* Makefile.am: AM_CPPFLAGS += -I$(top_builddir).
Use AM_CPPFLAGS instead of AM_CFLAGS.
* src/ata.c: Include config.h.
* src/bdbuf.c: Ditto.
* src/blkdev.c: Ditto.
* src/diskdevs.c: Ditto.
* src/ide_part_table.c: Ditto.
* src/ramdisk.c: Ditto.
* capture/config.h: Remove.
* capture/Makefile.am: Remove config.h.
* cpuuse/config.h: Remove.
* cpuuse/Makefile.am: Remove config.h.
* devnull/config.h: Remove.
* devnull/Makefile.am: Remove config.h.
* dummy/config.h: Remove.
* dummy/Makefile.am: Remove config.h.
* dumpbuf/config.h: Remove.
* dumpbuf/Makefile.am: Remove config.h.
* monitor/config.h: Remove.
* monitor/Makefile.am: Remove config.h.
* mw-fb/config.h: Remove.
* mw-fb/Makefile.am: Remove config.h.
* rtmonuse/config.h: Remove.
* rtmonuse/Makefile.am: Remove config.h.
* serdbg/config.h: Remove.
* serdbg/Makefile.am: Remove config.h.
* shell/config.h: Remove.
* shell/Makefile.am: Remove config.h.
* stackchk/config.h: Remove.
* stackchk/Makefile.am: Remove config.h.
* untar/config.h: Remove.
* untar/Makefile.am: Remove config.h.
* src/config.h: Remove.
* Makefile.am: Remove src/config.h
* src/Makefile.am: AM_CPPFLAGS += -I$(top_builddir).
* src/dosfs/config.h: Remove.
* src/dosfs/Makefile.am: Remove config.h
* src/imfs/config.h: Remove.
* src/imfs/Makefile.am: Remove config.h
* acinclude.m4: New.
* configure.ac: Don't use AUTOHEADER to generate cpuopts.h.
Add local autoheader config.h.
* aclocal/canonical-target-name.m4: Require AC_CANONICAL_HOST.
* aclocal/enable-inlines.m4: Remove USE_MACROS (Unused).
* gcc3newlib/gccnewlib.add: Add hacks to make gnatlib
buildable.
* gcc3newlib/base-gnat.add: Add info files.
which included commits to RCS files with non-trunk default branches.
* Makefile.am: Reflect having moved tests/.
* mptests/Makefile.am: Reflect having moved tests/.
* mptests/mp01/Makefile.am: Reflect having moved tests/.
* mptests/mp01/node1/Makefile.am: Reflect having moved tests/.
* mptests/mp01/node2/Makefile.am: Reflect having moved tests/.
* samples/Makefile.am: Reflect having moved tests/.
* samples/base_mp/Makefile.am: Reflect having moved tests/.
* samples/base_mp/node1/Makefile.am: Reflect having moved tests/.
* samples/base_mp/node2/Makefile.am: Reflect having moved tests/.
* samples/base_sp/Makefile.am: Reflect having moved tests/.
* samples/hello/Makefile.am: Reflect having moved tests/.
* samples/ticker/Makefile.am: Reflect having moved tests/.
* sptests/Makefile.am: Reflect having moved tests/.
* sptests/sp01/Makefile.am: Reflect having moved tests/.
* sptests/sp02/Makefile.am: Reflect having moved tests/.
* sptests/sp03/Makefile.am: Reflect having moved tests/.
* sptests/sp04/Makefile.am: Reflect having moved tests/.
* sptests/sp05/Makefile.am: Reflect having moved tests/.
* sptests/sp06/Makefile.am: Reflect having moved tests/.
* sptests/sp07/Makefile.am: Reflect having moved tests/.
* sptests/sp08/Makefile.am: Reflect having moved tests/.
* sptests/sp09/Makefile.am: Reflect having moved tests/.
* sptests/sp11/Makefile.am: Reflect having moved tests/.
* sptests/sp12/Makefile.am: Reflect having moved tests/.
