* | Let rpm Obsolete < %{binutils_version}-%{release} | Ralf Corsepius | 2006-07-23 | 1 | -2/+2 | |
* | Rename *base packages into gcc*-common gcc/base*.add | Ralf Corsepius | 2006-07-23 | 2 | -4/+8 | |
* | Rename *base packages into gcc*-common gcc/base*.add | Ralf Corsepius | 2006-07-23 | 1 | -9/+10 | |
| | | | | Rename *gfortran into *gcc-gfortran | |||||
* | Rename *base packages into gcc*-common gcc/base*.add | Ralf Corsepius | 2006-07-23 | 1 | -8/+9 | |
| | | | | Rename *g77 into *gcc-g77 | |||||
* | Rename *base packages into gcc*-common gcc/base*.add | Ralf Corsepius | 2006-07-23 | 1 | -4/+7 | |
| | | | | Rename *objc into *gcc-objc | |||||
* | Rename *base packages into gcc*-common gcc/base*.add | Ralf Corsepius | 2006-07-23 | 1 | -1/+2 | |
| | | | | Rename *gcj into *gcc-gcj | |||||
* | Rename *base packages into gcc*-common gcc/base*.add | Ralf Corsepius | 2006-07-23 | 1 | -4/+5 | |
| | | | | Rename *gnat into *gcc-gnat | |||||
* | Rename *base packages into gcc*-common gcc/base*.add | Ralf Corsepius | 2006-07-23 | 1 | -5/+8 | |
| | | | | Rename *c++ into *gcc-c++ | |||||
* | Rename *base packages into gcc*-common | Ralf Corsepius | 2006-07-23 | 6 | -35/+69 | |
* | Let rpm Obsolete < %{gdb_version}-%{release} | Ralf Corsepius | 2006-07-23 | 1 | -2/+2 | |
* | Add --enable-threads. | Ralf Corsepius | 2006-07-23 | 1 | -0/+1 | |
* | Elminate blank lines. | Ralf Corsepius | 2006-07-23 | 6 | -24/+24 | |
* | Changes to the installer and an extra script to build all. | Chris Johns | 2006-07-22 | 3 | -0/+614 | |
* | Eliminate white spaces. | Ralf Corsepius | 2006-07-22 | 10 | -50/+50 | |
* | Rename rtems4.7-base-gdb into gdb-common | Ralf Corsepius | 2006-07-22 | 3 | -11/+14 | |
* | Rename rtems4.7-base-binutils into binutils-common | Ralf Corsepius | 2006-07-21 | 3 | -7/+13 | |
* | Remove --sources (Unused) | Ralf Corsepius | 2006-07-21 | 1 | -10/+0 | |
* | Add %{gcclib}/@tool_target@/%{gcc_version}/include/ssp | Ralf Corsepius | 2006-07-21 | 1 | -0/+3 | |
* | Make install-patches more verbose. | Ralf Corsepius | 2006-07-21 | 1 | -1/+2 | |
* | Add install-patches. | Ralf Corsepius | 2006-07-21 | 1 | -0/+6 | |
* | Add objc. | Ralf Corsepius | 2006-07-21 | 1 | -1/+1 | |
* | 2006-07-21 Chris Johns <chrisj@rtems.org> | Chris Johns | 2006-07-21 | 1 | -0/+6 | |
| | | | | | | * build-rpms.sh: Add the build-rpms.sh here until moved to crossrpms. * AUTHORS, ChangeLog, README: Add the support files. | |||||
* | Add the build-rpms.sh here until moved to crossrpms. | Chris Johns | 2006-07-21 | 1 | -0/+355 | |
* | Add the support files. | Chris Johns | 2006-07-21 | 3 | -0/+24 | |
* | Add NSIS installer support for MinGW. | Chris Johns | 2006-07-21 | 4 | -0/+416 | |
* | Use gcc-core-4.1.1-rtems-20060720.diff. | Chris Johns | 2006-07-20 | 10 | -10/+10 | |
* | Remove $build_infos. | Ralf Corsepius | 2006-07-20 | 1 | -9/+6 | |
| | | | | Add SPECSTRIP_OPTS. | |||||
* | Add --enable/disable-infos. | Ralf Corsepius | 2006-07-20 | 1 | -6/+13 | |
* | Add SPECSTRIP_OPTS. | Ralf Corsepius | 2006-07-20 | 1 | -2/+1 | |
* | 2006-07-19 Chris Johns <chrisj@rtems.org> | Chris Johns | 2006-07-20 | 1 | -0/+5 | |
| | | | | | * patches/gcc-core-4.1.1-rtems-20060720.diff: Added patch to fix GCC bug PR28400. | |||||
* | Added patch to fix GCC bug PR28400. | Chris Johns | 2006-07-19 | 1 | -0/+65 | |
* | Use newlib-1.14.0-rtems-20060707.diff | Ralf Corsepius | 2006-07-18 | 1 | -1/+1 | |
* | Fix setting up targets for solaris* | Ralf Corsepius | 2006-07-18 | 1 | -2/+7 | |
* | Remove infos and man7 if !%build_infos. | Ralf Corsepius | 2006-07-18 | 1 | -3/+1 | |
* | Require: base packages iff %build_infos | Ralf Corsepius | 2006-07-17 | 3 | -0/+8 | |
* | Require: base-g77 iff %build_infos | Ralf Corsepius | 2006-07-17 | 1 | -0/+2 | |
* | Require: base-gfortran iff %build_infos | Ralf Corsepius | 2006-07-17 | 1 | -1/+1 | |
* | Cosmetics. | Ralf Corsepius | 2006-07-17 | 5 | -6/+6 | |
* | 2006-07-16 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-07-16 | 2 | -0/+8 | |
| | | | | * preinstall.am: Install spacewire.h | |||||
* | Require base-gnat if build_infos is true. | Ralf Corsepius | 2006-07-16 | 1 | -1/+1 | |
* | Require base-gcc if build_infos is true. | Ralf Corsepius | 2006-07-16 | 2 | -2/+2 | |
* | Cosmetics. | Ralf Corsepius | 2006-07-16 | 2 | -2/+8 | |
* | Let *-gcc subpackage require base-package. | Ralf Corsepius | 2006-07-16 | 1 | -0/+3 | |
* | Remove rpmlint warning on subject. | Ralf Corsepius | 2006-07-16 | 1 | -1/+1 | |
* | Remove @build_infos@. | Ralf Corsepius | 2006-07-16 | 1 | -1/+0 | |
* | Eliminate @osversion@ | Ralf Corsepius | 2006-07-16 | 1 | -1/+0 | |
* | Eliminate @osversion. Hard-code 4.7. | Ralf Corsepius | 2006-07-16 | 16 | -52/+52 | |
* | 2006-07-13 Jerry Needell <jerry.needell@unh.edu> | Joel Sherrill | 2006-07-14 | 5 | -35/+90 | |
| | | | | | | * clock/ckinit.c, include/leon.h, timer/timer.c, amba/amba.c fixed up merge from 4.6.6. Correct references to LEON3_IrqCtrl_Regs_Map.mask[x] and LEON3_Timer_Regs_Map.timer[x]. | |||||
* | added ChangeLog entries for PR1117/1118/1119/1120 | Thomas Doerfler | 2006-07-14 | 6 | -0/+90 | |
* | Use <os>/<arch>/Makefile.am in check for all/rtems. | Ralf Corsepius | 2006-07-14 | 1 | -8/+12 | |
