* | Include missing <rtems/score/threaddispatch.h> | Sebastian Huber | 2013-07-26 | 27 | -59/+44 |
* | score: Include missing <rtems/score/thread.h> | Sebastian Huber | 2013-07-26 | 2 | -0/+2 |
* | score: Move mppkt implementation into mpciimpl.h | Sebastian Huber | 2013-07-26 | 5 | -84/+24 |
* | score: Create mpci implementation header | Sebastian Huber | 2013-07-26 | 51 | -502/+388 |
| | | | | | Move implementation specific parts of mpci.h into new header file mpciimpl.h. The mpci.h contains now only the application visible API. | ||||
* | rtems: Create signal implementation header | Sebastian Huber | 2013-07-26 | 9 | -52/+79 |
| | | | | | | Move implementation specific parts of signal.h into new header file signalimpl.h. The signal.h contains now only the application visible API. | ||||
* | score: Merge objectmp implementation into one file | Sebastian Huber | 2013-07-26 | 4 | -85/+44 |
* | rtems: Fix partition includes | Sebastian Huber | 2013-07-26 | 2 | -12/+5 |
* | rtems: Use proper header guard | Sebastian Huber | 2013-07-26 | 1 | -2/+2 |
* | score: Create threadq implementation header | Sebastian Huber | 2013-07-26 | 103 | -719/+570 |
| | | | | | | | | Move implementation specific parts of tqdata.h, threadq.h and threadq.inl into new header file threadqimpl.h. The threadq.h contains now only the application visible API. Delete tqdata.h. | ||||
* | score: Delete threadq.inl | Sebastian Huber | 2013-07-26 | 4 | -56/+11 |
* | score: Merge threadmp implementation into one file | Sebastian Huber | 2013-07-26 | 4 | -78/+35 |
* | score: Create states implementation header | Sebastian Huber | 2013-07-26 | 113 | -267/+144 |
| | | | | | | Move implementation specific parts of states.h and states.inl into new header file statesimpl.h. The states.h contains now only the application visible API. | ||||
* | score: Create thread implementation header | Sebastian Huber | 2013-07-26 | 113 | -1220/+873 |
| | | | | | | | | Move implementation specific parts of thread.h and thread.inl into new header file threadimpl.h. The thread.h contains now only the application visible API. Remove superfluous header file includes from various files. | ||||
* | score: Create prioritybitmap implementation header | Sebastian Huber | 2013-07-26 | 9 | -201/+140 |
| | | | | | | | | Move implementation specific parts of prioritybitmap.h and prioritybitmap.inl into new header file prioritybitmapimpl.h. The prioritybitmap.h contains now only the application visible API. Move content of bitfield.h into prioritybitmapimpl.h. | ||||
* | score: Create scheduler implementation header | Sebastian Huber | 2013-07-26 | 28 | -172/+78 |
| | | | | | | Move implementation specific parts of scheduler.h and scheduler.inl into new header file schedulerimpl.h. The scheduler.h contains now only the application visible API. | ||||
* | score: Create schedulerpriority impl header | Sebastian Huber | 2013-07-26 | 24 | -100/+45 |
| | | | | | | | | | | | | | Move implementation specific parts of schedulerpriority.h and schedulerpriority.inl into new header file schedulerpriorityimpl.h. The schedulerpriority.h contains now only the application visible API. Add missing includes. Remove superfluous includes. Move declaration of _Priority_Bit_map to prioritybitmap.inl since this variable is used only here. Remove second declaration of _Priority_Major_bit_map. | ||||
* | score: Create schedulersimple impl header | Sebastian Huber | 2013-07-26 | 8 | -36/+27 |
| | | | | | | Move implementation specific parts of schedulersimple.h and schedulersimple.inl into new header file schedulersimpleimpl.h. The schedulersimple.h contains now only the application visible API. | ||||
* | libtests/malloc04: Fixes for RTEMS_DEBUG | Sebastian Huber | 2013-07-26 | 2 | -17/+17 |
* | conf.t: Fix minor typos. | Joel Sherrill | 2013-07-24 | 1 | -2/+2 |
* | readdir_r(): Add restrict keyword per Single UNIX Specification | Sahil Patnayakunii | 2013-07-24 | 1 | -1/+5 |
* | POSIX Semaphore: Add restrict keyword per Single UNIX Specification | Sahil Patnayakunii | 2013-07-24 | 3 | -8/+8 |
* | POSIX AIO: Add restrict keyword per Single UNIX Specification | Sahil Patnayakunii | 2013-07-24 | 2 | -8/+9 |