* sptests/sp13/Makefile.am: Reflect having moved tests/.
* sptests/sp14/Makefile.am: Reflect having moved tests/.
* sptests/sp15/Makefile.am: Reflect having moved tests/.
* sptests/sp16/Makefile.am: Reflect having moved tests/.
* sptests/sp17/Makefile.am: Reflect having moved tests/.
* sptests/sp19/Makefile.am: Reflect having moved tests/.
* sptests/sp20/Makefile.am: Reflect having moved tests/.
* sptests/sp21/Makefile.am: Reflect having moved tests/.
* sptests/sp22/Makefile.am: Reflect having moved tests/.
* sptests/sp23/Makefile.am: Reflect having moved tests/.
* sptests/sp24/Makefile.am: Reflect having moved tests/.
* sptests/sp25/Makefile.am: Reflect having moved tests/.
* sptests/spsize/Makefile.am: Reflect having moved tests/.
* support/Makefile.am: Reflect having moved tests/.
* tmtests/Makefile.am: Reflect having moved tests/.
* tmtests/tm01/Makefile.am: Reflect having moved tests/.
* tmtests/tm02/Makefile.am: Reflect having moved tests/.
* tmtests/tm03/Makefile.am: Reflect having moved tests/.
* tmtests/tm04/Makefile.am: Reflect having moved tests/.
* tmtests/tm05/Makefile.am: Reflect having moved tests/.
* tmtests/tm06/Makefile.am: Reflect having moved tests/.
* tmtests/tm07/Makefile.am: Reflect having moved tests/.
* tmtests/tm08/Makefile.am: Reflect having moved tests/.
* tmtests/tm09/Makefile.am: Reflect having moved tests/.
* tmtests/tm10/Makefile.am: Reflect having moved tests/.
* tmtests/tm11/Makefile.am: Reflect having moved tests/.
* tmtests/tm12/Makefile.am: Reflect having moved tests/.
* tmtests/tm13/Makefile.am: Reflect having moved tests/.
* tmtests/tm14/Makefile.am: Reflect having moved tests/.
* tmtests/tm15/Makefile.am: Reflect having moved tests/.
* tmtests/tm16/Makefile.am: Reflect having moved tests/.
* tmtests/tm17/Makefile.am: Reflect having moved tests/.
* tmtests/tm18/Makefile.am: Reflect having moved tests/.
* tmtests/tm19/Makefile.am: Reflect having moved tests/.
* tmtests/tm20/Makefile.am: Reflect having moved tests/.
* tmtests/tm21/Makefile.am: Reflect having moved tests/.
* tmtests/tm22/Makefile.am: Reflect having moved tests/.
* tmtests/tm23/Makefile.am: Reflect having moved tests/.
* tmtests/tm24/Makefile.am: Reflect having moved tests/.
* tmtests/tm25/Makefile.am: Reflect having moved tests/.
* tmtests/tm28/Makefile.am: Reflect having moved tests/.
* tmtests/tm29/Makefile.am: Reflect having moved tests/.
* tmtests/tmck/Makefile.am: Reflect having moved tests/.
* tmtests/tmoverhd/Makefile.am: Reflect having moved tests/.
* aclocal/canonical-target-name.m4: Remove.
* aclocal/canonicalize-tools.m4: Remove.
* aclocal/check-custom-bsp.m4: Remove.
* aclocal/check-cxx.m4: Remove.
* aclocal/check-itron.m4: Remove.
* aclocal/check-multiprocessing.m4: Remove.
* aclocal/check-networking.m4: Remove.
* aclocal/check-posix.m4: Remove.
* aclocal/check-tests.m4: Remove.
* aclocal/check-tool.m4: Remove.
* aclocal/config-subdirs.m4: Remove.
* aclocal/enable-bare.m4: Remove.
* aclocal/enable-cxx.m4: Remove.
* aclocal/enable-itron.m4: Remove.
* aclocal/enable-multiprocessing.m4: Remove.
