* | Patch from Chris Johns <cjohns@cybertec.com.au> so the directory | Joel Sherrill | 2000-06-30 | 4 | -4/+4 |
| | | | | read function in the IMFS properly returns the inode number. | ||||
* | Patch from Chris Johns <cjohns@cybertec.com.au> to add support for | Joel Sherrill | 2000-06-30 | 8 | -52/+68 |
| | | | | | stat()'ing a symbolic link. This is needed to support the port of the BSD commands like ls to RTEMS. | ||||
* | Patch from Chris Johns <cjohns@cybertec.com.au> to add fchdir() | Joel Sherrill | 2000-06-30 | 8 | -2/+218 |
| | | | | functionality to libc and update TODO. | ||||
* | This is the initial addition of the port of RTEMS to the | Joel Sherrill | 2000-06-29 | 30 | -2/+4016 |
| | | | | | | | | | | | | | Hitachi H8 family. This port was done by Philip Quaife <philip@qs.co.nz> of Q Solutions and sponsored by Comnet Technologies Ltd. The port was done based on RTEMS 3.5.1 to a Hitach H8300H. The port was updated to RTEMS 4.5 style Makefiles/configure by Joel Sherrill <joel@OARcorp.com>. While doing this Joel added support for the h8300-rtems to binutils, gcc, newlib, and gdb. NOTE: Philip submitted a BSP for a Hitachi evaluation board which is being merged as a separate entity. | ||||
* | Using RPM names for versions now. | Joel Sherrill | 2000-06-29 | 1 | -6/+6 |
* | Added H8 as IEEE whether this is true or not. | Joel Sherrill | 2000-06-29 | 3 | -0/+3 |
* | Disabled #ident since the h8300-rtems binutils do not like the | Joel Sherrill | 2000-06-29 | 3 | -3/+3 |
| | | | | generated assembly from it. | ||||
* | Corrected prototype for xdrrec_endofrecord to match C body. | Joel Sherrill | 2000-06-29 | 3 | -3/+3 |
* | Added RTEMS_CPU_HAS_16_BIT_ADDRESSES constant to disable code | Joel Sherrill | 2000-06-29 | 4 | -0/+24 |
| | | | | | | | | that breaks when the target has 16 bit address space. One of the H8 multilibs is a 16-bit address space CPU. When a real attempt is made to support this CPU model, the code that assumes an address is 32 bits will have to change. This constant is probably not flagging all impacted code. | ||||
* | Corrected. | Joel Sherrill | 2000-06-29 | 1 | -7/+3 |
* | New file. | Joel Sherrill | 2000-06-29 | 3 | -0/+85 |
* | Switch to gcc patch 20000629 and revision level 8. This patch | Joel Sherrill | 2000-06-29 | 1 | -2/+2 |
| | | | | | | fixes: + the h8300-rtems and hppa1.1-rtems configure.in stanzas + config/rs6000/rtems.h start and end file specs | ||||
* | h8300-rtems now uses the correct command to generate the specs file. | Joel Sherrill | 2000-06-29 | 1 | -1/+1 |
* | Added initial h8300 support. | Joel Sherrill | 2000-06-29 | 5 | -8/+26 |
* | gdb 5.0 does not install readline so don't try to grab the info files. | Joel Sherrill | 2000-06-29 | 1 | -1/+2 |
* | Patch from Eric Valette to do some cleanup. | Joel Sherrill | 2000-06-29 | 3 | -9/+16 |
* | Patch from Chris Johns <cjohns@cybertec.com.au> to make sure the | Joel Sherrill | 2000-06-29 | 3 | -3/+6 |
| | | | | ttyHead back link is set. | ||||
* | Patch from Eric Valette <valette@crf.canon.fr> to make librdbg work | Joel Sherrill | 2000-06-29 | 1 | -8/+10 |
| | | | | with the new RPC code. | ||||
* | Patch rtems-rc-20000627-2 from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-06-29 | 4 | -17/+3 |
| | | | | | | | | | | | | that does some cleanup: * remove c/src/make/main.cfg.in (obsolete, unused) and any reference to it. * remove RTEMS_BSP_SPECS from c/src/make/custom/default.cfg.in (unused) Notes: All files being effected by this patch are only used when building RTEMS, therefore this patch should not have any side-effects outside of the source- rsp. build-tree. | ||||
* | Patch rtems-rc-20000627-1 from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-06-29 | 3 | -7/+73 |
| | | | | | | | | | | | | | | | | | | | | | that is part of the multilib/gnu-canonicalization movement: Changes: * New m4-macro: aclocal/multilib.am * Suppress multiprocessing if --enable-multilib is given to configure Notes: For now this patch only suppresses multiprocessing if --enable-multilib is given to configure and should not have any other side-effects, ie. it works around a minor issue which prevents introduction of multilibs in general. The RTEMS_ENABLE_MULTILIB_MASTER macro is the core part to build real multilibs, but can not be applied before other multilib related issues with RTEMS have been solved. (e.g. sptables.h, bsp_specs, Cygnus/Gnu canonicalization, _RTEMS_version, targopts.h, changing the installation point/tooldir support, etc.). | ||||
