Add TM27_USE_VECTOR_HANDLER to select the interrupt handler type used by
the <tm27.h> implementation.
Close #4820.
Do not use a chained assignment for code clarity.
Close #4818.
For example, the QorIQ T4240 has more than 16 TLB1 entries.
This adds a test verifying basic TLS functionality in loadable modules
now that at least one architecture supports it.
This adds basic TLS relocation support for AArch64 to libdl. This lets
loadable modules use TLS symbols hosted in the main binary. This does
not allow loadable modules to host their own TLS symbols.
This prints the relocation type that was found to be missing in addition
to its address to aid in bug reports.
The mask 0xff is used by ELF32 while ELF64 uses 0xffffffff. These are
automatically selected based on the build type when using ELF_R_TYPE().
This should use the CC 4.0 license to match the rest of the tree.
Merge the "default" and "default-by-variant" attributes. Use an
"enabled-by" expression to select the default value based on the enabled
set. This makes it possible to select default values depending on other
options. For example you could choose memory settings based on whether
RTEMS_SMP is enabled or disabled.
The change was tested by comparing the output of
./waf bspdefaults
before and after the change.
Replace the variant patterns in the default-by-variant list with an
explicit list of matching BSPs.
./waf bspdefaults
Use yaml.dump(data, default_flow_style=False, allow_unicode=True) with a
custom representer for integer default values to format all build items.
The RTEMS and Linux JFFS2 compression support have a slightly different
interface. This fixes a bug introduced by:
commit 17c3d536ca8ee17d36ea251eade884e07ff1ee75
Author: Yang Yang <yang.yang29@zte.com.cn>
Date: Thu Jan 28 02:55:35 2021 -0800
jffs2: check the validity of dstlen in jffs2_zlib_compress()
KASAN reports a BUG when download file in jffs2 filesystem.It is
because when dstlen == 1, cpage_out will write array out of bounds.
Actually, data will not be compressed in jffs2_zlib_compress() if
data's length less than 4.
There is a regular need in the kernel to provide a way to declare
having a dynamically sized set of trailing elements in a structure.
Kernel code should always use “flexible array members”[1] for these
cases. The older style of one-element or zero-length arrays should
no longer be used[2].
This code was transformed with the help of Coccinelle:
(linux-5.19-rc2$ spatch --jobs $(getconf _NPROCESSORS_ONLN) --sp-file script.cocci --include-headers --dir . > output.patch)
identifier S, member, array;
type T1, T2;
struct S {
T1 member;
T2 array[
- 0
-fstrict-flex-arrays=3 is coming and we need to land these changes
to prevent issues like these in the short future:
../fs/minix/dir.c:337:3: warning: 'strcpy' will always overflow; destination buffer has size 0,
but the source string has length 2 (including NUL byte) [-Wfortify-source]
strcpy(de3->name, ".");
Since these are all [0] to [] changes, the risk to UAPI is nearly zero. If
this breaks anything, we can use a union with a new member name.
[1] https://en.wikipedia.org/wiki/Flexible_array_member
[2] https://www.kernel.org/doc/html/v5.16/process/deprecated.html#zero-length-and-one-element-arrays
Link: https://github.com/KSPP/linux/issues/78
Build-tested-by: kernel test robot <lkp@intel.com>
Link: https://lore.kernel.org/lkml/62b675ec.wKX6AOZ6cbE71vtF%25lkp@intel.com/
Acked-by: Dan Williams <dan.j.williams@intel.com> # For ndctl.h
Signed-off-by: Gustavo A. R. Silva <gustavoars@kernel.org>
Use kzalloc rather than duplicating its implementation, which
makes code simple and easy to understand.
Signed-off-by: Haowen Bai <baihaowen@meizu.com>
[rw: Fixed printk string]
Signed-off-by: Richard Weinberger <richard@nod.at>
By making filler_t the same as read_folio, we can use the same function
for both in gfs2. We can push the use of folios down one more level
in jffs2 and nfs. We also increase type safety for future users of the
various read_cache_page() family of functions by forcing the parameter
to be a pointer to struct file (or NULL).
