* | bsp/lpc24xx: Convert I2C driver to Linux API | Sebastian Huber | 2019-03-15 | 4 | -365/+435 |
| | | | | | | Change license to BSD-2-Clause. Close #3725. | ||||
* | bsps/powerpc: Initialize stack earlier | Sebastian Huber | 2019-03-15 | 1 | -9/+9 |
| | | | | | | The __eabi() call may use the stack. Update #3459. | ||||
* | shmopen.c: Fix logically unreachable code (Coverity ID: 1399706, 1399714) | Joel Sherrill | 2019-03-14 | 1 | -2/+3 |
| | | | | Closes #3694. | ||||
* | main_edit.c: Use strncpy() to eliminate potential buffer overflow. | Joel Sherrill | 2019-03-14 | 1 | -4/+5 |
* | fifo.c: Eliminate logically dead code (Coverity 1437635) | Joel Sherrill | 2019-03-14 | 1 | -8/+5 |
* | z85c30.c: Do not process 0 baud and return an error (CID 1399713) | Joel Sherrill | 2019-03-14 | 1 | -0/+9 |
* | Remove superfluous <rtems/system.h> includes | Sebastian Huber | 2019-03-14 | 135 | -142/+6 |
* | sparc64: Do not include <rtems/asm.h> in C source | Sebastian Huber | 2019-03-14 | 1 | -1/+0 |
* | Add rtems_board_support_package() | Sebastian Huber | 2019-03-14 | 3 | -0/+14 |
* | posix: is_initialized is of type int not bool | Sebastian Huber | 2019-03-13 | 3 | -3/+3 |
* | Regenerate cpukit/headers.am | Sebastian Huber | 2019-03-13 | 1 | -0/+1 |
| | | | | Updates #3686. | ||||
* | bsp/lm3s69xx: Fix typo in test configuration | Sebastian Huber | 2019-03-13 | 2 | -2/+1 |
* | mpc5643l_evb-testsuite.tcfg: : Update to account for static allocation and ↵ | Joel Sherrill | 2019-03-12 | 1 | -0/+4 |
| | | | | BSP small memory | ||||
* | mpc5643l_dpu-testsuite.tcfg: Update to account for static allocation and BSP ↵ | Joel Sherrill | 2019-03-12 | 1 | -0/+4 |
| | | | | small memory | ||||
* | mcf5225x-testsuite.tcfg: Update to account for static allocation and BSP ↵ | Joel Sherrill | 2019-03-12 | 1 | -0/+1 |
| | | | | small memory | ||||
* | mcf52235-testsuite.tcfg: Update to account for static allocation and BSP ↵ | Joel Sherrill | 2019-03-12 | 1 | -0/+6 |
| | | | | small memory | ||||
* | tms570ls3137_hdk_with_loader-testsuite.tcfg: Update to account for static ↵ | Joel Sherrill | 2019-03-12 | 1 | -0/+2 |
| | | | | allocation and BSP small memory | ||||
* | tms570ls3137_hdk_intram-testsuite.tcfg: Update to account for static ↵ | Joel Sherrill | 2019-03-12 | 1 | -0/+2 |
* | tms570ls3137_hdk-testsuite.tcfg: Update to account for static allocation and ↵ | Joel Sherrill | 2019-03-12 | 1 | -0/+2 |
* | stm32f4-testsuite.tcfg: Update to account for static allocation and BSP ↵ | Joel Sherrill | 2019-03-12 | 1 | -0/+1 |
| | | | | small memory | ||||
* | stm32f105rc-testsuite.tcfg: Update to account for static allocation and BSP ↵ | Joel Sherrill | 2019-03-12 | 1 | -0/+1 |
| | | | | small memory | ||||
* | lpc32xx_mzx_stage_1-testsuite.tcfg: Update to account for static allocation ↵ | Joel Sherrill | 2019-03-12 | 1 | -0/+3 |
* | lpc23xx_tli800-testsuite.tcfg: Update to account for static allocation and ↵ | Joel Sherrill | 2019-03-12 | 1 | -0/+16 |
* | lpc2362-testsuite.tcfg: Update to account for static allocation and BSP ↵ | Joel Sherrill | 2019-03-12 | 1 | -0/+17 |
| | | | | small memory | ||||
* | lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Update to account for static ↵ | Joel Sherrill | 2019-03-12 | 1 | -52/+105 |
* | lpc1768_mbed_ahb_ram-testsuite.tcfg: Update to account for static allocation ↵ | Joel Sherrill | 2019-03-12 | 1 | -55/+6 |
* | lpc1768_mbed-testsuite.tcfg: Update to account for static allocation and BSP ↵ | Joel Sherrill | 2019-03-12 | 1 | -62/+14 |
| | | | | small memory | ||||
