* | new states added and _Rate_monotonic_Set_State removed. | Joel Sherrill | 1995-12-05 | 5 | -205/+127 |
* | Insert mode argument to _Watchdog_Insert removed. Now are watchdog timers | Joel Sherrill | 1995-12-01 | 27 | -180/+75 |
| | | | | are automatically activated upon insertion. | ||||
* | Added new synchronization algorithm. | Joel Sherrill | 1995-12-01 | 2 | -116/+184 |
* | Added support for new synchronization algorithm. Specifically, the routine | Joel Sherrill | 1995-12-01 | 3 | -0/+42 |
| | | | | _Thread_queue_Enter_critical_section was added. | ||||
* | Added support for new synchronization algorithm. | Joel Sherrill | 1995-12-01 | 3 | -0/+75 |
* | Changed code for exit from synchronization state to a switch on the | Joel Sherrill | 1995-12-01 | 2 | -22/+38 |
| | | | | | possible synchronization actions. This should have made it harder to avoid a case. | ||||
* | spurious blank line removed | Joel Sherrill | 1995-12-01 | 3 | -3/+0 |
* | Replaced critical section algorithm to correct race conditions. | Joel Sherrill | 1995-12-01 | 2 | -20/+38 |
* | Made _Event_Sync volatile | Joel Sherrill | 1995-12-01 | 3 | -6/+45 |
| | | | | | | Replaced critical section algorithm to correct race conditions. This resulted in the new variable _Event_Sync_state and the type _Event_Sync_states. | ||||
* | Corrected use of the state WATCHDOG_REINSERT and renamed it | Joel Sherrill | 1995-12-01 | 5 | -24/+50 |
| | | | | WATCHDOG_BEING_INSERTED. | ||||
* | typos fixed | Joel Sherrill | 1995-10-31 | 25 | -73/+481 |
* | SPARC port passes all tests | Joel Sherrill | 1995-10-30 | 112 | -1370/+4366 |
* | reordered test cases from simple to complex | Joel Sherrill | 1995-10-11 | 2 | -26/+50 |
* | fixed null pointer dereference | Joel Sherrill | 1995-10-06 | 2 | -4/+4 |
* | fixed missing CVS IDs | Joel Sherrill | 1995-10-06 | 136 | -24/+215 |
* | SPARC merged and successfully tested w/o interrupt support | Joel Sherrill | 1995-10-06 | 23 | -4/+2295 |
* | moved to new development machine and went to gcc 2.7.0 | Joel Sherrill | 1995-10-06 | 17 | -6/+38 |
* | all targets compile .. tony's patches in place | Joel Sherrill | 1995-09-29 | 70 | -318/+629 |
* | new programs added | Joel Sherrill | 1995-09-27 | 6 | -2/+552 |
* | updated | Joel Sherrill | 1995-09-27 | 1 | -13/+8 |
* | Modified UNIX simulator port so all references to native unix | Joel Sherrill | 1995-09-27 | 36 | -342/+966 |
| | | | | | stuff is in the executive source proper in the file cpu.c. This should help avoid conflicts between RTEMS POSIX files and UNIX files. | ||||
* | Fixed typo | Joel Sherrill | 1995-09-27 | 3 | -6/+6 |
* | posix support initially added | Joel Sherrill | 1995-09-26 | 488 | -1203/+21585 |
* | fixed Id strings | Joel Sherrill | 1995-09-26 | 6 | -3/+12 |
* | new file | Joel Sherrill | 1995-09-26 | 1 | -0/+436 |
* | Removed unnecessary include files. | Joel Sherrill | 1995-09-22 | 2 | -2/+2 |
* | Removed unneeded referenced to rtems/fatal.h | Joel Sherrill | 1995-09-22 | 11 | -11/+0 |
* | moving files around and adding the exec/wrapup directory | Joel Sherrill | 1995-09-22 | 8 | -16/+22 |
* | More file movement required api extension to be added to score | Joel Sherrill | 1995-09-21 | 9 | -10/+442 |
* | More file movement | Joel Sherrill | 1995-09-21 | 8 | -8/+8 |
* | More file movement | Joel Sherrill | 1995-09-21 | 10 | -12/+6 |
* | More file movement | Joel Sherrill | 1995-09-21 | 9 | -17/+12 |
* | Fixed problem in fast_idle_switch_hook | Joel Sherrill | 1995-09-21 | 1 | -1/+1 |
* | moving files around | Joel Sherrill | 1995-09-21 | 22 | -38/+28 |
* | Changed version number | Joel Sherrill | 1995-09-20 | 2 | -2/+2 |
* | Actually adding efi bsp's from John Gwynne after forgetting to | Joel Sherrill | 1995-09-20 | 28 | -0/+4376 |
| | | | | commit them. | ||||
* | Heap changes required some changes in this screen. | Joel Sherrill | 1995-09-19 | 2 | -14/+34 |
