* | 2005-11-31 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-12-31 | 3 | -1/+10 |
| | | | | | | PR 851/bsps * aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add gen5200 BSP family. | ||||
* | Misc. fixes. | Ralf Corsepius | 2005-12-31 | 1 | -8/+9 |
* | 2005-12-31 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-12-31 | 1 | -0/+2 |
| | | | | | * irq/irq.c, irq/irq_init.c, vectors/vectors_init.c: include <libcpu/raw_exceptions.h>. | ||||
* | include <libcpu/raw_exceptions.h>. | Ralf Corsepius | 2005-12-31 | 3 | -5/+12 |
* | 2005-12-31 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-12-31 | 1 | -0/+5 |
| | | | | | * include/raw_exception.h, vectors/raw_exception.c: Remove. Use implementation from libcpu instead. | ||||
* | Remove. Use implementation from libcpu instead. | Ralf Corsepius | 2005-12-31 | 2 | -451/+0 |
* | 2005-12-31 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-12-31 | 2 | -1/+7 |
| | | | | | PR 851/bsps * mpc6xx/exceptions/raw_exception.c: Add PPC_603le. | ||||
* | 2005-11-31 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-12-31 | 1 | -0/+4 |
| | | | | * mpc6xx/exceptions/raw_exception.c: Cosmetics. | ||||
* | Cosmetics. | Ralf Corsepius | 2005-12-31 | 1 | -9/+9 |
* | Misc include file fixes. | Ralf Corsepius | 2005-12-31 | 20 | -42/+98 |
* | 2005-12-31 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-12-31 | 1 | -0/+9 |
| | | | | | | | | | * bestcomm/bestcomm_glue.c, clock/clock.c, console/console.c, i2c/i2c.c, i2c/i2cdrv.c, ide/idecfg.c, ide/pcmcia_ide.c, ide/pcmcia_ide.h, include/i2c.h, irq/irq.c, irq/irq_init.c, mscan/mscan.c, network_5200/network.c, nvram/nvram.c, nvram/nvram.h, slicetimer/slicetimer.c, startup/bspstart.c, startup/cpuinit.c, tod/todcfg.c, vectors/vectors_init.c: Misc include file fixes. | ||||
* | Regenerate. | Ralf Corsepius | 2005-12-31 | 1 | -143/+55 |
* | Add bspopts.h.in | Ralf Corsepius | 2005-12-31 | 1 | -0/+1 |
* | New (CVS import Thomas Doerfler <Thomas.Doerfler@embedded-brains.de>'s | Ralf Corsepius | 2005-12-31 | 82 | -0/+23211 |
| | | | | submission). | ||||
* | Add BuildRoot. | Ralf Corsepius | 2005-12-29 | 4 | -1/+5 |
* | 2005-12-29 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-12-29 | 1 | -0/+3 |
| | | | | | * gdb/gdb.add, rtems/rtems.add, rtemsdoc/rtemsdoc.add: Add BuildRoot. | ||||
* | 2005-12-29 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-12-29 | 1 | -1/+3 |
| | | | | | * cpukit/rtems-cpukit: Add BuildRoot. * gccnewlib/gccnewlib.add: Add BuildRoot. | ||||
* | Add BuildRoot: | Ralf Corsepius | 2005-12-29 | 1 | -0/+1 |
* | 2005-12-29 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-12-29 | 1 | -0/+2 |
| | | | | | * binutils/binutils.add: Remove BuildRoot. Don't build infos for prefix==/usr. | ||||
* | Remove BuildRoot. Don't build infos for prefix==/usr. | Ralf Corsepius | 2005-12-29 | 1 | -4/+12 |
* | 2005-12-29 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-12-29 | 1 | -0/+1 |
| | | | | * common/common.add.in: Remove BuildRoot. | ||||
* | Remove BuildRoot. | Ralf Corsepius | 2005-12-29 | 1 | -3/+0 |
* | 2005-12-29 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-12-29 | 1 | -0/+5 |
| | | | | | * autotools/autoconf.add, autotools/automake.add: Add BuildRoot. Remove Packager. | ||||
* | Add BuildRoot. Remove Packager. | Ralf Corsepius | 2005-12-29 | 2 | -5/+4 |
* | Cosmetics. | Ralf Corsepius | 2005-12-22 | 1 | -7/+18 |
* | Cosmetics to make rpmlint happy. | Ralf Corsepius | 2005-12-22 | 6 | -6/+6 |
* | Cosmetics. | Ralf Corsepius | 2005-12-21 | 10 | -18/+20 |
* | Drop Epoch:, Packager:. | Ralf Corsepius | 2005-12-21 | 1 | -2/+0 |
