* gdb/.cvsignore: Add mkspec.
* ChangeLog: Fix yesterday's entry.
* gdb/target-gdb.add: %defattr(-,root,root).
Use %{_prefix} instead of /opt/rtems.
Misc. minor changes.
* gdb/gdb.add: Use %{_prefix} instead of /opt/rtems.
Remove stray unpackaged files.
Use %{_defaultbuildroot} instead of hard-coded values.
configure --disable-nls.
Add BuildPreReq: ncurses-devel.
* gdb/base-gdb.add: %defattr(-,root,root).
* gdb/mkspec.in: New.
* gdb/Makefile.am: Reflect addition of gdb/mkspec.in.
* gcc3newlib/mkspec.in: Fix usage.
* gcc3newlib/gccnewlib.add: Use %{_defaultbuildroot} instead of
hard-coded values. Update copyright notice.
* mkgdbspec.in: Removed.
* Makefile.am: Remove mkgdbspec.
* configure.ac: Remove mkgdbspec.
Add gdb/mkspec.
* VERSION: Updated to rtems-ss-20030128.
* aclocal/version.m4: Updated to rtems-ss-20030128.
* tversions.texi: Updated tool version numbers.
* makefiles.t, support.t: Updated to reflect use of automake in
addition to autoconf.
* startup/Makefile.am, startup/linkcmds, startup/linkcmds-le,
startup/linkcmds-le.coff: Fix to work around truncated section names.
* startup/linkcmds: Fix to work around truncated section names.
* startup/linkcmds, startup/linkcmds.rom, startup/linkcmds.rom2ram: Fix
* startup/linkcmds, startup/linkcmds.ram, startup/linkcmds.rom: Fix to
* include/DP8570A.h, include/bsp.h, start/start.c,
startup/efi68k_tcp.c: Rename tcp_init() to bsp_tcp_init()
to avoid conflict with TCP/IP stack internal routine.
* .cvsignore: New file.
* setup.def, sparc-solaris-gcc.spec.in: Update and enable gnat. You
must build and install a C only toolset first though.
* .cvsignore: Add entries to .cvsignore.
* gccnewlib.add: Add various BuildPreReq.
Add %defattr(-,root,root) to "dir".
* base-g77.add: %defattr(-,root,root).
* base-gcc.add %defattr(-,root,root).
* base-gcj.add %defattr(-,root,root).
* base-gnat.add %defattr(-,root,root).
* target-c++.add %defattr(-,root,root).
* target-g77.add %defattr(-,root,root).
* target-gcc.add %defattr(-,root,root).
* target-gcj.add %defattr(-,root,root).
* target-gnat.add %defattr(-,root,root).
* target-objc.add %defattr(-,root,root).
* shmdr/Makefile.am: install mpci.h and shm_driver.h.
Eliminate OBJS.
* Makefile.am: Add kern/kern_sysctl.c to Makefile.am so networking
tests build. This was subsequently reported as PR337 before I
committed the fix.
* ChangeLog: binutils/binutils.add-entry from previous patch.
* setup.def: binutils_rpm_release=2.
* binutils/base-binutils.add: %defattr(-,root,root).
* binutils/binutils.add: Ditto.
* binutils/target-binutils.add: Ditto.
* Makefile.am, configure.ac: Added new test loopback which shows how to
use the loopback interface. Thank you Eric Norum for a portable
target independent test which exercises the TCP/IP. This should
prevent massive failures in the TCP/IP stack from reaching the
street.
* loopback/.cvsignore, loopback/Makefile.am, loopback/README,
loopback/init.c, loopback/loopback.scn: New files.
street.
* setup.def, sparc-solaris-binutils.spec.in: Updated and
used to build sparc-solaris 3.2.1-1 C language only.
2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
2001-04-16 Joel Sherrill <joel@OARcorp.com>
* .cvsignore: Added missing files.
* setup.def: New shot using gcc 3.0.4 RPMs.
* sparc-solaris-binutils.spec.in: Switched to bz2 file.
* sparc-solaris-gcc.spec.in: Use gcc3 file naming for archive
and use find to pick up all files.
