* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 1 | -0/+7 |
| | | | | | | | * custom/gensh1.cfg, custom/gensh2.cfg, custom/gensh4.cfg, custom/simsh1.cfg, custom/simsh2.cfg, custom/simsh2e.cfg, custom/simsh4.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>). | ||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 5 | -0/+83 |
| | | | | | | | * make/custom/simsh1.cfg: New (relocated from /make/custom). * make/custom/simsh2.cfg: New (relocated from /make/custom). * make/custom/simsh2e.cfg: New (relocated from /make/custom). * make/custom/simsh4.cfg: New (relocated from /make/custom). | ||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 2 | -0/+37 |
| | | | | * make/custom/gensh4.cfg: New (relocated from /make/custom). | ||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 2 | -0/+30 |
| | | | | * make/custom/gensh2.cfg: New (relocated from /make/custom). | ||||
| | | | | * make/custom/gensh1.cfg: New (relocated from /make/custom). | ||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 4 | -2/+15 |
| | | | | | * aclocal/check-custom-bsp.m4: Let _RTEMS_CHECK_CUSTOM_BSP look for *.cfg into c/src/lib/libbsp/<cpu>/<bsp_family>/make/custom. | ||||
* | 2009-10-14 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-10-14 | 2 | -38/+32 |
| | | | | | * sp32/init.c: Lengthen the clock tick and move configuration to the bottom of the file. | ||||
* | 2009-10-14 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-10-14 | 2 | -1/+18 |
| | | | | | * psxtimer01/psxtimer.c: It is not necessarily an error for the time remaining to not equal the period. | ||||
* | 2009-10-14 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-10-14 | 2 | -4/+9 |
| | | | | | * tmck/task1.c: Ignore numbers that are too large but keep going -- do not abort. | ||||
* | 2009-10-14 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-10-14 | 2 | -3/+7 |
| | | | | * unlimited/test1.c: Spacing. | ||||
* | 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-14 | 3 | -59/+3 |
| | | | | | * libcsupport/src/no_libc.c: Remove. * libcsupport/Makefile.am: Remove no_libc.c. | ||||
* | 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-14 | 2 | -4/+1 |
| | | | | * libcsupport/src/newlibc_reent.c: Eliminate RTEMS_UNIX. | ||||
* | 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-14 | 2 | -4/+2 |
| | | | | * libcsupport/src/newlibc_exit.c: Eliminate RTEMS_UNIX. | ||||
* | 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-14 | 2 | -3/+1 |
| | | | | * libcsupport/src/base_fs.c: Eliminate RTEMS_UNIX. | ||||
| | | | | * libcsupport/src/stat.c: Eliminate RTEMS_UNIX. | ||||
* | 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-14 | 2 | -18/+2 |
| | | | | * libmisc/monitor/mon-editor.c: Eliminate RTEMS_UNIX. | ||||
* | 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-14 | 2 | -10/+6 |
| | | | | | * libcsupport/include/rtems/libcsupport.h: Remove RTEMS_UNIX, hpux. Fix extern "C" {}. | ||||
* | 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-14 | 2 | -8/+4 |
| | | | | * libfs/src/imfs/ioman.c: Remove RTEMS_UNIX, __linux__. | ||||
* | 2009-10-14 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-10-14 | 2 | -3/+4 |
| | | | | * score/src/threadhandler.c: Remove comment mentioning unix port. | ||||
* | 2009-10-14 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-10-14 | 2 | -1/+5 |
| | | | | * bsp_howto/console.t: Capitalization. | ||||
* | 2009-10-14 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-10-14 | 2 | -1/+7 |
| | | | | * user/preface.texi: Remove UNIX and update port list. | ||||