* | Modifications from Tony Bennett accepted to tune this test a little. | Joel Sherrill | 1995-09-19 | 8 | -22/+44 |
* | Modifications from Tony Bennett accepted to return aligned block. | Joel Sherrill | 1995-09-19 | 4 | -24/+80 |
| | | | | | Thread_Close fixed to avoid returning FP context area when one was not allocated at initialization time. | ||||
* | Modifications from Tony Bennett accepted to return aligned block. | Joel Sherrill | 1995-09-19 | 9 | -0/+114 |
* | Removed a section of code which was "#if 0"'ed. | Joel Sherrill | 1995-09-19 | 1 | -16/+0 |
* | Incorporated the submission from John S. Gwynne | Joel Sherrill | 1995-09-19 | 14 | -94/+1754 |
| | | | | | | <jsg@coulomb.eng.ohio-state.edu> of the rest of the 68000-ish support for interrupt handling and bfffo support, the two BSPs he submitted (efi68k and efi332), and SGI Irix 5.3 host support. | ||||
* | Minor bug fixes to get all targets compilable and running. The | Joel Sherrill | 1995-09-19 | 228 | -2348/+4843 |
| | | | | | | single biggest changes were the expansion of the workspace size macro to include other types of objects and the increase in the minimum stack size for most CPUs. | ||||
* | Initial attempt at building HP PA-RISC using Solaris hosted tools. | Joel Sherrill | 1995-09-12 | 12 | -28/+313 |
| | | | | Changed back to Newlib for Solaris UNIX simulator. | ||||
* | Added... | Joel Sherrill | 1995-09-11 | 2 | -0/+90 |
* | Added... This is the Configuration Tables Template file. | Joel Sherrill | 1995-09-11 | 3 | -0/+846 |
* | Added | Joel Sherrill | 1995-09-11 | 3 | -0/+621 |
* | The word "RTEMS" almost completely removed from the core. | Joel Sherrill | 1995-09-11 | 883 | -11327/+20872 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Configuration Table Template file added and all tests modified to use this. All gvar.h and conftbl.h files removed from test directories. Configuration parameter maximum_devices added. Core semaphore and mutex handlers added and RTEMS API Semaphore Manager updated to reflect this. Initialization sequence changed to invoke API specific initialization routines. Initialization tasks table now owned by RTEMS Tasks Manager. Added user extension for post-switch. Utilized user extensions to implement API specific functionality like signal dispatching. Added extensions to the System Initialization Thread so that an API can register a function to be invoked while the system is being initialized. These are largely equivalent to the pre-driver and post-driver hooks. Added the Modules file oar-go32_p5, modified oar-go32, and modified the file make/custom/go32.cfg to look at an environment varable which determines what CPU model is being used. All BSPs updated to reflect named devices and clock driver's IOCTL used by the Shared Memory Driver. Also merged clock isr into main file and removed ckisr.c where possible. Updated spsize to reflect new and moved variables. Makefiles for the executive source and include files updated to show break down of files into Core, RTEMS API, and Neither. Header and inline files installed into subdirectory based on whether logically in the Core or a part of the RTEMS API. | ||||
* | new file -- split from inlines | Joel Sherrill | 1995-08-29 | 2 | -0/+404 |
* | Added unused priority ceiling parameter to rtems_semaphore_create. | Joel Sherrill | 1995-08-28 | 159 | -804/+2388 |
| | | | | | | | | | | | | | | | Rearranged code to created thread handler routines to initialize, start, restart, and "close/delete" a thread. Made internal threads their own object class. This now uses the thread support routines for starting and initializing a thread. Insured deleted tasks are freed to the Inactive pool associated with the correct Information block. Added an RTEMS API specific data area to the thread control block. Beginnings of removing the word "rtems" from the core. |