* aclocal/enable-networking.m4: Remove.
* aclocal/enable-posix.m4: Remove.
* aclocal/enable-rtemsbsp.m4: Remove.
* aclocal/enable-tests.m4: Remove.
* aclocal/env-rtemsbsp.m4: Remove.
* aclocal/gcc-isystem.m4: Remove.
* aclocal/gcc-pipe.m4: Remove.
* aclocal/gcc-specs.m4: Remove.
* aclocal/multilib.m4: Remove.
* aclocal/path-ksh.m4: Remove.
* aclocal/prog-cc.m4: Remove.
* aclocal/prog-cxx.m4: Remove.
* aclocal/project-root.m4: Remove.
* aclocal/quoting.m4: Remove.
* aclocal/rtems-cpu-subdirs.m4: Remove.
* aclocal/rtems-flags.m4: Remove.
* aclocal/rtems-test-no-pause.m4: Remove.
* aclocal/rtems-top.m4: Remove.
* aclocal/target.m4: Remove.
* aclocal/tool-paths.m4: Remove.
* aclocal/version.m4: Remove.
* .cvsignore: Remove.
* ChangeLog: Remove.
* Makefile.am: Remove.
* PROBLEMS: Remove.
* README: Remove.
* configure.ac: Remove.
* automake/compile.am: Remove.
* automake/host.am: Remove.
* automake/leaf.am: Remove.
* automake/local.am: Remove.
* automake/subdirs.am: Remove.
* PROBLEMS: Remove.
* README: Remove.
* mp01/node1/.cvsignore: Remove.
* mp01/node1/Makefile.am: Remove.
* mp01/node1/mp01.doc: Remove.
* mp01/node1/mp01.scn: Remove.
* mp01/.cvsignore: Remove.
* mp01/Makefile.am: Remove.
* mp01/init.c: Remove.
* mp01/system.h: Remove.
* mp01/task1.c: Remove.
* mp01/node2/.cvsignore: Remove.
* mp01/node2/Makefile.am: Remove.
* mp01/node2/mp01.doc: Remove.
* mp01/node2/mp01.scn: Remove.
* mp02/node1/.cvsignore: Remove.
* mp02/node1/Makefile.am: Remove.
* mp02/node1/mp02.doc: Remove.
* mp02/node1/mp02.scn: Remove.
* mp02/.cvsignore: Remove.
* mp02/Makefile.am: Remove.
* mp02/init.c: Remove.
* mp02/system.h: Remove.
* mp02/task1.c: Remove.
* mp02/node2/.cvsignore: Remove.
* mp02/node2/Makefile.am: Remove.
* mp02/node2/mp02.doc: Remove.
* mp02/node2/mp02.scn: Remove.
* README: Remove.
* mptests.am: Remove.
* mp03/node1/.cvsignore: Remove.
* mp03/node1/Makefile.am: Remove.
* mp03/node1/mp03.doc: Remove.
* mp03/node1/mp03.scn: Remove.
* mp03/.cvsignore: Remove.
* mp03/Makefile.am: Remove.
* mp03/delay.c: Remove.
* mp03/init.c: Remove.
* mp03/system.h: Remove.
* mp03/task1.c: Remove.
* mp03/node2/.cvsignore: Remove.
* mp03/node2/Makefile.am: Remove.
* mp03/node2/mp03.doc: Remove.
* mp03/node2/mp03.scn: Remove.
* mp04/node1/.cvsignore: Remove.
* mp04/node1/Makefile.am: Remove.
* mp04/node1/mp04.doc: Remove.
* mp04/node1/mp04.scn: Remove.
* mp04/.cvsignore: Remove.
* mp04/Makefile.am: Remove.
* mp04/init.c: Remove.
* mp04/system.h: Remove.
* mp04/task1.c: Remove.
* mp04/node2/.cvsignore: Remove.
* mp04/node2/Makefile.am: Remove.
* mp04/node2/mp04.doc: Remove.