Signed-off-by: Matthew Wilcox (Oracle) <willy@infradead.org>
Reviewed-by: Christoph Hellwig <hch@lst.de>
Reviewed-by: Andreas Gruenbacher <agruenba@redhat.com>
In preparation for unifying the read_cache_page() and read_folio()
implementations, make jffs2_do_readpage_unlock() get the inode
from the page instead of passing it in from read_cache_page().
If an error is returned in jffs2_scan_eraseblock() and some memory
has been added to the jffs2_summary *s, we can observe the following
kmemleak report:
unreferenced object 0xffff88812b889c40 (size 64):
comm "mount", pid 692, jiffies 4294838325 (age 34.288s)
hex dump (first 32 bytes):
40 48 b5 14 81 88 ff ff 01 e0 31 00 00 00 50 00 @H........1...P.
00 00 01 00 00 00 01 00 00 00 02 00 00 00 09 08 ................
backtrace:
[<ffffffffae93a3a3>] __kmalloc+0x613/0x910
[<ffffffffaf423b9c>] jffs2_sum_add_dirent_mem+0x5c/0xa0
[<ffffffffb0f3afa8>] jffs2_scan_medium.cold+0x36e5/0x4794
[<ffffffffb0f3dbe1>] jffs2_do_mount_fs.cold+0xa7/0x2267
[<ffffffffaf40acf3>] jffs2_do_fill_super+0x383/0xc30
[<ffffffffaf40c00a>] jffs2_fill_super+0x2ea/0x4c0
[<ffffffffb0315d64>] mtd_get_sb+0x254/0x400
[<ffffffffb0315f5f>] mtd_get_sb_by_nr+0x4f/0xd0
[<ffffffffb0316478>] get_tree_mtd+0x498/0x840
[<ffffffffaf40bd15>] jffs2_get_tree+0x25/0x30
[<ffffffffae9f358d>] vfs_get_tree+0x8d/0x2e0
[<ffffffffaea7a98f>] path_mount+0x50f/0x1e50
[<ffffffffaea7c3d7>] do_mount+0x107/0x130
[<ffffffffaea7c5c5>] __se_sys_mount+0x1c5/0x2f0
[<ffffffffaea7c917>] __x64_sys_mount+0xc7/0x160
[<ffffffffb10142f5>] do_syscall_64+0x45/0x70
unreferenced object 0xffff888114b54840 (size 32):
c0 75 b5 14 81 88 ff ff 02 e0 02 00 00 00 02 00 .u..............
00 00 84 00 00 00 44 00 00 00 6b 6b 6b 6b 6b a5 ......D...kkkkk.
backtrace:
[<ffffffffae93be24>] kmem_cache_alloc_trace+0x584/0x880
[<ffffffffaf423b04>] jffs2_sum_add_inode_mem+0x54/0x90
[<ffffffffb0f3bd44>] jffs2_scan_medium.cold+0x4481/0x4794
unreferenced object 0xffff888114b57280 (size 32):
comm "mount", pid 692, jiffies 4294838393 (age 34.357s)
10 d5 6c 11 81 88 ff ff 08 e0 05 00 00 00 01 00 ..l.............
00 00 38 02 00 00 28 00 00 00 6b 6b 6b 6b 6b a5 ..8...(...kkkkk.
backtrace:
[<ffffffffaf423c34>] jffs2_sum_add_xattr_mem+0x54/0x90
[<ffffffffb0f3a24f>] jffs2_scan_medium.cold+0x298c/0x4794
unreferenced object 0xffff8881116cd510 (size 16):
comm "mount", pid 692, jiffies 4294838395 (age 34.355s)
hex dump (first 16 bytes):
00 00 00 00 00 00 00 00 09 e0 60 02 00 00 6b a5 ..........`...k.
backtrace:
[<ffffffffaf423cc4>] jffs2_sum_add_xref_mem+0x54/0x90
[<ffffffffb0f3b2e3>] jffs2_scan_medium.cold+0x3a20/0x4794
Therefore, we should call jffs2_sum_reset_collected(s) on exit to
release the memory added in s. In addition, a new tag "out_buf" is
added to prevent the NULL pointer reference caused by s being NULL.
