PR 576/doc
* FAQ/FAQ.texi, FAQ/Makefile.am: Remove embedded information as it was
out of date and frequently duplicated information available from
other public sources like the CrossGCC Wiki.
* FAQ/embeddedinfo.t: Removed.
PR 505/bsps
* setvec.c: Rework to remove punned pointer warning generated by gcc
3.3 and newer.
* include/buffer_test_io.h: Correct typo.
* startup/linkcmds: Add more memory and sections so tests can link.
This is a generic BSP for a CPU model so OK to do this.
* vectors/vectors.h, vectors/vectors_init.c: Undo previous change.
* irq/irq.h: Correct typo.
* Makefile.am: Correct typo.
* startup/linkcmds: Add more memory so tests can link. This is a
PR 570/bsps
* custom/mvme2307.cfg: Do not use -msdata=eabi since
it breaks the linking of the vectors.
* cpu_asm.S: Close window while restoring interrupted task state which
resulted in CWP corruption.
PR 584/RTEMS
* rtems/src/eventtimeout.c: Fix critical section window.
PR 583/tests
* tm26/task1.c, tm27/task1.c: Correctly reset
_Thread_Dispatch_disable_level so printing is safe.
PR 582/core
* posix/src/mqueue.c, posix/src/mqueuecreatesupp.c,
posix/src/mqueuedeletesupp.c, posix/src/mqueueunlink.c: Use memory
from workspace to avoid use of mutex during dispatch disable critical
section. Besides memory for object names should come from the
Workspace anyway.
PR 582/core
* psxmsgq01/init.c, psxmsgq01/psxmsgq01.scn: Fix the POSIX message
queue test so more of it runs now.
PR 580/tools
* setup.def: Fix setup.def to match current reality.
* gdb/base-gdb.add: Add annotate.info.
* gdb/gdb.add: Remove info/dir.
* README: New file.
* rtems-apt-conf.spec.in: Add @VERSION@ to Source0.
* Makefile.am, gpg/gpg-pubkey-eac29b6f-3fe1f458, ChangeLog,
vendors.list.d/rtems.list, sources.list.d/rtems-4.6.list,
sources.list.d/rtems-4.7.list, configure.ac, .cvsignore, COPYING,
rtems-apt-conf.spec.in, INSTALL: New.
* Makefile.am: Cosmetics.
* aclocal/rtems-top.m4: Sync with c/src/aclocal/rtems-top.m4
* Makefile.am, gdb/Makefile.am: Cosmetics.
* Makefile.am: Add EXTRA_DIST = search-id.sh multigen
cvsignore-add.sh.
* acinclude.m4: Fix loosing arguments when configuring cpukit and
testsuites (Was exposed with --enable-multilib, only).
Remove RTEMS_SUBCONFIGURE_ARGS_QUOTE. RTEMS_CONFIG_SUBDIR.
Add RTEMS_BSP_CONFIG_SUBDIR.
* configure.ac: Reflect changes to acinclude.m4. Reflect new args to
testsuites's configure.
* aclocal/rtems-top.m4: Remove ENDIF hack.
Rework and fix setting up PROJECT_TOPdir (PACKHEX wasn't found).
* libchip/Makefile.am, librdbg/Makefile.am, optman/Makefile.am,
wrapup/Makefile.am: Fix automake problems having been introduced
in previous patch.
* bootloader/Makefile.am: Fix preinstall dir handling.
* setup.def, gdb/gdb.add: gdb 6.0 RPMs built.
* ChangeLog: Replace RTEMS user account with Joel.
* bootloader/Makefile.am: Preinstall dirs.
* Makefile.am: Reflect changes to bsp.am.
Preinstall dist_project_lib*.
* Makefile.am: Don't install *.rels. Reflect changes to bsp.am.
* libchip/Makefile.am, librdbg/Makefile.am, optman/Makefile.am:
Preinstall dirs.
* wrapup/Makefile.am: Preinstall dirs. Cosmetics.
* aclocal/check-multiprocessing.m4: Cosmetics.
* aclocal/env-rtemsbsp.m4: Remove RTEMS_ROOT.
* aclocal/project-root.m4: Remove obsolete comments. Remove PACKHEX.
* Makefile.am: Preinstall dirs.
* bsp.am: Remove everything but CPPASCOMPILE.
* configure.ac: AC_CONFIG_SRCDIR([PROBLEMS]).
* aclocal/check-custom-bsp.m4: Sync with c/src/aclocal.
* aclocal/rtems-top.m4: Rework.
* setup.def, gdb/base-gdb.add, gdb/gdb.add: Building a gcc 3.2.3 i960
gcc and updating gdb to 5.3.
* mpc505/Makefile.am: Fix typo.
* Makefile.am: DIST_SUBDIRS = $(SUBDIRS).
Rework dist-hook.
* configure.ac: Reflect changes to RTEMS_ENABLE_RTEMSBSP.
* aclocal/enable-rtemsbsp.m4: Add support for --disable-rtemsbsp.
* configure.ac: Add support for --disable-rtemsbsp. Cosmetics.
* librdbg/Makefile.am: Merge-in librdbg/include/Makefile.am,
librdbg/src/Makefile.am.
* librdbg/include/Makefile.am, librdbg/src/Makefile.am: Remove.
Unconditionally apply RTEMS_CHECK_MULTIPROCESSING.
* Makefile.am: Add DIST_SUBDIRS = @BSP_SUBDIRS@.
* develenv/Makefile.am: Put *.texi into the builddir.
* bootloader/Makefile.am: Fix up paths having been broken in
previous patch.
* bsp.am: Add CPPASCOMPILE.
* started/tversions.texi: Remove (Bogus).
* aclocal/check-rdbg.m4: Don't AC_SUBST(HAS_RDBG).
* configure.ac: RTEMS_BUILD_CONFIG_SUBDIRS([testsuites/tools]).
* Makefile.am: DISTCLEANFILES += @CUSTOM_CFG_FILES.
* bootloader/Makefile.am: Remove references to $(top_srcdir).
Remove NM, LD. Cosmetics.