* | POSIX mqueue.h: Add restrict keyword per Single UNIX Specification | Sahil Patnayakunii | 2013-07-24 | 3 | -10/+10 |
* | doc/user/conf.t: Fix SMP_MAXIMUM_PROCESSORS and add Go configuration | Cynthia Rempel | 2013-07-24 | 1 | -1/+93 |
* | bsp/mpc55xx: Fix prototype | Peter Dufault | 2013-07-24 | 1 | -1/+1 |
* | score: Move _Heap_Area_overhead() definition. | Sebastian Huber | 2013-07-24 | 2 | -31/+31 |
| | | | | This function is used in bootcard.h. | ||||
* | score: Include <rtems/score/cpu.h> | Sebastian Huber | 2013-07-24 | 1 | -1/+1 |
| | | | | This file uses CPU_ALIGNMENT. | ||||
* | score: Add freechain | Zhongwei Yao | 2013-07-24 | 10 | -0/+419 |
* | score: Delete priority.inl | Sebastian Huber | 2013-07-24 | 4 | -62/+0 |
* | score: Merge sysstate API into one file | Sebastian Huber | 2013-07-24 | 103 | -184/+99 |
* | libtests/malloctest: Fixes for RTEMS_DEBUG | Sebastian Huber | 2013-07-24 | 2 | -5/+36 |
* | bsp/lpc32xx: Fix memory map for GPIO registers | Sebastian Huber | 2013-07-24 | 1 | -0/+2 |
* | score: Create stack implementation header | Sebastian Huber | 2013-07-23 | 13 | -29/+38 |
| | | | | | | Move implementation specific parts of stack.h and stack.inl into new header file stackimpl.h. The stack.h contains now only the application visible API. | ||||
* | posix: Include missing <stdint.h> | Sebastian Huber | 2013-07-23 | 1 | -0/+2 |
* | score: Create heap implementation header | Sebastian Huber | 2013-07-23 | 25 | -642/+643 |
| | | | | | | Move implementation specific parts of heap.h and heap.inl into new header file heapimpl.h. The heap.h contains now only the application visible API. | ||||
* | score: Include missing <rtems/score/thread.h> | Sebastian Huber | 2013-07-23 | 1 | -0/+1 |
* | score: PR1782: CPU_USE_DEFERRED_FP_SWITCH | Sebastian Huber | 2013-07-23 | 4 | -11/+14 |
| | | | | Do not redefine CPU_USE_DEFERRED_FP_SWITCH. | ||||
* | score: Include missing <rtems/score/address.h> | Sebastian Huber | 2013-07-23 | 2 | -0/+2 |
* | score: Merge wkspace API into one file | Sebastian Huber | 2013-07-23 | 5 | -62/+17 |
* | score: Merge address API into one file | Sebastian Huber | 2013-07-23 | 4 | -202/+160 |
* | rtems: Include missing header | Sebastian Huber | 2013-07-23 | 1 | -1/+2 |
* | rtems: Create tasks implementation header | Sebastian Huber | 2013-07-23 | 36 | -201/+216 |
| | | | | | | Move implementation specific parts of tasks.h and tasks.inl into new header file tasksimpl.h. The tasks.h contains now only the application visible API. | ||||
* | rtems: Create region implementation header | Sebastian Huber | 2013-07-23 | 23 | -118/+119 |
| | | | | | | Move implementation specific parts of region.h and region.inl into new header file regionimpl.h. The region.h contains now only the application visible API. | ||||
* | rtems: Include <rtems/debug.h> in <rtems.h> | Sebastian Huber | 2013-07-23 | 1 | -0/+1 |
| | | | | This header file is included indirectly via <rtems/rtems/region.h>. | ||||
* | rtems: Create part implementation header | Sebastian Huber | 2013-07-23 | 17 | -69/+75 |
| | | | | | | Move implementation specific parts of part.h and part.inl into new header file partimpl.h. The part.h contains now only the application visible API. | ||||
* | rtems: Create timer implementation header | Sebastian Huber | 2013-07-23 | 24 | -267/+272 |
| | | | | | | Move implementation specific parts of timer.h and timer.inl into new header file timerimpl.h. The timer.h contains now only the application visible API. | ||||
* | rtems: Create ratemon implementation header | Sebastian Huber | 2013-07-23 | 22 | -312/+313 |
| | | | | | | Move implementation specific parts of ratemon.h and ratemon.inl into new header file ratemonimpl.h. The ratemon.h contains now only the application visible API. | ||||
* | score: Include <string.h> in basedefs.h | Sebastian Huber | 2013-07-23 | 1 | -0/+7 |
* | Include missing <string.h> | Sebastian Huber | 2013-07-23 | 44 | -2/+50 |
* | rtems: Create dpmem implementation header | Sebastian Huber | 2013-07-23 | 14 | -61/+57 |
| | | | | | | Move implementation specific parts of dpmem.h and dpmem.inl into new header file dpmemimpl.h. The dpmem.h contains now only the application visible API. |