(thanks to Zhang Yi for this analysis)
Fixes: e631ddba5887 ("[JFFS2] Add erase block summary support (mount time improvement)")
Cc: stable@vger.kernel.org
Co-developed-with: Zhihao Cheng <chengzhihao1@huawei.com>
Signed-off-by: Baokun Li <libaokun1@huawei.com>
If jffs2_build_filesystem() in jffs2_do_mount_fs() returns an error,
we can observe the following kmemleak report:
unreferenced object 0xffff88811b25a640 (size 64):
comm "mount", pid 691, jiffies 4294957728 (age 71.952s)
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<ffffffffa493be24>] kmem_cache_alloc_trace+0x584/0x880
[<ffffffffa5423a06>] jffs2_sum_init+0x86/0x130
[<ffffffffa5400e58>] jffs2_do_mount_fs+0x798/0xac0
[<ffffffffa540acf3>] jffs2_do_fill_super+0x383/0xc30
[<ffffffffa540c00a>] jffs2_fill_super+0x2ea/0x4c0
unreferenced object 0xffff88812c760000 (size 65536):
bb bb bb bb bb bb bb bb bb bb bb bb bb bb bb bb ................
backtrace:
[<ffffffffa493a449>] __kmalloc+0x6b9/0x910
[<ffffffffa5423a57>] jffs2_sum_init+0xd7/0x130
This is because the resources allocated in jffs2_sum_init() are not
released. Call jffs2_sum_exit() to release these resources to solve
the problem.
inode->i_mutex has been replaced with inode->i_rwsem long ago. Fix
comments still mentioning i_mutex.
Signed-off-by: hongnanli <hongnan.li@linux.alibaba.com>
Add a rcu argument to the ->get_acl() callback to allow
get_cached_acl_rcu() to call the ->get_acl() method in the next patch.
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
Building with W=1 shows a few warnings for empty macros:
fs/jffs2/scan.c: In function 'jffs2_scan_xattr_node':
fs/jffs2/scan.c:378:66: error: suggest braces around empty body in an 'if' statement [-Werror=empty-body]
378 | jffs2_sum_add_xattr_mem(s, rx, ofs - jeb->offset);
fs/jffs2/scan.c: In function 'jffs2_scan_xref_node':
fs/jffs2/scan.c:434:65: error: suggest braces around empty body in an 'if' statement [-Werror=empty-body]
434 | jffs2_sum_add_xref_mem(s, rr, ofs - jeb->offset);
fs/jffs2/scan.c: In function 'jffs2_scan_eraseblock':
fs/jffs2/scan.c:893:88: error: suggest braces around empty body in an 'if' statement [-Werror=empty-body]
893 | jffs2_sum_add_padding_mem(s, je32_to_cpu(node->totlen));
Change all these macros to 'do { } while (0)' statements to avoid the
warnings and make the code a little more robust.
Signed-off-by: Arnd Bergmann <arnd@arndb.de>
KASAN report a slab-out-of-bounds problem. The logs are listed below.
It is because in function jffs2_scan_dirent_node, we alloc "checkedlen+1"
bytes for fd->name and we check crc with length rd->nsize. If checkedlen
is less than rd->nsize, it will cause the slab-out-of-bounds problem.