* | Remove unix. | Joel Sherrill | 2009-10-14 | 1 | -1/+0 |
* | 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-14 | 2 | -2/+1 |
| | | | | * wrapup/Makefile.am: Remove UNIX. | ||||
* | Regenerate. | Ralf Corsepius | 2009-10-14 | 2 | -4/+1 |
* | 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-14 | 2 | -1/+1 |
| | | | | * configure.ac: Remove UNIX AM_CONDITIONAL. | ||||
* | 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-14 | 2 | -4/+3 |
| | | | | | * libfs/Makefile.am: Unconditionally build src/pipe/fifo.c src/pipe/pipe.c src/pipe/pipe.h. | ||||
| | | | | * libblock/Makefile.am: Unconditionall build libblock. | ||||
| | | | | * Makefile.am: Unconditional build libblock. | ||||
* | Remove libfs/src/imfs/imfs_unixstub.c, libfs/src/devfs/devfs_unixstub.c. | Ralf Corsepius | 2009-10-14 | 1 | -4/+0 |
* | Remove | Ralf Corsepius | 2009-10-14 | 2 | -124/+0 |
* | 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-14 | 1 | -0/+7 |
| | | | | | | | * libfs/src/imfs/imfs_unixstub.c, libfs/src/devfs/devfs_unixstub.c: Remove (unused). * libfs/Makefile.am: Remove libfs/src/imfs/imfs_unixstub.c, libfs/src/devfs/devfs_unixstub.c. | ||||
| | | | | | | | * libcsupport/src/unixlibc.c, libcsupport/src/unixlibc_io.c, libcsupport/src/hosterr.c: Remove (unused). * libcsupport/Makefile.am: Remove libcsupport/src/unixlibc.c, libcsupport/src/unixlibc_io.c, libcsupport/src/hosterr.c. | ||||
* | Remove libcsupport/src/unixlibc.c, libcsupport/src/unixlibc_io.c, ↵ | Ralf Corsepius | 2009-10-14 | 1 | -4/+0 |
* | Remove. | Ralf Corsepius | 2009-10-14 | 3 | -120/+0 |
* | 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-14 | 1 | -0/+6 |
| | | | | | | * aclocal/canonical-target-name.m4, aclocal/check-networking.m4, aclocal/check-posix.m4, aclocal/enable-posix.m4, aclocal/rtems-cpu-subdirs.m4: Remove posix/unix. | ||||
* | 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-14 | 5 | -20/+7 |
| | | | | | * HELP.html, bsp_howto/support.t, relnotes/status.texi, started_ada/buildada.t: Remove references to posix/Unix port. | ||||
* | 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-14 | 2 | -5/+4 |
| | | | | * tmck/task1.c: Remove support for "unix". | ||||
* | 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-14 | 2 | -125/+1 |
| | | | | * aclocal/sysv-ipc.m4: Remove (unused). | ||||
* | 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-14 | 2 | -10/+4 |
| | | | | * configure.ac: Remove RTEMS_UNIX, RTEMS_UNIXLIB. | ||||
* | 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-14 | 1 | -1/+4 |
| | | | | | | | * configure.ac: Remove some unix-specific checks. Remove unix-CPU_CONTEXT size checking. Remove enable-unixlib. Remove unix subdir. | ||||
* | Remove some unix-specific checks. | Ralf Corsepius | 2009-10-14 | 1 | -4/+2 |
* | Remove unix-CPU_CONTEXT size checking. | Ralf Corsepius | 2009-10-14 | 1 | -5/+0 |
* | Remove unix-CPU_CONTEXT size checking. | Ralf Corsepius | 2009-10-14 | 1 | -17/+0 |
* | Remove enable-unixlib. | Ralf Corsepius | 2009-10-14 | 1 | -6/+0 |
* | 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-14 | 1 | -0/+8 |
| | | | | * configure.ac: Remove unix subdir. | ||||
* | Remove unix subdir. | Ralf Corsepius | 2009-10-14 | 1 | -1/+0 |
| | | | | | | * aclocal/canonical-target-name.m4, aclocal/check-networking.m4, aclocal/check-posix.m4, aclocal/enable-posix.m4: Remove unix/posix. | ||||
* | Remove unix/posix. | Ralf Corsepius | 2009-10-14 | 4 | -27/+0 |
* | Remove posix/unix. | Ralf Corsepius | 2009-10-14 | 5 | -34/+0 |
* | Remove (Abandoned). | Ralf Corsepius | 2009-10-14 | 42 | -2569/+0 |