* | 2005-12-21 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-12-21 | 2 | -11/+17 |
| | | | | * gdb/gdb.add: Add URL:. | ||||
* | Add another 'extended BSP' routine which returns reboot status register ↵ | Eric Norum | 2005-12-19 | 2 | -0/+42 |
| | | | | information | ||||
* | 2005-12-19 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-12-19 | 1 | -0/+7 |
| | | | | | | | * binutils/binutils.add: Add URL:. * gccnewlib/gccnewlib.add: Add URL:. Use Source50/Patch50 for newlib. * gccnewlib/mkspec.in: Use Source50/Patch50 for newlib. | ||||
* | Use Source50/Patch50 for newlib. | Ralf Corsepius | 2005-12-19 | 1 | -3/+3 |
* | Add URL:. | Ralf Corsepius | 2005-12-19 | 1 | -10/+12 |
* | Add URL:. | Ralf Corsepius | 2005-12-19 | 1 | -0/+1 |
* | Cosmetics | Ralf Corsepius | 2005-12-19 | 9 | -2/+10 |
* | Cosmetics. | Ralf Corsepius | 2005-12-19 | 3 | -10/+13 |
* | Add __os_install_post. | Ralf Corsepius | 2005-12-18 | 4 | -0/+12 |
* | Remove __os_install_post. | Ralf Corsepius | 2005-12-18 | 1 | -3/+0 |
* | 2005-12-18 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-12-18 | 1 | -0/+6 |
| | | | | | | * common/common.add.in: Remove __os_install_post. * cpukit/rtems-cpukit.add, gdb/gdb.add, rtems/rtems.add, rtemsdoc/rtemsdoc.add: Add __os_install_post. | ||||
* | Remove Packager: | Ralf Corsepius | 2005-12-18 | 1 | -1/+0 |
* | This commit was generated by cvs2svn to compensate for changes in r12921, | Ralf Corsepius | 2005-12-11 | 1 | -0/+404 |
|\ | | | | | which included commits to RCS files with non-trunk default branches. | ||||
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2005-12-11 | 1 | -0/+404 |
* | | 2005-12-09 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2005-12-09 | 1 | -1/+1 |
| | | | | | | | | * ChangeLog: fixed wrong date of last ChangeLog entry. | ||||
* | | 2005-11-02 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2005-12-09 | 2 | -1/+7 |
| | | | | | | | | | | | | PR 849/networking * librpc/src/rpc/rtems_portmapper.c: Increased stack size by ARGSIZE to prevent overrun. | ||||
* | | 2005-12-02 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2005-12-02 | 4 | -0/+63 |
| | | | | | | | | | | | | | | | | | | * shared/irq/irq_init.c, shared/openpic/openpic.h shared/openpic/openpic.c: The 8240's EPIC has a 'serial' mode of operation for multiplexing 16 interrupt lines. This introduces a pipeline delay which can cause spurious interrupts unless ending the interrupt cycle (EOI) is delayed accordingly. | ||||
* | | 2005-12-01 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2005-12-02 | 4 | -26/+72 |
| | | | | | | | | | | | | | | | | | | * shared/vectors/vectors.h, shared/vectors/vectors.S, shared/vectors/vectors_init.c: Reduced size of default prologue (some exceptions, e.g., altivec unavail.) are only 0x20 bytes apart. Also introduced a modified prologue that switches r0..r3 shadowing off (r0..r3 undefined on certain 603e variants when incurring a TLB miss). | ||||
* | | 2005-11-29 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2005-11-30 | 3 | -0/+9 |
| | | | | | | | | | | | | * shared/irq/irq_asm.S, shared/vectors/vectors.S: Clear CR[6] before invoking high-level handler to make sure no varargs fn callee assumes there are FP arguments. | ||||
* | | 2005-11-29 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2005-11-30 | 2 | -0/+5 |
| | | | | | | | | | | * shared/irq/irq.c: Fixed incorrect removal of first shared interrupt in chain. | ||||
* | | - trivial correction in comment | Till Straumann | 2005-11-29 | 1 | -1/+1 |
* | | Fixed format. | Joel Sherrill | 2005-11-22 | 1 | -4/+4 |
