* | 2006-08-09 Kolja Waschk <waschk@telos.de> | Joel Sherrill | 2006-08-09 | 17 | -0/+1837 |
| | | | | | | | | * configure.ac: New port to Altera NIOS II. * nios2/.cvsignore, nios2/Makefile.am, nios2/README, nios2/bridges.c, nios2/bridges.h, nios2/clocks.c, nios2/clocks.h, nios2/configure.ac, nios2/devices.c, nios2/devices.h, nios2/nios2gen.c, nios2/output.c, nios2/output.h, nios2/ptf.c, nios2/ptf.h: New files. | ||||
* | 2006-08-09 Kolja Waschk <waschk@telos.de> | Joel Sherrill | 2006-08-09 | 2 | -0/+5 |
| | | | | * aclocal/rtems-cpu-subdirs.m4: New port to Altera NIOS II. | ||||
* | 2006-08-09 Kolja Waschk <waschk@telos.de> | Joel Sherrill | 2006-08-09 | 4 | -1/+8 |
| | | | | | * configure.ac, librpc/src/xdr/xdr_float.c, score/cpu/Makefile.am: New port to Altera NIOS II. | ||||
* | 2006-08-09 Kolja Waschk <waschk@telos.de> | Joel Sherrill | 2006-08-09 | 2 | -0/+10 |
| | | | | * TOOL_TARGETS: New port to Altera NIOS II. | ||||
* | 2006-08-09 Kolja Waschk <waschk@telos.de> | Joel Sherrill | 2006-08-09 | 2 | -0/+19 |
| | | | | * config-ml.in: New port to Altera NIOS II. | ||||
* | 2006-08-09 Kolja Waschk <waschk@telos.de> | Joel Sherrill | 2006-08-09 | 7 | -0/+221 |
| | | | | | | * nios2/Makefile.am, nios2/configure.ac, nios2/preinstall.am, nios2/shared/cache/cache.c, nios2/shared/cache/cache_.h, nios2/shared/misc/memcpy.c: New files. | ||||
* | 2006-08-09 Kolja Waschk <waschk@telos.de> | Joel Sherrill | 2006-08-09 | 3 | -0/+53 |
| | | | | | * Makefile.am: New port to Altera NIOS II. * custom/nios2_iss.cfg: New file. | ||||
* | 2006-08-09 Kolja Waschk <waschk@telos.de> | Joel Sherrill | 2006-08-09 | 7 | -0/+853 |
| | | | | | * ChangeLog, Makefile.am, cpu.c, cpu_asm.S, irq.c, preinstall.am, rtems/asm.h: New files. | ||||
* | 2006-08-09 Kolja Waschk <waschk@telos.de> | Joel Sherrill | 2006-08-09 | 29 | -0/+4136 |
| | | | | | | | | | | | | | | | * ChangeLog, Makefile.am, README, acinclude.m4, configure.ac, nios2_iss/ChangeLog, nios2_iss/Makefile.am, nios2_iss/bsp_specs, nios2_iss/configure.ac, nios2_iss/nios2_iss.ptf, nios2_iss/nios2_iss.sh, nios2_iss/times, nios2_iss/console/console.c, nios2_iss/include/bsp.h, nios2_iss/include/bspopts.h.in, nios2_iss/include/coverhd.h, nios2_iss/include/tm27.h, nios2_iss/shmsupp/addrconv.c, nios2_iss/shmsupp/getcfg.c, nios2_iss/shmsupp/lock.c, nios2_iss/shmsupp/mpisr.c, nios2_iss/start/crtnn.s, nios2_iss/start/start.S, nios2_iss/startup/bspclean.c, nios2_iss/startup/bspstart.c, nios2_iss/startup/linkcmds, nios2_iss/startup/main.c, nios2_iss/startup/setvec.c, nios2_iss/timer/timer.c: New files. | ||||
* | * libnetworking/rtems/rtems_mii_ioctl_kern.c: | Till Straumann | 2006-08-09 | 2 | -2/+19 |
| | | | | | read ANER and include partner's autoneg capability when determining active link parameters. | ||||
* | 2006-08-07 Chris Johns <chrisj@rtems.org> | Chris Johns | 2006-08-07 | 1 | -0/+37 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * build.sh: Log the script command lines. * build-rpms.sh: Updated to handle a different build processor to a i686. * build-exes.sh: Removed the tool version as Ralf has removed it from the rpms. 2006-08-05 Chris Johns <chrisj@rtems.org> * build-exes.sh: Update the release tag. 2006-08-04 Chris Johns <chrisj@rtems.org> * build-exes.sh: Updated to support the new installer. * build-rpms.sh: Updated to use common rather than base. More rpmbuild work arounds. * build.sh: Fix the return code when used with tee. * rtems.ini: Updated hello screen. * rtems-tools.nsi: Generate the batch files when installing. * AUTHORS, README: Convert to DOS format. 2006-07-22 Chris Johns <chrisj@rtems.org> * COPYING, build.sh, rtems-license.rtf: Changes to the installer and an extra script to build all. | ||||