* mp04/node2/mp04.scn: Remove.
* mp05/node1/.cvsignore: Remove.
* mp05/node1/Makefile.am: Remove.
* mp05/node1/mp05.doc: Remove.
* mp05/node1/mp05.scn: Remove.
* mp05/.cvsignore: Remove.
* mp05/Makefile.am: Remove.
* mp05/asr.c: Remove.
* mp05/init.c: Remove.
* mp05/system.h: Remove.
* mp05/task1.c: Remove.
* mp05/node2/.cvsignore: Remove.
* mp05/node2/Makefile.am: Remove.
* mp05/node2/mp05.doc: Remove.
* mp05/node2/mp05.scn: Remove.
* mp06/node1/.cvsignore: Remove.
* mp06/node1/Makefile.am: Remove.
* mp06/node1/mp06.doc: Remove.
* mp06/node1/mp06.scn: Remove.
* mp06/.cvsignore: Remove.
* mp06/Makefile.am: Remove.
* mp06/init.c: Remove.
* mp06/system.h: Remove.
* mp06/task1.c: Remove.
* mp06/node2/.cvsignore: Remove.
* mp06/node2/Makefile.am: Remove.
* mp06/node2/mp06.doc: Remove.
* mp06/node2/mp06.scn: Remove.
* mp07/node1/.cvsignore: Remove.
* mp07/node1/Makefile.am: Remove.
* mp07/node1/mp07.doc: Remove.
* mp07/node1/mp07.scn: Remove.
* mp07/.cvsignore: Remove.
* mp07/Makefile.am: Remove.
* mp07/init.c: Remove.
* mp07/system.h: Remove.
* mp07/task1.c: Remove.
* mp07/node2/.cvsignore: Remove.
* mp07/node2/Makefile.am: Remove.
* mp07/node2/mp07.doc: Remove.
* mp07/node2/mp07.scn: Remove.
* mp08/node1/.cvsignore: Remove.
* mp08/node1/Makefile.am: Remove.
* mp08/node1/mp08.doc: Remove.
* mp08/node1/mp08.scn: Remove.
* mp08/.cvsignore: Remove.
* mp08/Makefile.am: Remove.
* mp08/init.c: Remove.
* mp08/system.h: Remove.
* mp08/task1.c: Remove.
* mp08/node2/.cvsignore: Remove.
* mp08/node2/Makefile.am: Remove.
* mp08/node2/mp08.doc: Remove.
* mp08/node2/mp08.scn: Remove.
* mp09/node1/.cvsignore: Remove.
* mp09/node1/Makefile.am: Remove.
* mp09/node1/mp09.doc: Remove.
* mp09/node1/mp09.scn: Remove.
* mp09/.cvsignore: Remove.
* mp09/Makefile.am: Remove.
* mp09/init.c: Remove.
* mp09/recvmsg.c: Remove.
* mp09/sendmsg.c: Remove.
* mp09/system.h: Remove.
* mp09/task1.c: Remove.
* mp09/node2/.cvsignore: Remove.
* mp09/node2/Makefile.am: Remove.
* mp09/node2/mp09.doc: Remove.
* mp09/node2/mp09.scn: Remove.
* mp10/node1/.cvsignore: Remove.
* mp10/node1/Makefile.am: Remove.
* mp10/node1/mp10.doc: Remove.
* mp10/node1/mp10.scn: Remove.
* mp10/.cvsignore: Remove.
* mp10/Makefile.am: Remove.
* mp10/init.c: Remove.
* mp10/system.h: Remove.
* mp10/task1.c: Remove.
* mp10/task2.c: Remove.
* mp10/task3.c: Remove.
* mp10/node2/.cvsignore: Remove.
* mp10/node2/Makefile.am: Remove.
* mp10/node2/mp10.doc: Remove.
* mp10/node2/mp10.scn: Remove.
* mp11/node1/.cvsignore: Remove.
* mp11/node1/Makefile.am: Remove.
