and RTEMS_ID_NONE. No object can have this ID.
* libnetworking/netinet/ip_output.c: when fragmenting
multicast packets M_MCAST must be set on all fragments.
This was fixed in FreeBSD ip_output.c 1.82 on 1998/8/23 !
(see my email to rtems-users from 2008/5/15).
* vmeUniverse/VME.h: removed 'weak' attribute from
declaration of BSP_vme_config().
* shared/startup/pretaskinghook.c: removed declaration
of BSP_vme_config() (which is already declared in
<bsp/VME.h>. Removed test for NULL-ness of BSP_vme_config;
gcc doesn't seem to understand that the linker may
define this to be NULL... Silences a compiler warning
(and users can always provide an empty routine).
* shared/comm/tty_drv.c: Eliminate copies of switches to convert
termios Bxxx constants to xxx as an integer. Use the shared
termios_baud_to_number() routine to do the same conversion.
* console/console.c: Eliminate copies of switches to convert termios
* console/console.c, console/serial_mouse.c: Eliminate copies of
switches to convert termios Bxxx constants to xxx as an integer. Use
the shared termios_baud_to_number() routine to do the same
conversion.
* console/m340uart.c: Eliminate copies of switches to convert termios
* shared/comm/console.c: Eliminate copies of switches to convert
* ppc403/tty_drv/tty_drv.c, ppc403/console/console405.c:
../ictrl/ictrl.h has gone; include ../irq/ictrl.h
* shared/startup/linkcmds, shared/startup/zerobss.c:
introduced '__bss_end'; assuming that __rtems_end
coincides with the end of .bss for the purpose of
zeroing .bss is very dangerous.
* vmeUniverse/vmeUniverse.c: fixed compiler warning;
moved struct attributes as directed by gcc warning.
* shared/console/console.c: Fix typo.
* itron/include/rtems/itron/task.h, itron/src/del_tsk.c,
itron/src/exd_tsk.c, itron/src/task.c,
posix/include/rtems/posix/threadsup.h, posix/src/cancel.c,
posix/src/cancelrun.c, posix/src/pthread.c, posix/src/pthreadexit.c,
posix/src/setcancelstate.c, posix/src/setcanceltype.c,
posix/src/testcancel.c, rtems/src/taskdelete.c,
score/inline/rtems/score/object.inl, score/src/objectclose.c,
score/src/threadclose.c: Make all task delete/exit/cancel routines
follow the same critical section pattern. Also ensure that POSIX
cancelation routines are run at thread exit.
* libcsupport/src/termios_baud2index.c,
libcsupport/src/termios_baud2num.c,
libcsupport/src/termios_num2baud.c,
libcsupport/src/termios_setinitialbaud.c: New files.
* shared/console/console.c: Remove explicit switch and call
termios_baud_to_number().
* console/console.c: Remove explicit switch and call
* console/mc68360_scc.c: Remove explicit switch and call
* libchip/Makefile.am: Move termios helper routines from libchip to
libcsupport. Add routine which makes it easy for a termios device
driver to inform termios of its default baud rate. This avoids
inconsistencies in later termios settings changes.
* libchip/serial/termios_baud2index.c,
libchip/serial/termios_baud2num.c: Removed.
* libcsupport/Makefile.am, libcsupport/preinstall.am,
libcsupport/include/rtems/termiostypes.h: Move termios helper
routines from libchip to libcsupport. Add routine which makes it easy
for a termios device driver to inform termios of its default baud
rate. This avoids inconsistencies in later termios settings changes.
* console/console.c: Properly inform termios of our initial baud rate.
If it is not the default, this causes problems when an application
changes any termios attributes since termios thinks our baud rate is
one thing when in fact, it is another.
* libcsupport/include/rtems/watchdogdrv.h: Finish writing comments.
* user/conf.t: Add baseline interface for Watchdog Driver.
* libcsupport/preinstall.am, sapi/include/confdefs.h: Add baseline
* libcsupport/include/rtems/watchdogdrv.h: New file.
* itronhello/system.h, itronmbox01/system.h, itrontask02/system.h,
itrontime01/system.h: Add use of
CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER.
* Makefile.am, configure.ac, startup/start.c: Use new framework
capability where RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION.
* custom/nds.cfg: Email from author says to drop this flag.
* leaf.cfg: Do not override bsp-post-link.
* score/src/threadchangepriority.c: Just in case the transient
state was set when we entered, ensure that it is still set when
we exit.
* score/src/threadclose.c: When a thread is being deleted, it should
go into the dormant state -- not the transient state.
* mpc83xx/include/mpc83xx.h: or is not a good name for any name in
C/C++. See iso646.h for the reason.
* preinstall.am, console/console-io.c: Install cplb.h and use it.
* Makefile.am: Remove stray line.
* psxstat/psxstat.scn, psxstat/test.c: Eliminate patterns that look
like CVS conflict markers.
* network/network.c: Eliminate patterns that look like CVS conflict
markers.
* aclocal/bsp-bootcards-handles-ram-allocation.m4: New file.
* wrapup/Makefile.am: Many BSPs do not include any .rel files now so do
not fail if there are none.
* bootcard.c: Add capability for bootcard.c BSP Initialization
Framework to ask the BSP where it has memory for the RTEMS Workspace
and C Program Heap. These collectively are referred to as work area.
If the BSP supports this, then it does not have to include code to
split the available memory between the two areas. This reduces the
amount of code in the BSP specific bspstart.c file. Additionally, the
shared framework can initialize the C Library, call
rtems_debug_enable(), and dirty the work area memory. Until most/all
BSPs support this new capability, if the BSP supports this, it should
call RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION from its configure.ac.
When the transition is complete, this autoconf macro can be removed.
* bsppretaskinghook.c: New file.
* startup/bspstart.c: Add capability for bootcard.c BSP Initialization
* configure.ac, startup/bspstart.c: Add capability for bootcard.c BSP
Initialization Framework to ask the BSP where it has memory for the
RTEMS Workspace and C Program Heap. These collectively are referred
to as work area. If the BSP supports this, then it does not have to
include code to split the available memory between the two areas.
This reduces the amount of code in the BSP specific bspstart.c file.
Additionally, the shared framework can initialize the C Library, call
* shared/startup/pretaskinghook.c: Add capability for bootcard.c BSP
* Makefile.am, configure.ac, startup/bspstart.c: Add capability for
bootcard.c BSP Initialization Framework to ask the BSP where it has
memory for the RTEMS Workspace and C Program Heap. These collectively
are referred to as work area. If the BSP supports this, then it does
not have to include code to split the available memory between the
two areas. This reduces the amount of code in the BSP specific
bspstart.c file. Additionally, the shared framework can initialize
the C Library, call rtems_debug_enable(), and dirty the work area
memory. Until most/all BSPs support this new capability, if the BSP
supports this, it should call
RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION from its configure.ac. When
* startup/bspstart.c, startup/bspstart.c.nocache: Add capability for