* | Removed as it was orphaned by previous patches. | Joel Sherrill | 2000-06-26 | 1 | -19/+0 |
* | Patch from Chris Johns <cjohns@cybertec.com.au> and | Joel Sherrill | 2000-06-26 | 4 | -0/+12 |
| | | | | | | | | | | | Jennifer Averett <jennifer.averett@oarcorp.com> to fix appends (O_APPEND at open time) on in-memory files. A call such as: fd = open (file, O_APPEND | O_WRONLY); did not append to the end of the file. | ||||
* | Patch from Chris Johns <cjohns@cybertec.com.au> and | Joel Sherrill | 2000-06-26 | 4 | -4/+4 |
| | | | | | Jennifer Averett <jennifer.averett@oarcorp.com> to make sure "/" is created with S_IFDIR set. | ||||
* | Patch rtemsdoc-4.5.0-rc-14-cvs.diff from Ralf Corsepius | Joel Sherrill | 2000-06-17 | 1 | -10/+16 |
| | | | | | <corsepiu@faw.uni-ulm.de> to address build problems effecting RedHat users but not SuSE users. | ||||
* | *** empty log message *** | Joel Sherrill | 2000-06-16 | 3 | -3/+4 |
* | Patch from John Cotton <john.cotton@nrc.ca> to correct style of | Joel Sherrill | 2000-06-16 | 2 | -32/+32 |
| | | | | names to be rtems_PACKAGE_method. | ||||
* | Bug report from James Housley <jim@thehousleys.net> correcting | Joel Sherrill | 2000-06-16 | 1 | -1/+1 |
| | | | | name of GNU Java Compiler. | ||||
* | changed version to ss-20000616 | Joel Sherrill | 2000-06-16 | 0 | -0/+0 |
* | changed version to ss-20000616 | Joel Sherrill | 2000-06-16 | 1 | -1/+1 |
* | New file. | Joel Sherrill | 2000-06-16 | 1 | -0/+2 |
* | Patch rtems-rc-20000616-2-cvs.diff from Ralf Corsepius | Joel Sherrill | 2000-06-16 | 1 | -1/+2 |
| | | | | | <corsepiu@faw.uni-ulm.de> to add -qnolinkcmds to bsp_specs like other BSPs. | ||||
* | Patch rtems-rc-20000616-1-cvs.diff from Ralf Corsepius | Joel Sherrill | 2000-06-16 | 1 | -7/+7 |
| | | | | | <corsepiu@faw.uni-ulm.de> to use __i386__ instead of __i386 and i386 to be able to compile this file with -ansi. | ||||
* | Patch from James Housley <jim@thehousleys.net> to address FreeBSD 4.x | Joel Sherrill | 2000-06-16 | 5 | -4/+5 |
| | | | | build issues. | ||||
* | Patch rtems-rc-20000615-4-cvs.diff from Ralf Corsepius | Joel Sherrill | 2000-06-16 | 3 | -23/+2 |
| | | | | | | | | | | | | <corsepiu@faw.uni-ulm.de> to fix the following: * lib/configure.in actually is libc's configure.in, so let it depend on libc not on lib [In my Cygnus/GNU configuration scheme, lib/include and lib/libc are treated as one unit, while libcpu and libbsp are treated as separate units.] * Allow empty --enable-bare* flags for the bare bsp. The formerly used scheme is too strict for our multilib experiments. | ||||
* | Modified to pick up components from libcpu. | Joel Sherrill | 2000-06-15 | 2 | -1/+2 |
* | rxgen960 compiles and links. | Joel Sherrill | 2000-06-15 | 9 | -17/+91 |
* | Remove pragma align 4 | Joel Sherrill | 2000-06-15 | 2 | -4/+0 |
* | Make ppc603e pick up caching code. | Joel Sherrill | 2000-06-15 | 1 | -0/+1 |
* | Pick up caching code. | Joel Sherrill | 2000-06-15 | 1 | -1/+2 |
* | Use correct name for caching routines. | Joel Sherrill | 2000-06-15 | 1 | -3/+2 |
* | Updated mailing list information. | Joel Sherrill | 2000-06-15 | 1 | -16/+24 |
* | Fixing warning obtained by some users. | Joel Sherrill | 2000-06-15 | 3 | -0/+12 |
* | Typo corrected from John Cotton <john.cotton@nrc.ca>. | Joel Sherrill | 2000-06-15 | 1 | -9/+9 |
* | Updated. | Joel Sherrill | 2000-06-15 | 2 | -1/+4 |
* | Added multigen generated bare BSP configuration files. | Joel Sherrill | 2000-06-15 | 1 | -0/+1 |
* | Patch rtems-rc-20000615-3-cvs.diff from Ralf Corsepius | Joel Sherrill | 2000-06-15 | 3 | -7/+9 |
| | | | | | <corsepiu@faw.uni-ulm.de> so these BSPs pick up the components they need from libcpu. | ||||
* | Patch rtems-rc-20000615-2-cvs.diff from Ralf Corsepius | Joel Sherrill | 2000-06-15 | 1 | -0/+6 |
| | | | | <corsepiu@faw.uni-ulm.de> to update multigen. | ||||
* | Patch rtems-rc-20000615-1-cvs.diff from Ralf Corsepius | Joel Sherrill | 2000-06-15 | 1 | -1/+1 |
| | | | | <corsepiu@faw.uni-ulm.de> to fix a bad file reference. | ||||
* | Moved <sys/cdefs.h> to lib/include so non-networking applications could | Joel Sherrill | 2000-06-15 | 3 | -3/+3 |
| | | | | include <sys/ioctl.h>. | ||||
* | Moved <sys/cdefs.h> to lib/include/sys from libnetworking/sys so | Joel Sherrill | 2000-06-15 | 1 | -2/+2 |
| | | | | non-networking applications could include <sys/ioctl.h>. |