* mp11/node1/mp11.doc: Remove.
* mp11/node1/mp11.scn: Remove.
* mp11/.cvsignore: Remove.
* mp11/Makefile.am: Remove.
* mp11/init.c: Remove.
* mp11/system.h: Remove.
* mp11/node2/.cvsignore: Remove.
* mp11/node2/Makefile.am: Remove.
* mp11/node2/mp11.doc: Remove.
* mp11/node2/mp11.scn: Remove.
* mp12/node1/.cvsignore: Remove.
* mp12/node1/Makefile.am: Remove.
* mp12/node1/mp12.doc: Remove.
* mp12/node1/mp12.scn: Remove.
* mp12/.cvsignore: Remove.
* mp12/Makefile.am: Remove.
* mp12/init.c: Remove.
* mp12/system.h: Remove.
* mp12/node2/.cvsignore: Remove.
* mp12/node2/Makefile.am: Remove.
* mp12/node2/mp12.doc: Remove.
* mp12/node2/mp12.scn: Remove.
* mp13/node1/.cvsignore: Remove.
* mp13/node1/Makefile.am: Remove.
* mp13/node1/mp13.doc: Remove.
* mp13/node1/mp13.scn: Remove.
* mp13/.cvsignore: Remove.
* mp13/Makefile.am: Remove.
* mp13/init.c: Remove.
* mp13/system.h: Remove.
* mp13/task1.c: Remove.
* mp13/task2.c: Remove.
* mp13/node2/.cvsignore: Remove.
* mp13/node2/Makefile.am: Remove.
* mp13/node2/mp13.doc: Remove.
* mp13/node2/mp13.scn: Remove.
* mp14/node1/.cvsignore: Remove.
* mp14/node1/Makefile.am: Remove.
* mp14/node1/mp14.doc: Remove.
* mp14/node1/mp14.scn: Remove.
* mp14/.cvsignore: Remove.
* mp14/Makefile.am: Remove.
* mp14/delay.c: Remove.
* mp14/evtask1.c: Remove.
* mp14/evtmtask.c: Remove.
* mp14/exit.c: Remove.
* mp14/init.c: Remove.
* mp14/msgtask1.c: Remove.
* mp14/pttask1.c: Remove.
* mp14/smtask1.c: Remove.
* mp14/system.h: Remove.
* mp14/node2/.cvsignore: Remove.
* mp14/node2/Makefile.am: Remove.
* mp14/node2/mp14.doc: Remove.
* mp14/node2/mp14.scn: Remove.
* include/.cvsignore: Remove.
* include/timesys.h: Remove.
* README: Remove.
* tmitrontests.am: Remove.
* tmitronsem01/.cvsignore: Remove.
* tmitronsem01/Makefile.am: Remove.
* tmitronsem01/init.c: Remove.
* tmitronsem01/system.h: Remove.
* tmitronsem01/tmitronsem01.doc: Remove.
* generic/.cvsignore: Remove.
* generic/ChangeLog: Remove.
* generic/Makefile.am: Remove.
* generic/configure.ac: Remove.
* generic/difftest.in: Remove.
* generic/sorttimes.in: Remove.
* psxtests.am: Remove.
* include/pmacros.h: Remove.
* psx01/.cvsignore: Remove.
* psx01/Makefile.am: Remove.
* psx01/init.c: Remove.
* psx01/psx01.scn: Remove.
* psx01/system.h: Remove.
* psx01/task.c: Remove.
* psx02/.cvsignore: Remove.
* psx02/Makefile.am: Remove.
* psx02/init.c: Remove.
* psx02/psx02.scn: Remove.
* psx02/system.h: Remove.
* psx02/task.c: Remove.
* psx03/.cvsignore: Remove.
* psx03/Makefile.am: Remove.
* psx03/init.c: Remove.
* psx03/psx03.scn: Remove.
* psx03/system.h: Remove.
* psx03/task.c: Remove.
* psx04/.cvsignore: Remove.
* psx04/Makefile.am: Remove.