jffs2: Dirent at *** has zeroes in name. Truncating to %d char
BUG: KASAN: slab-out-of-bounds in crc32_le+0x1ce/0x260 at addr ffff8800842cf2d1
Read of size 1 by task test_JFFS2/915
BUG kmalloc-64 (Tainted: G B O ): kasan: bad access detected
INFO: Allocated in jffs2_alloc_full_dirent+0x2a/0x40 age=0 cpu=1 pid=915
___slab_alloc+0x580/0x5f0
__slab_alloc.isra.24+0x4e/0x64
__kmalloc+0x170/0x300
jffs2_scan_eraseblock+0x1ca4/0x3b64
jffs2_scan_medium+0x285/0xfe0
jffs2_do_mount_fs+0x5fb/0x1bbc
jffs2_do_fill_super+0x245/0x6f0
jffs2_fill_super+0x287/0x2e0
mount_mtd_aux.isra.0+0x9a/0x144
mount_mtd+0x222/0x2f0
jffs2_mount+0x41/0x60
mount_fs+0x63/0x230
vfs_kern_mount.part.6+0x6c/0x1f4
do_mount+0xae8/0x1940
SyS_mount+0x105/0x1d0
INFO: Freed in jffs2_free_full_dirent+0x22/0x40 age=27 cpu=1 pid=915
__slab_free+0x372/0x4e4
kfree+0x1d4/0x20c
jffs2_build_remove_unlinked_inode+0x17a/0x1e4
jffs2_do_mount_fs+0x1646/0x1bbc
mount_fs+0x63/0x230
entry_SYSCALL_64_fastpath+0x1e/0x97
Call Trace:
[<ffffffff815befef>] dump_stack+0x59/0x7e
[<ffffffff812d1d65>] print_trailer+0x125/0x1b0
[<ffffffff812d82c8>] object_err+0x34/0x40
[<ffffffff812dadef>] kasan_report.part.1+0x21f/0x534
[<ffffffff81132401>] ? vprintk+0x2d/0x40
[<ffffffff815f1ee2>] ? crc32_le+0x1ce/0x260
[<ffffffff812db41a>] kasan_report+0x26/0x30
[<ffffffff812d9fc1>] __asan_load1+0x3d/0x50
[<ffffffff815f1ee2>] crc32_le+0x1ce/0x260
[<ffffffff814764ae>] ? jffs2_alloc_full_dirent+0x2a/0x40
[<ffffffff81485cec>] jffs2_scan_eraseblock+0x1d0c/0x3b64
[<ffffffff81488813>] ? jffs2_scan_medium+0xccf/0xfe0
[<ffffffff81483fe0>] ? jffs2_scan_make_ino_cache+0x14c/0x14c
[<ffffffff812da3e9>] ? kasan_unpoison_shadow+0x35/0x50
[<ffffffff812da462>] ? kasan_kmalloc+0x5e/0x70
[<ffffffff812d5d90>] ? kmem_cache_alloc_trace+0x10c/0x2cc
[<ffffffff818169fb>] ? mtd_point+0xf7/0x130
[<ffffffff81487dc9>] jffs2_scan_medium+0x285/0xfe0
[<ffffffff81487b44>] ? jffs2_scan_eraseblock+0x3b64/0x3b64
[<ffffffff812d57df>] ? __kmalloc+0x12b/0x300
[<ffffffff814a2753>] ? jffs2_sum_init+0x9f/0x240
[<ffffffff8148b2ff>] jffs2_do_mount_fs+0x5fb/0x1bbc
[<ffffffff8148ad04>] ? jffs2_del_noinode_dirent+0x640/0x640
[<ffffffff81127c5b>] ? __init_rwsem+0x97/0xac
[<ffffffff81492349>] jffs2_do_fill_super+0x245/0x6f0
[<ffffffff81493c5b>] jffs2_fill_super+0x287/0x2e0
[<ffffffff814939d4>] ? jffs2_parse_options+0x594/0x594
[<ffffffff81819bea>] mount_mtd_aux.isra.0+0x9a/0x144
[<ffffffff81819eb6>] mount_mtd+0x222/0x2f0
[<ffffffff81819c94>] ? mount_mtd_aux.isra.0+0x144/0x144
[<ffffffff81258757>] ? free_pages+0x13/0x1c
[<ffffffff814fa0ac>] ? selinux_sb_copy_data+0x278/0x2e0
[<ffffffff81492b35>] jffs2_mount+0x41/0x60
[<ffffffff81302fb7>] mount_fs+0x63/0x230
[<ffffffff8133755f>] ? alloc_vfsmnt+0x32f/0x3b0
[<ffffffff81337f2c>] vfs_kern_mount.part.6+0x6c/0x1f4
[<ffffffff8133ceec>] do_mount+0xae8/0x1940
[<ffffffff811b94e0>] ? audit_filter_rules.constprop.6+0x1d10/0x1d10