* | Log the script command lines. | Chris Johns | 2006-08-07 | 1 | -0/+2 |
* | Updated to handle a different build processor to a i686. | Chris Johns | 2006-08-07 | 1 | -50/+47 |
* | Removed the tool version as Ralf has removed it from the rpms. | Chris Johns | 2006-08-07 | 1 | -5/+6 |
* | added startup/linkcmds.brs5l | Thomas Doerfler | 2006-08-07 | 2 | -0/+308 |
* | Update the release tag. | Chris Johns | 2006-08-05 | 1 | -1/+1 |
* | Updated to support the new installer. | Chris Johns | 2006-08-04 | 1 | -6/+25 |
* | Updated to use common rather than base. More rpmbuild work arounds. | Chris Johns | 2006-08-04 | 1 | -5/+12 |
* | Fix the return code when used with tee. | Chris Johns | 2006-08-04 | 1 | -4/+15 |
* | Updated hello screen. | Chris Johns | 2006-08-04 | 1 | -56/+59 |
* | Generate the batch files when installing. | Chris Johns | 2006-08-04 | 1 | -9/+81 |
* | Convert to DOS format. | Chris Johns | 2006-08-04 | 2 | -19/+19 |
* | Bump version. | Ralf Corsepius | 2006-08-03 | 1 | -1/+1 |
* | Use hard-coded %release. | Ralf Corsepius | 2006-08-03 | 1 | -2/+2 |
* | Use hard-coded %release. | Ralf Corsepius | 2006-08-03 | 11 | -30/+30 |
* | Remove (Obsolete) | Ralf Corsepius | 2006-08-03 | 1 | -50/+0 |
* | Remove | Ralf Corsepius | 2006-08-03 | 1 | -822/+0 |
* | Update to using newlib-1.14.0-rtems-20060707.diff | Ralf Corsepius | 2006-08-03 | 6 | -6/+6 |
* | Bump version. | Ralf Corsepius | 2006-08-02 | 1 | -1/+1 |
* | Use further shared spec-fragments. | Ralf Corsepius | 2006-08-02 | 2 | -0/+6 |
* | Split out target-autoconf.add | Ralf Corsepius | 2006-08-02 | 1 | -31/+2 |
* | Split out target-automake.add | Ralf Corsepius | 2006-08-02 | 1 | -30/+0 |
* | New. | Ralf Corsepius | 2006-08-02 | 2 | -0/+47 |
* | Add bsp_setbenv system call. | Eric Norum | 2006-08-01 | 2 | -1/+6 |
* | Add objc | Ralf Corsepius | 2006-07-25 | 2 | -2/+2 |
* | Remove sed -e /[@]tool_target[@]-newlib/d" | Ralf Corsepius | 2006-07-25 | 1 | -1/+0 |
* | Remove blank lines. | Ralf Corsepius | 2006-07-25 | 1 | -5/+5 |
* | More %if %build_newlib blocks. | Ralf Corsepius | 2006-07-25 | 2 | -0/+4 |
* | New. | Ralf Corsepius | 2006-07-25 | 1 | -0/+60 |
* | Fix rpmgroup. | Ralf Corsepius | 2006-07-25 | 2 | -26/+22 |
| | | | | Cosmetics. | ||||
* | Upgrade to gcc-3.4.4-2, cygwin-1.5.21-1 | Ralf Corsepius | 2006-07-25 | 1 | -2/+2 |
* | Bump version. | Ralf Corsepius | 2006-07-24 | 1 | -1/+3 |
| | | | | Add AC_CONFIG_FILES([autotools/Makefile]) | ||||
* | Add autotools. | Ralf Corsepius | 2006-07-24 | 1 | -0/+2 |
* | Add provisory/preliminary autotools support. | Ralf Corsepius | 2006-07-24 | 1 | -0/+2 |
* | Cleanup. | Ralf Corsepius | 2006-07-24 | 1 | -6/+3 |
| | | | | Add note on autotools. | ||||
* | New. | Ralf Corsepius | 2006-07-24 | 6 | -0/+235 |
* | Add Chris and Joel. | Ralf Corsepius | 2006-07-24 | 1 | -0/+8 |
* | 2006-07-23 Rename "*-base-*" packages into <tool>-common. | Ralf Corsepius | 2006-07-24 | 1 | -0/+5 |
| | | | | | | Rename GCC's "*-<lang>" packages into "*-gcc-<lang>". Many small directory ownership fixes. Build all GCC packages with --enable-threads. | ||||
* | Bump version | Ralf Corsepius | 2006-07-23 | 1 | -1/+1 |
* | Minor fixes. | Ralf Corsepius | 2006-07-23 | 1 | -2/+2 |