* psx04/init.c: Remove.
* psx04/psx04.scn: Remove.
* psx04/system.h: Remove.
* psx04/task1.c: Remove.
* psx04/task2.c: Remove.
* psx04/task3.c: Remove.
* psx05/.cvsignore: Remove.
* psx05/Makefile.am: Remove.
* psx05/init.c: Remove.
* psx05/psx05.scn: Remove.
* psx05/system.h: Remove.
* psx05/task.c: Remove.
* psx05/task2.c: Remove.
* psx05/task3.c: Remove.
* psx06/.cvsignore: Remove.
* psx06/Makefile.am: Remove.
* psx06/init.c: Remove.
* psx06/psx06.scn: Remove.
* psx06/system.h: Remove.
* psx06/task.c: Remove.
* psx06/task2.c: Remove.
* psx07/.cvsignore: Remove.
* psx07/Makefile.am: Remove.
* psx07/init.c: Remove.
* psx07/psx07.scn: Remove.
* psx07/system.h: Remove.
* psx07/task.c: Remove.
* psx08/.cvsignore: Remove.
* psx08/Makefile.am: Remove.
* psx08/init.c: Remove.
* psx08/psx08.scn: Remove.
* psx08/system.h: Remove.
* psx08/task1.c: Remove.
* psx08/task2.c: Remove.
* psx08/task3.c: Remove.
* psx09/.cvsignore: Remove.
* psx09/Makefile.am: Remove.
* psx09/init.c: Remove.
* psx09/psx09.scn: Remove.
* psx09/system.h: Remove.
* psx10/.cvsignore: Remove.
* psx10/Makefile.am: Remove.
* psx10/init.c: Remove.
* psx10/psx10.scn: Remove.
* psx10/system.h: Remove.
* psx10/task.c: Remove.
* psx10/task2.c: Remove.
* psx10/task3.c: Remove.
* psx11/.cvsignore: Remove.
* psx11/Makefile.am: Remove.
* psx11/init.c: Remove.
* psx11/psx11.scn: Remove.
* psx11/system.h: Remove.
* psx11/task.c: Remove.
* psx12/.cvsignore: Remove.
* psx12/Makefile.am: Remove.
* psx12/init.c: Remove.
* psx12/psx12.scn: Remove.
* psx12/system.h: Remove.
* psx12/task.c: Remove.
* psx13/.cvsignore: Remove.
* psx13/Makefile.am: Remove.
* psx13/main.c: Remove.
* psx13/psx13.scn: Remove.
* psx13/test.c: Remove.
* psxcancel/.cvsignore: Remove.
* psxcancel/Makefile.am: Remove.
* psxcancel/init.c: Remove.
* psxcancel/psxcancel.scn: Remove.
* psxchroot01/.cvsignore: Remove.
* psxchroot01/Makefile.am: Remove.
* psxchroot01/main.c: Remove.
* psxchroot01/psxchroot01.scn: Remove.
* psxchroot01/test.c: Remove.
* psxfile01/.cvsignore: Remove.
* psxfile01/Makefile.am: Remove.
* psxfile01/main.c: Remove.
* psxfile01/psxfile01.scn: Remove.
* psxfile01/test.c: Remove.
* psxfile01/test_cat.c: Remove.
* psxfile01/test_extend.c: Remove.
* psxfile01/test_write.c: Remove.
* psxhdrs/.cvsignore: Remove.
* psxhdrs/Makefile.am: Remove.
* psxhdrs/clock01.c: Remove.
* psxhdrs/clock02.c: Remove.
* psxhdrs/clock03.c: Remove.
* psxhdrs/clock04.c: Remove.
* psxhdrs/clock05.c: Remove.
* psxhdrs/clock06.c: Remove.
* psxhdrs/cond01.c: Remove.
* psxhdrs/cond02.c: Remove.
* psxhdrs/cond03.c: Remove.
* psxhdrs/cond04.c: Remove.
* psxhdrs/cond05.c: Remove.