[<ffffffff8133c404>] ? copy_mount_string+0x40/0x40
[<ffffffff812cbf78>] ? alloc_pages_current+0xa4/0x1bc
[<ffffffff81253a89>] ? __get_free_pages+0x25/0x50
[<ffffffff81338993>] ? copy_mount_options.part.17+0x183/0x264
[<ffffffff8133e3a9>] SyS_mount+0x105/0x1d0
[<ffffffff8133e2a4>] ? copy_mnt_ns+0x560/0x560
[<ffffffff810e8391>] ? msa_space_switch_handler+0x13d/0x190
[<ffffffff81be184a>] entry_SYSCALL_64_fastpath+0x1e/0x97
[<ffffffff810e9274>] ? msa_space_switch+0xb0/0xe0
Memory state around the buggy address:
ffff8800842cf180: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
ffff8800842cf200: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
>ffff8800842cf280: fc fc fc fc fc fc 00 00 00 00 01 fc fc fc fc fc
ffff8800842cf300: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
ffff8800842cf380: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
Reported-by: Kunkun Xu <xukunkun1@huawei.com>
Signed-off-by: lizhe <lizhe67@huawei.com>
[ 393.799778] BUG: KASAN: slab-out-of-bounds in jffs2_rtime_compress+0x214/0x2f0 at addr ffff800062e3b281
[ 393.809166] Write of size 1 by task tftp/2918
[ 393.813526] CPU: 3 PID: 2918 Comm: tftp Tainted: G B 4.9.115-rt93-EMBSYS-CGEL-6.1.R6-dirty #1
[ 393.823173] Hardware name: LS1043A RDB Board (DT)
[ 393.827870] Call trace:
[ 393.830322] [<ffff20000808c700>] dump_backtrace+0x0/0x2f0
[ 393.835721] [<ffff20000808ca04>] show_stack+0x14/0x20
[ 393.840774] [<ffff2000086ef700>] dump_stack+0x90/0xb0
[ 393.845829] [<ffff20000827b19c>] kasan_object_err+0x24/0x80
[ 393.851402] [<ffff20000827b404>] kasan_report_error+0x1b4/0x4d8
[ 393.857323] [<ffff20000827bae8>] kasan_report+0x38/0x40
[ 393.862548] [<ffff200008279d44>] __asan_store1+0x4c/0x58
[ 393.867859] [<ffff2000084ce2ec>] jffs2_rtime_compress+0x214/0x2f0
[ 393.873955] [<ffff2000084bb3b0>] jffs2_selected_compress+0x178/0x2a0
[ 393.880308] [<ffff2000084bb530>] jffs2_compress+0x58/0x478
[ 393.885796] [<ffff2000084c5b34>] jffs2_write_inode_range+0x13c/0x450
[ 393.892150] [<ffff2000084be0b8>] jffs2_write_end+0x2a8/0x4a0
[ 393.897811] [<ffff2000081f3008>] generic_perform_write+0x1c0/0x280
[ 393.903990] [<ffff2000081f5074>] __generic_file_write_iter+0x1c4/0x228
[ 393.910517] [<ffff2000081f5210>] generic_file_write_iter+0x138/0x288
[ 393.916870] [<ffff20000829ec1c>] __vfs_write+0x1b4/0x238
[ 393.922181] [<ffff20000829ff00>] vfs_write+0xd0/0x238
[ 393.927232] [<ffff2000082a1ba8>] SyS_write+0xa0/0x110
[ 393.932283] [<ffff20000808429c>] __sys_trace_return+0x0/0x4
[ 393.937851] Object at ffff800062e3b280, in cache kmalloc-64 size: 64
[ 393.944197] Allocated:
[ 393.946552] PID = 2918
[ 393.948913] save_stack_trace_tsk+0x0/0x220
[ 393.953096] save_stack_trace+0x18/0x20
[ 393.956932] kasan_kmalloc+0xd8/0x188
[ 393.960594] __kmalloc+0x144/0x238
[ 393.963994] jffs2_selected_compress+0x48/0x2a0
[ 393.968524] jffs2_compress+0x58/0x478
[ 393.972273] jffs2_write_inode_range+0x13c/0x450
[ 393.976889] jffs2_write_end+0x2a8/0x4a0
