* configure.in, Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros.
* ChangeLog: Corrected previous entry to include configure.in.
* automake/multilib.am: New file.
* Makefile.am: Update AUTOMAKE_FILES to reflect the contents of
the automake/ directory.
* configure.in: add tests to the GNU canonicalized subdirectories,
* itrontests.am: Remove DEFS.
* libtests.am: Remove DEFS.
* mptests.am: Remove DEFS.
* psxtests.am: Remove DEFS.
* sample.am: Remove DEFS.
* sptests.am: Remove DEFS.
* tmitrontests.am: Remove DEFS.
* tmtests.am: Remove DEFS.
* configure.in: Replace AC_CONFIG_SUBDIRS with
RTEMS_CONFIG_BUILD_SUBDIRS.
* Makefile.am: Make sure $SHELL inside of Makefiles does not get
propagated to the BSP-subdirectories if a user specified CONFIG_SHELL.
* configure.in: add lib/libcpu to the GNU canonicalized subdirectories,
* configure.in: Remove trailing '/'s from setting up RPM_SPECdir.
* configure.in: Remove bogus cfg_subdirs.
* configure.in: add lib to the GNU canonicalized subdirectories,
make the lib directory before configuring lib/.
* configure.in, Makefile.am: add exec to the GNU canonicalized
subdirectories.
* configure.in: add librtems++, libnetworking, librpc, librdb, libmisc,
and libchip to the GNU canonicalized subdirectories.
NOTE: Missed committing as each subdirectory was added (joel).
* configure.in: add librtems++ to the GNU canonicalized subdirectories.
* configure.in: add libnetworking, librpc and librdb to the GNU
* configure.in: add libmisc and libchip to the GNU canonicalized
subdirectories.
* macros/enable-hwapi.m4: Removed.
* aclocal/rtems-top.m4, automake/compile.am, automake/lib.am:
A small cleanup step towards gnu-canonicalization.
* libc/ioman.c: Moved to libfs.
* libc/Makefile.am: Removed ioman.c as part of moving it to libfs.
* libc/base_fs.c: Removed include of imfs.h and reworded comment
to avoid being IMFS specific.
* libc/libio.h: Removed prototype of IMFS_ops since it should
not be in this file.
* libc/mount.c: Removed IMFS specific configuration information.
* libc/unmount.c: Removed include of imfs.h and reworded comment
* custom/p4600.cfg, custom/p4650.cfg: Commented out RTEMS_CPU
definition since this information can be picked up from
autoconf generated files. These BSPs are shared by the
mips and mips64orion "ports."
* psxmount/test.c, psxstat/test.c: Include <imfs.h> to get IMFS_ops.
It was formerly incorrectly prototyped in <libio.h>.
* src/imfs/imfs_config.c: New file containing IMFS configuration
information split from libc/base_fs.c.
* src/imfs/ioman.c: New file. Moved from lib/libc. Missed previously.
* src/imfs/Makefile.am: Added imfs_config.c and ioman.c.
* Makefile.am, acinclude.m4, configure.in: Introduce GNU
canonicalization to libfs/.
The approach is currently a bit of a hack as GNU canonicalization
does not support the per-BSP build some of the other directories
require. As more of the tree is converted, this will become less
of an issue.
* Makefile.am, configure.in: Introduce GNU canonicalization to libfs/.
of an issue.
Joel Sherrill <joel@OARcorp.com>
* This is a major reworking of the mips64orion port to use
gcc predefines as much as possible and a big push to multilib
the mips port. The mips64orion port was copied/renamed to mips
to be more like other GNU tools. Alan did most of the technical
work of determining how to map old macro names used by the mips64orion
port to standard compiler macro definitions. Joel did the merge
with CVS magic to keep individual file history and did the BSP
modifications. Details follow:
* Makefile.am: Made clock and timer subdirectories conditional.
* configure.in: Ditto.
* clock/clock.S: Switch from using <idtmon.h> to <asm.h>.
* clock/gettime.S: Switch from using <idtmon.h> to <asm.h>.
* console/led.S: Switch from using <idtmon.h> to <asm.h>.
* console/start.S: Switch from using <idtmon.h> to <asm.h>. Added
define of PMON stacksize.
* console/idtmem.S: Switch from using <idtmon.h> to <asm.h>. Also
reworked conditionals to use gcc predefines.
* console/idttlb.S: Ditto.
* Makefile.am: idtmon.h in mips64orion port not present.
* asm.h: MIPS64ORION replaced with MIPS. Frame setup macros added.
* cpu.c: Comments added.
* cpu_asm.S: Conditionals changed. MIPS ISA level 1 support added.
First attempt at exception/interrupt processing for ISA level 1
and minus any use of IDT/MON added.
* idtcpu.h: Conditionals changed to use gcc predefines.
* iregdef.h: Ditto.
* cpu_asm.h: No real change. Merger required commit.
* rtems/Makefile.am: Ditto.
* rtems/score/Makefile.am: Ditto.
* rtems/score/cpu.h: Change MIPS64ORION to MIPS.
* rtems/score/mips64orion.h: Change MIPS64ORION to MIPS. Convert
from using RTEMS_CPU_MODEL to gcc predefines to figre things out.
* console/serial_mouse.c: Fixed typos introduced by removal of CR/LF.
* console/serial_mouse.c: Added support for changing serial parameters.
* mpc8xx/console-generic/console-generic.c: Avoid use of
BSP definitions and rely on the new routine
mbx8xx_console_get_configuration() to get information. This
routine was formerly incorrectly called
mbx8xx_console_use_maximum_buffer_size().
binding to the exception code.
* configure.in, Makefile.am: Explicitly specify whether an
RTEMS_CPU_MODEL is using old or new exception processing. This
is important because when building multilib, you do not know
the RTEMS_CPU_MODEL. So everything built in a multilib'ed RTEMS
must be independent of the exception model and allow for late
* console/console.c: Add mbx8xx_console_get_configuration() which
returns either nvram configuration or a static equivalent.
* console/console.c: Invoke BSP_uart_init() with enough arguments
now that more communication parameters are settable.
* shared/ppc.h: For multilibs, derive PPC_HAS_FPU from _SOFT_FLOAT.
* network/dec21140.c: Corrected attach to include "int attach"
parameter.
* include/wd80x3.h: Added file header and logic to prevent multiple
inclusions of this file.
* wd8003/wd8003.c: Corrected attach to include "int attach" parameter.
* include/bsp.h: Cleaned up network driver name and attach defines.