* psxhdrs/cond06.c: Remove.
* psxhdrs/cond07.c: Remove.
* psxhdrs/cond08.c: Remove.
* psxhdrs/cond09.c: Remove.
* psxhdrs/cond10.c: Remove.
* psxhdrs/key01.c: Remove.
* psxhdrs/key02.c: Remove.
* psxhdrs/key03.c: Remove.
* psxhdrs/key04.c: Remove.
* psxhdrs/mutex01.c: Remove.
* psxhdrs/mutex02.c: Remove.
* psxhdrs/mutex03.c: Remove.
* psxhdrs/mutex04.c: Remove.
* psxhdrs/mutex05.c: Remove.
* psxhdrs/mutex06.c: Remove.
* psxhdrs/mutex07.c: Remove.
* psxhdrs/mutex08.c: Remove.
* psxhdrs/mutex09.c: Remove.
* psxhdrs/mutex10.c: Remove.
* psxhdrs/mutex11.c: Remove.
* psxhdrs/mutex12.c: Remove.
* psxhdrs/mutex13.c: Remove.
* psxhdrs/mutex14.c: Remove.
* psxhdrs/mutex15.c: Remove.
* psxhdrs/mutex16.c: Remove.
* psxhdrs/proc01.c: Remove.
* psxhdrs/proc02.c: Remove.
* psxhdrs/proc03.c: Remove.
* psxhdrs/proc04.c: Remove.
* psxhdrs/proc05.c: Remove.
* psxhdrs/proc06.c: Remove.
* psxhdrs/proc07.c: Remove.
* psxhdrs/proc08.c: Remove.
* psxhdrs/proc09.c: Remove.
* psxhdrs/proc10.c: Remove.
* psxhdrs/proc11.c: Remove.
* psxhdrs/proc12.c: Remove.
* psxhdrs/proc13.c: Remove.
* psxhdrs/proc14.c: Remove.
* psxhdrs/pthread01.c: Remove.
* psxhdrs/pthread02.c: Remove.
* psxhdrs/pthread03.c: Remove.
* psxhdrs/pthread04.c: Remove.
* psxhdrs/pthread05.c: Remove.
* psxhdrs/pthread06.c: Remove.
* psxhdrs/pthread07.c: Remove.
* psxhdrs/pthread08.c: Remove.
* psxhdrs/pthread09.c: Remove.
* psxhdrs/pthread10.c: Remove.
* psxhdrs/pthread11.c: Remove.
* psxhdrs/pthread12.c: Remove.
* psxhdrs/pthread13.c: Remove.
* psxhdrs/pthread14.c: Remove.
* psxhdrs/pthread15.c: Remove.
* psxhdrs/pthread16.c: Remove.
* psxhdrs/pthread17.c: Remove.
* psxhdrs/pthread18.c: Remove.
* psxhdrs/pthread19.c: Remove.
* psxhdrs/pthread20.c: Remove.
* psxhdrs/pthread21.c: Remove.
* psxhdrs/pthread22.c: Remove.
* psxhdrs/pthread23.c: Remove.
* psxhdrs/pthread24.c: Remove.
* psxhdrs/pthread25.c: Remove.
* psxhdrs/pthread26.c: Remove.
* psxhdrs/pthread27.c: Remove.
* psxhdrs/pthread28.c: Remove.
* psxhdrs/pthread29.c: Remove.
* psxhdrs/pthread30.c: Remove.
* psxhdrs/pthread31.c: Remove.
* psxhdrs/pthread32.c: Remove.
* psxhdrs/pthread33.c: Remove.
* psxhdrs/pthread34.c: Remove.
* psxhdrs/pthread35.c: Remove.
* psxhdrs/pthread36.c: Remove.
* psxhdrs/sched01.c: Remove.
* psxhdrs/sched02.c: Remove.
* psxhdrs/sched03.c: Remove.
* psxhdrs/sched04.c: Remove.
* psxhdrs/sched05.c: Remove.