[ 393.980810] generic_perform_write+0x1c0/0x280
[ 393.985251] __generic_file_write_iter+0x1c4/0x228
[ 393.990040] generic_file_write_iter+0x138/0x288
[ 393.994655] __vfs_write+0x1b4/0x238
[ 393.998228] vfs_write+0xd0/0x238
[ 394.001543] SyS_write+0xa0/0x110
[ 394.004856] __sys_trace_return+0x0/0x4
[ 394.008684] Freed:
[ 394.010691] PID = 2918
[ 394.013051] save_stack_trace_tsk+0x0/0x220
[ 394.017233] save_stack_trace+0x18/0x20
[ 394.021069] kasan_slab_free+0x88/0x188
[ 394.024902] kfree+0x6c/0x1d8
[ 394.027868] jffs2_sum_write_sumnode+0x2c4/0x880
[ 394.032486] jffs2_do_reserve_space+0x198/0x598
[ 394.037016] jffs2_reserve_space+0x3f8/0x4d8
[ 394.041286] jffs2_write_inode_range+0xf0/0x450
[ 394.045816] jffs2_write_end+0x2a8/0x4a0
[ 394.049737] generic_perform_write+0x1c0/0x280
[ 394.054179] __generic_file_write_iter+0x1c4/0x228
[ 394.058968] generic_file_write_iter+0x138/0x288
[ 394.063583] __vfs_write+0x1b4/0x238
[ 394.067157] vfs_write+0xd0/0x238
[ 394.070470] SyS_write+0xa0/0x110
[ 394.073783] __sys_trace_return+0x0/0x4
[ 394.077612] Memory state around the buggy address:
[ 394.082404] ffff800062e3b180: 00 00 00 00 00 00 00 00 fc fc fc fc fc fc fc fc
[ 394.089623] ffff800062e3b200: 00 00 00 00 00 00 00 00 fc fc fc fc fc fc fc fc
[ 394.096842] >ffff800062e3b280: 01 fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
[ 394.104056] ^
[ 394.107283] ffff800062e3b300: fb fb fb fb fb fb fb fb fc fc fc fc fc fc fc fc
[ 394.114502] ffff800062e3b380: fb fb fb fb fb fb fb fb fc fc fc fc fc fc fc fc
[ 394.121718] ==================================================================
Signed-off-by: Yang Yang <yang.yang29@zte.com.cn>
Extend some inode methods with an additional user namespace argument. A
filesystem that is aware of idmapped mounts will receive the user
namespace the mount has been marked with. This can be used for
additional permission checking and also to enable filesystems to
translate between uids and gids if they need to. We have implemented all
relevant helpers in earlier patches.
As requested we simply extend the exisiting inode method instead of
introducing new ones. This is a little more code churn but it's mostly
mechanical and doesnt't leave us with additional inode methods.
Link: https://lore.kernel.org/r/20210121131959.646623-25-christian.brauner@ubuntu.com
Cc: Christoph Hellwig <hch@lst.de>
Cc: David Howells <dhowells@redhat.com>
Cc: Al Viro <viro@zeniv.linux.org.uk>
Cc: linux-fsdevel@vger.kernel.org
Signed-off-by: Christian Brauner <christian.brauner@ubuntu.com>
The macro use will already have a semicolon.
Signed-off-by: Tom Rix <trix@redhat.com>
Set rp_size to zero will be ignore during remounting.
The method to identify whether we input a remounting option of
rp_size is to check if the rp_size input is zero. It can not work
well if we pass "rp_size=0".
This patch add a bool variable "set_rp_size" to fix this problem.