2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2002-02-08 Joel Sherrill <joel@OARcorp.com>
2001-02-05 Joel Sherrill <joel@OARcorp.com>
* Makefile.am: New file, missed previously.
2004-02-05 Joel Sherrill <joel@OARcorp.com>
* ChangeLog, configure.ac, setup, setup.def,
sparc-solaris-binutils.spec.in, sparc-solaris-gcc.spec.in,
sparc-solaris-libs.spec.in: New files.
* i386-cygwin-gcc.spec.in, setup.def: Enabled building of GNAT for
revision 2.
* i386-cygwin-gcc.spec.in, i386-cygwin-mingw.spec.in, setup.def:
Updated to current Cygwin versions and fixed some minor nits in
the specifications.
2003-01-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* setup.def: Update to binutils-20021117-1.
* i386-cygwin-binutils.spec.in: Reflect update to binutils-20021127-1.
Adaptations to RH-8.0/rpm-4.1.
Add autom4te*cache.
* i386-cygwin-libs.spec.in, i386-cygwin-mingw.spec.in,
i386-cygwin-w32api.spec.in: Modified group.
2001-01-22 Joel Sherrill <joel@OARcorp.com>
* i386-cygwin-binutils.spec.in, i386-cygwin-gcc.spec.in,
i386-cygwin-w32api.spec.in, setup.def: Updated to reflect latest
versions and packaging.
2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* configure.in: Remove.
2001-09-13 Joel Sherrill <joel@OARcorp.com>
* .cvsignore: Corrected for missing files.
2001-08-31 Joel Sherrill <joel@OARcorp.com>
* .cvsignore: Missed in previous commit.
2001-08-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* Makefile.am, .cvsignore, configure.in, i386-cygwin-binutils.spec.in,
i386-cygwin-gcc.spec.in, i386-cygwin-libs.spec.in,
i386-cygwin-w32api.spec.in, i386-cygwin-mingw.spec.in, setup, setup.def:
New files that support building RPMs for Linux hosted cross compilers
targeting Cygwin.
* buildalltar.in, setup.def: Tool update including binaries for Cygwin
with a special RTEMS user account.
* libc/getproto.c, libc/getprotoname.c: modification to call
getprotoent_static() if fopen() on /etc/protocols fails.
* stackchk/check.c: Fix problem where _Objects_Get_information()
will dereference a null pointer when checking the interrupt stack.
If there's something at 0, you may be ok at run time but it is wrong.
* monitor/mon-command.c: Correct two potential NULL references.
* src/ptimer1.c: Correct problem which could lead to overflow in time
math.
* src/blkdev.c: Per PR331 fix bug which is tripped by writing 512 byte
blocks to 512 byte aligned positions.
* index.html.in: Fix duplicate c4x entry.
* configure.ac: Add rtemsdoc.
* Makefile.ac: Add rtemsdoc.
* rtemsdoc/README: New.
* rtemsdoc/.cvsignore: New.
* rtemsdoc/Makefile.am: New.
* rtemsdoc/mkspec.in: New.
* rtemsdoc/rtemsdoc.spec.in: New.
* rtemsdoc/supplement.add.in: New.
* rtemsdoc/templ.add.in: New.
* index.html.in: Add c4x.
* c_user.texi: Set @setfilename c_user.info.
* template.texi: Set @setfilename template.info.
* sparc.texi: Set @setfilename sparc.info.
* sh.texi: Set @setfilename sh.info.
* powerpc.texi: Set @setfilename powerpc.info.
* mips64orion.texi: Set @setfilename mips64orion.info.
* mips.texi: Set @setfilename mips.info.
* m68k.texi: Set @setfilename m68k.info.
* i960.texi: Set @setfilename i960.info.
* i386.texi: Set @setfilename i386.info.
* hppa1_1.texi: Set @setfilename hppa1_1.info.
* c4x.texi: Set @setfilename c4x.info.
* arm.texi: Set @setfilename arm.info.
* started_ada.texi: Set @setfilename started_ada.info.
