* clock/clock.c, console/console.c, ide/pcmcia_ide.c,
ide/pcmcia_ide.h, irq/irq.c, irq/irq.h, irq/irq_asm.S,
irq/irq_init.c, nvram/m93cxx.h, nvram/nvram.c, nvram/nvram.h,
slicetimer/slicetimer.c, start/start.S, startup/bspstart.c,
startup/cpuinit.c, vectors/vectors.S, vectors/vectors_init.c:
Convert to utf-8.
* include/m68349.inc, start/start.S, startup/dumpanic.c:
Convert to utf-8.
* configure.ac: Require automake-1.9.
* bootloader/Makefile.am: Remove DEFAULT_INCLUDES.
* configure.ac, aclocal/multi.m4, aclocal/prog-cc.m4, aclocal/prog-ccas.m4
automake/compile.am: Adaptations to automake-1.10.
* configure.ac: Set RTEMS_API to 4.8.
* autotools/Makefile.am, autotools/automake.add: Update to
automake-1.10.
* console/defaultfont.c: Convert to utf-8.
* network_ada/adasockets/AUTHORS,
network_ada/adasockets/sockets-link.ads,
network_ada/adasockets/sockets-multicast.adb,
network_ada/adasockets/sockets-multicast.ads,
network_ada/adasockets/sockets-utils.adb,
network_ada/adasockets/sockets-utils.ads,
network_ada/adasockets/sockets.adb,
network_ada/adasockets/sockets.ads,
network_ada/listener/listener.adb,
network_ada/tcprelay/tcprelay.adb: Convert to utf-8.
which included commits to RCS files with non-trunk default branches.
* libmisc/monitor/mon-command.c: Flush stdout after updating the
command line.
* libnetworking/net/route.c, librpc/src/rpc/auth_none.c,
librpc/src/rpc/auth_unix.c, librpc/src/rpc/authunix_prot.c,
librpc/src/rpc/rpc_callmsg.c, librpc/src/rpc/rpc_prot.c,
librpc/src/rpc/rtems_portmapper.c: Removed warnings.
* user/barrier.t: New file.
* sapi/include/confdefs.h, sapi/src/posixapi.c, sapi/src/rtemsapi.c:
Add Classic API Barriers and commented out hooks to initialize .
* rtems/Makefile.am, rtems/preinstall.am, rtems/include/rtems.h,
rtems/include/rtems/rtems/attr.h, rtems/include/rtems/rtems/config.h,
rtems/inline/rtems/rtems/attr.inl, rtems/macros/rtems/rtems/attr.inl:
Add Classic API Barriers.
* rtems/include/rtems/rtems/barrier.h,
rtems/include/rtems/rtems/barriermp.h,
rtems/inline/rtems/rtems/barrier.inl,
rtems/macros/rtems/rtems/barrier.inl, rtems/src/barrier.c,
rtems/src/barriercreate.c, rtems/src/barrierdelete.c,
rtems/src/barrierident.c, rtems/src/barrierrelease.c,
rtems/src/barriertranslatereturncode.c, rtems/src/barrierwait.c:
New files.
score/include/rtems/score/coresem.h,
score/include/rtems/score/states.h,
score/inline/rtems/score/coresem.inl: Add SuperCore Barriers,
SpinLocks and a partial implementation of RWLocks.
* score/include/rtems/score/corebarrier.h,
score/include/rtems/score/corerwlock.h,
score/include/rtems/score/corespinlock.h,
score/inline/rtems/score/corebarrier.inl,
score/inline/rtems/score/corerwlock.inl,
score/inline/rtems/score/corespinlock.inl,
score/macros/rtems/score/corebarrier.inl,
score/macros/rtems/score/corerwlock.inl,
score/macros/rtems/score/corespinlock.inl, score/src/corebarrier.c,
score/src/corebarrierrelease.c, score/src/corebarrierwait.c,
score/src/corespinlock.c, score/src/corespinlockrelease.c,
score/src/corespinlockwait.c: New files.
* mongoosev/duart/mg5uart.c: Removed warnings.
* shared/gdbstub/mips-stub.c: Removed warnings.
* libmisc/cpuuse/cpuuse.c, libmisc/cpuuse/cpuuse.h: Promote CPU Usage
to first class citizen. Rename to start with rtems_ and include
documentation in user guide.
* new_chapters/Makefile.am, new_chapters/gen_section,
new_chapters/new_chapters.texi, user/Makefile.am, user/c_user.texi,
user/dirstat.texi: Promote CPU Usage to first class citizen. Rename
to start with rtems_ and include documentation in user guide.
* user/cpuuse.t: New file.
* new_chapters/cpuuse.t: Removed.
* libnetworking/rtems/rtems_malloc_mbuf.c: Removed warning by adding
prototype of malloc.
* libmisc/stackchk/check.c, libmisc/stackchk/internal.h,
libmisc/stackchk/stackchk.h: Move stack to first class citizen
status. Include it in User Manual and rename to start with rtems_.
* new_chapters/Makefile.am, user/Makefile.am, user/c_user.texi,
user/dirstat.texi, user/task.t: Move stack to first class citizen
* user/stackchk.t: New file.
* new_chapters/stackchk.t: Removed.
* sh7750/include/rtems/score/sh7750_regs.h: Fix spelling of IPRC
(Probably a cyrillic 'C' instead of an ASCI 'C').
* configure.ac: Use RTEMS_AMPOLISH3.
* mongoosev/vectorisrs/vectorisrs.c: Convert C++ style comments to C
style.
* librdbg/src/_servtgt.c: Convert C++ style comments to C style.
* include/mpc5200.h, network_5200/network.c: Convert C++ style comments
to C style.
* startup/bspstart.c: Convert C++ style comments to C style.
* console/console.c, console/sci.c, console/sci.h, spurious/spinit.c,
startup/bspclean.c, startup/start_c.c: Convert C++ style comments to
C style.
* console/console.c, startup/init5235.c: Convert C++ style comments to
C style.
* startup/init5282.c: Convert C++ style comments to C style.
* console/fb_vga.c, console/kd.h: Convert C++ style comments to C
style.
* include/arm_mode_bits.h: Convert C++ style comments to C style.
* libmisc/mw-fb/mw_fb.c, libmisc/mw-fb/mw_fb.h, libmisc/mw-fb/mw_uid.c,
libmisc/mw-fb/mw_uid.h: Remove warning.
