* custom/leon3.cfg, custom/leon2.cfg, custom/sis.cfg,
custom/erc32.cfg:
Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* make/custom/leon3.cfg: New (relocated from /make/custom).
* make/custom/leon2.cfg: New (relocated from /make/custom).
* make/custom/erc32.cfg: New (relocated from /make/custom).
* make/custom/sis.cfg: New (relocated from /make/custom).
* custom/avrtest.cfg:
* make/custom/avrtest.cfg: New (relocated from /make/custom).
* custom/i386ex.cfg, custom/pc486.cfg, custom/ts_386ex.cfg,
custom/pc386.cfg, custom/pc586.cfg, custom/pc386dx.cfg,
custom/pc686.cfg:
* make/custom/ts_386ex.cfg: New (relocated from /make/custom).
* make/custom/pc386.cfg: New (relocated from /make/custom).
* make/custom/pc386dx.cfg: New (relocated from /make/custom).
* make/custom/pc486.cfg: New (relocated from /make/custom).
* make/custom/pc586.cfg: New (relocated from /make/custom).
* make/custom/pc686.cfg: New (relocated from /make/custom).
* make/custom/i386ex.cfg: New (relocated from /make/custom).
* custom/gensh1.cfg, custom/gensh2.cfg, custom/gensh4.cfg,
custom/simsh1.cfg, custom/simsh2.cfg, custom/simsh2e.cfg,
custom/simsh4.cfg:
* make/custom/simsh1.cfg: New (relocated from /make/custom).
* make/custom/simsh2.cfg: New (relocated from /make/custom).
* make/custom/simsh2e.cfg: New (relocated from /make/custom).
* make/custom/simsh4.cfg: New (relocated from /make/custom).
* make/custom/gensh4.cfg: New (relocated from /make/custom).
* make/custom/gensh2.cfg: New (relocated from /make/custom).
* make/custom/gensh1.cfg: New (relocated from /make/custom).
* aclocal/check-custom-bsp.m4: Let _RTEMS_CHECK_CUSTOM_BSP look for
*.cfg into c/src/lib/libbsp/<cpu>/<bsp_family>/make/custom.
* sp32/init.c: Lengthen the clock tick and move configuration to the
bottom of the file.
* psxtimer01/psxtimer.c: It is not necessarily an error for the time
remaining to not equal the period.
* tmck/task1.c: Ignore numbers that are too large but keep going -- do
not abort.
* unlimited/test1.c: Spacing.
* libcsupport/src/no_libc.c: Remove.
* libcsupport/Makefile.am: Remove no_libc.c.
* libcsupport/src/newlibc_reent.c: Eliminate RTEMS_UNIX.
* libcsupport/src/newlibc_exit.c: Eliminate RTEMS_UNIX.
* libcsupport/src/base_fs.c: Eliminate RTEMS_UNIX.
* libcsupport/src/stat.c: Eliminate RTEMS_UNIX.
* libmisc/monitor/mon-editor.c: Eliminate RTEMS_UNIX.
* libcsupport/include/rtems/libcsupport.h: Remove RTEMS_UNIX, hpux.
Fix extern "C" {}.
* libfs/src/imfs/ioman.c: Remove RTEMS_UNIX, __linux__.
* score/src/threadhandler.c: Remove comment mentioning unix port.
* bsp_howto/console.t: Capitalization.
* user/preface.texi: Remove UNIX and update port list.
* wrapup/Makefile.am: Remove UNIX.
* configure.ac: Remove UNIX AM_CONDITIONAL.
* libfs/Makefile.am: Unconditionally build src/pipe/fifo.c
src/pipe/pipe.c src/pipe/pipe.h.
* libblock/Makefile.am: Unconditionall build libblock.
* Makefile.am: Unconditional build libblock.
* libfs/src/imfs/imfs_unixstub.c, libfs/src/devfs/devfs_unixstub.c:
Remove (unused).
* libfs/Makefile.am: Remove libfs/src/imfs/imfs_unixstub.c,
libfs/src/devfs/devfs_unixstub.c.
* libcsupport/src/unixlibc.c, libcsupport/src/unixlibc_io.c,
libcsupport/src/hosterr.c: Remove (unused).
* libcsupport/Makefile.am: Remove libcsupport/src/unixlibc.c,
libcsupport/src/unixlibc_io.c, libcsupport/src/hosterr.c.
* aclocal/canonical-target-name.m4, aclocal/check-networking.m4,
aclocal/check-posix.m4, aclocal/enable-posix.m4,
aclocal/rtems-cpu-subdirs.m4: Remove posix/unix.
* HELP.html, bsp_howto/support.t, relnotes/status.texi,
started_ada/buildada.t: Remove references to posix/Unix port.
* tmck/task1.c: Remove support for "unix".
* aclocal/sysv-ipc.m4: Remove (unused).
* configure.ac: Remove RTEMS_UNIX, RTEMS_UNIXLIB.
