* | added calls to _Thread_Disable_dispatch to match requirements | Joel Sherrill | 1995-06-05 | 2 | -6/+26 | |
| | | | | for invocation of _Thread_Handler | |||||
* | conditional added for the hppa gr27 | Joel Sherrill | 1995-06-05 | 2 | -0/+4 | |
* | incorporate Tony's patches: | Joel Sherrill | 1995-06-05 | 4 | -9/+12 | |
| | | | | | | | | | | + c/src/lib/libc/support/generic/malloc.c did not initialize the sbrk amount + _Thread_Handler in c/src/exec/rtems/thread.c left a window during the begin extension which could result in a context switch fixed places which did not correctly distinguish between an CPU_isr and a CPU_isr_entry. | |||||
* | changed release number to 3.2.0 | Joel Sherrill | 1995-06-04 | 9 | -28/+30 | |
* | Corrected minor number for "Null" device driver | Joel Sherrill | 1995-05-31 | 2 | -2/+2 | |
* | fixing revision | Joel Sherrill | 1995-05-31 | 8 | -0/+24 | |
* | forced revision | Joel Sherrill | 1995-05-31 | 0 | -0/+0 | |
* | Added "signed" keyword to typedef of signed RTEMS types | Joel Sherrill | 1995-05-31 | 6 | -24/+24 | |
* | cpu/*types.h added and successfully compiled. | Joel Sherrill | 1995-05-30 | 19 | -39/+59 | |
| | | | | IDLE task priority changed from 0 to 255 during initialization. | |||||
* | Added m68ktypes.h | Joel Sherrill | 1995-05-26 | 1 | -0/+56 | |
* | Created rest of CP types.h files | Joel Sherrill | 1995-05-26 | 3 | -0/+168 | |
* | Trying to force back onto trunk | Joel Sherrill | 1995-05-26 | 0 | -0/+0 | |
* | Added types.h file for each CPU | Joel Sherrill | 1995-05-25 | 2 | -0/+102 | |
* | TEST | Joel Sherrill | 1995-05-25 | 2 | -0/+4 | |
* | test force of revision | Joel Sherrill | 1995-05-25 | 0 | -0/+0 | |
* | Fully tested on all in-house targets | Joel Sherrill | 1995-05-24 | 93 | -939/+756 | |
* | Forcing RCS revision to 1.2 I hope | Joel Sherrill | 1995-05-11 | 0 | -0/+0 | |
* | Initial revision | Joel Sherrill | 1995-05-11 | 1683 | -0/+189788 | |