Reported-by: Jubin Zhong <zhongjubin@huawei.com>
The log of this problem is:
jffs2: Error garbage collecting node at 0x***!
jffs2: No space for garbage collection. Aborting GC thread
This is because GC believe that it do nothing, so it abort.
After going over the image of jffs2, I find a scene that
can trigger this problem stably.
The scene is: there is a normal dirent node at summary-area,
but abnormal at corresponding not-summary-area with error
name_crc.
The reason that GC exit abnormally is because it find that
abnormal dirent node to GC, but when it goes to function
jffs2_add_fd_to_list, it cannot meet the condition listed
below:
if ((*prev)->nhash == new->nhash && !strcmp((*prev)->name, new->name))
So no node is marked obsolete, statistical information of
erase_block do not change, which cause GC exit abnormally.
The root cause of this problem is: we do not check the
name_crc of the abnormal dirent node with summary is enabled.
Noticed that in function jffs2_scan_dirent_node, we use
function jffs2_scan_dirty_space to deal with the dirent
node with error name_crc. So this patch add a checking
code in function read_direntry to ensure the correctness
of dirent node. If checked failed, the dirent node will
be marked obsolete so GC will pass this node and this
problem will be fixed.
Cc: <stable@vger.kernel.org>
Signed-off-by: Zhe Li <lizhe67@huawei.com>
When debug (print) macros are not enabled, change them to use the
no_printk() macro instead of <nothing>. This fixes gcc warnings when
-Wextra is used:
../cpukit/libfs/src/jffs2/src/nodelist.c:255:37: warning: suggest braces around empty body in an ‘else’ statement [-Wempty-body]
../cpukit/libfs/src/jffs2/src/nodelist.c:278:38: warning: suggest braces around empty body in an ‘else’ statement [-Wempty-body]
../cpukit/libfs/src/jffs2/src/nodelist.c:558:52: warning: suggest braces around empty body in an ‘else’ statement [-Wempty-body]
../cpukit/libfs/src/jffs2/src/xattr.c:1247:58: warning: suggest braces around empty body in an ‘if’ statement [-Wempty-body]
../cpukit/libfs/src/jffs2/src/xattr.c:1281:65: warning: suggest braces around empty body in an ‘if’ statement [-Wempty-body]
Builds without warnings on all 3 levels of CONFIG_JFFS2_FS_DEBUG.
Signed-off-by: Randy Dunlap <rdunlap@infradead.org>
Cc: David Woodhouse <dwmw2@infradead.org>
Cc: Richard Weinberger <richard@nod.at>
Cc: linux-mtd@lists.infradead.org
A follow up patch uses no_printk().
Low-end configurations may want to have the HTIF support removed.
Enable the option by default. Fix formatting. Fix node validity
checks.
Updates #4779.
Xilinx's upstream ILP32 xil_cache.h header is out of date and broken.
This provides a copy of the LP64 header in place of the ILP32 header
since the LP64 header includes all the correct types to work with either
data model.
The address of the nandpsu peripheral is specific to the ZynqMP SoC and
not relevant to other devices that might have one or more instances of
this peripheral.
Close #4759.
Closes #4751
--0000000000006acec205efd38cd6
Content-Type: text/plain; charset="UTF-8"
Closes #4556
This adds Xilinx's driver for the Xilinx NAND controller embedded in the
ZynqMP SoC. Within that device alone, it is possible to access this
peripheral from MicroBlaze, ARMv7, and ARMv8 cores. This has been added
to the hardware ZynqMP BSPs since QEMU does not support emulation of
this peripheral. This driver supports polled operation only. The
imported files are and should be able to remain unmodified. Import
information is kept in bsps/shared/dev/nand/VERSION.
This support code is necessary for many Xilinx-provided bare metal device
drivers supported on ARM, AArch64, and MicroBlaze platforms. Support for
all of these architectures is kept under bsps/include due to multiple
architecture variants being supported which requires complex logic in
the build system. The imported files are and should be able to remain
unmodified. Import information is kept in bsps/shared/xil/VERSION.