* | lm4f120-testsuite.tcfg: Update to account for static allocation and BSP ↵ | Joel Sherrill | 2019-03-12 | 1 | -49/+2 |
| | | | | small memory | ||||
* | lm3s6965-testsuite.tcfg: Update to account for static allocation and BSP ↵ | Joel Sherrill | 2019-03-12 | 1 | -0/+2 |
| | | | | small memory | ||||
* | lm3s3749-testsuite.tcfg: Update to account for static allocation and BSP ↵ | Joel Sherrill | 2019-03-12 | 1 | -0/+7 |
| | | | | small memory | ||||
* | coremsgseize.c: Fix spelling error | Joel Sherrill | 2019-03-12 | 1 | -1/+1 |
* | bsp/lpc24xx: Convert SSP driver to Linux API | Sebastian Huber | 2019-03-12 | 2 | -556/+396 |
| | | | | | | | Use interrupts instead of polled or DMA driven mode. Change license to BSD-2-Clause. Close #3724. | ||||
* | bsp/lpc24xx: Add alternative SSP2 pins | Sebastian Huber | 2019-03-12 | 1 | -0/+8 |
* | record: Add more system events | Sebastian Huber | 2019-03-12 | 2 | -115/+115 |
| | | | | Update #3665. | ||||
* | record: Add system call entry/exit events | Sebastian Huber | 2019-03-12 | 2 | -165/+165 |
| | | | | | | This corresponds to the Linux syscall_entry_* and syscall_exit_* events. Update #3665. | ||||
* | record: Rename internal per-CPU events | Sebastian Huber | 2019-03-12 | 6 | -27/+27 |
* | Correct psxtmtests_plan.csv | Shashvat Jain | 2019-03-11 | 1 | -3/+3 |
* | bsp/atsam: Fix use after free | Sebastian Huber | 2019-03-11 | 1 | -2/+1 |
* | bsps: Adjust umon Doxygen groups | Sebastian Huber | 2019-03-08 | 2 | -5/+8 |
| | | | | Update #3706. | ||||
* | bsp/atsam: Add Doxygen groups | Sebastian Huber | 2019-03-08 | 1 | -0/+1111 |
| | | | | | | | Add Doxygen groups for contributed code which would otherwise end up at the top level (about 178 groups). Update #3706. | ||||
* | bsp/altera-cyclone-v: Add Doxygen groups | Sebastian Huber | 2019-03-08 | 2 | -8/+85 |
| | | | | | | | Add Doxygen groups for contributed code which would otherwise end up at the top level. Update #3706. | ||||
* | bsps/arm: Adjust CMSIS Doxygen groups | Sebastian Huber | 2019-03-08 | 5 | -0/+15 |
* | bsps: Adjust shared Doxygen groups | Sebastian Huber | 2019-03-08 | 88 | -172/+263 |
* | bsps: Adjust bsp.h Doxygen groups | Sebastian Huber | 2019-03-08 | 374 | -653/+1693 |
* | shell: Correct argument order of `mfill` | Jonathan Brandmeyer | 2019-03-08 | 1 | -1/+1 |
| | | | | Close #3720. | ||||
* | cpukit/arm: Correct register definition | Jonathan Brandmeyer | 2019-03-08 | 1 | -2/+2 |
| | | | | | | | | | | | | | | The register definition for the CP15 PMCR (performance monitor control register) has the bits for X (export enable) and D (clock divider enable) backwards. Correct them according to ARMv7-A/R Architecture Reference Manual, Rev C, Section B4.1.117. Consequences: On an implementation that starts off with D set at reset, the clock divider will not be disabled by using RTEMS' definition of the D bit. Tested by using the counter on Xilinx Zynq 7020 to measure some atomic accesses and cache flushing operations. | ||||
* | bsps/powerpc: Move mpc55xx header files | Sebastian Huber | 2019-03-07 | 18 | -19/+19 |
| | | | | They are only used by this BSP. | ||||
* | libdl: Add small data support to the remaining PowerPC BSPs. | Chris Johns | 2019-03-07 | 8 | -42/+144 |
| | | | | Updates #3687 | ||||
* | testsuite: Make the OPERATION_COUNT a test configuration parameter. | Chris Johns | 2019-03-07 | 70 | -374/+335 |
| | | | | | - Add a small memory test config file. - Update the small memory PowerPC BSPs to use the new test config. | ||||
* | testsuite: Add rexclude, rinclude and cflags to test config files. | Chris Johns | 2019-03-07 | 1 | -11/+83 |