* psxhdrs/sched06.c: Remove.
* psxhdrs/sched07.c: Remove.
* psxhdrs/sched08.c: Remove.
* psxhdrs/signal01.c: Remove.
* psxhdrs/signal02.c: Remove.
* psxhdrs/signal03.c: Remove.
* psxhdrs/signal04.c: Remove.
* psxhdrs/signal05.c: Remove.
* psxhdrs/signal06.c: Remove.
* psxhdrs/signal07.c: Remove.
* psxhdrs/signal08.c: Remove.
* psxhdrs/signal09.c: Remove.
* psxhdrs/signal10.c: Remove.
* psxhdrs/signal11.c: Remove.
* psxhdrs/signal12.c: Remove.
* psxhdrs/signal13.c: Remove.
* psxhdrs/signal14.c: Remove.
* psxhdrs/signal15.c: Remove.
* psxhdrs/signal16.c: Remove.
* psxhdrs/signal17.c: Remove.
* psxhdrs/signal18.c: Remove.
* psxhdrs/signal19.c: Remove.
* psxhdrs/signal20.c: Remove.
* psxhdrs/signal21.c: Remove.
* psxhdrs/signal22.c: Remove.
* psxhdrs/signal23.c: Remove.
* psxhdrs/sync01.c: Remove.
* psxhdrs/sync02.c: Remove.
* psxhdrs/sync03.c: Remove.
* psxhdrs/time01.c: Remove.
* psxhdrs/time02.c: Remove.
* psxhdrs/time03.c: Remove.
* psxhdrs/time04.c: Remove.
* psxhdrs/time05.c: Remove.
* psxhdrs/time06.c: Remove.
* psxhdrs/time07.c: Remove.
* psxhdrs/time08.c: Remove.
* psxhdrs/time09.c: Remove.
* psxhdrs/time10.c: Remove.
* psxhdrs/time11.c: Remove.
* psxhdrs/time12.c: Remove.
* psxhdrs/time13.c: Remove.
* psxhdrs/timer01.c: Remove.
* psxhdrs/timer02.c: Remove.
* psxhdrs/timer03.c: Remove.
* psxhdrs/timer04.c: Remove.
* psxhdrs/timer05.c: Remove.
* psxhdrs/timer06.c: Remove.
* psxhdrs/timer07.c: Remove.
* psxmount/.cvsignore: Remove.
* psxmount/Makefile.am: Remove.
* psxmount/main.c: Remove.
* psxmount/psxmount.scn: Remove.
* psxmount/test.c: Remove.
* psxmsgq01/.cvsignore: Remove.
* psxmsgq01/Makefile.am: Remove.
* psxmsgq01/init.c: Remove.
* psxmsgq01/psxmsgq01.scn: Remove.
* psxmsgq01/system.h: Remove.
* psxreaddir/.cvsignore: Remove.
* psxreaddir/Makefile.am: Remove.
* psxreaddir/main.c: Remove.
* psxreaddir/psxreaddir.scn: Remove.
* psxreaddir/test.c: Remove.
* psxsem01/.cvsignore: Remove.
* psxsem01/Makefile.am: Remove.
* psxsem01/init.c: Remove.
* psxsem01/psxsem01.scn: Remove.
* psxsem01/system.h: Remove.
* psxstat/.cvsignore: Remove.
* psxstat/Makefile.am: Remove.
* psxstat/main.c: Remove.
* psxstat/psxstat.scn: Remove.
* psxstat/test.c: Remove.
* psxtime/.cvsignore: Remove.
* psxtime/Makefile.am: Remove.
* psxtime/main.c: Remove.
* psxtime/psxtime.scn: Remove.
* psxtime/test.c: Remove.
* psxtimer/.cvsignore: Remove.
* psxtimer/Makefile.am: Remove.
* psxtimer/psxtimer.c: Remove.
* psxtimer/psxtimer.scn: Remove.
* psxtimer/system.h: Remove.
* README: Remove.
* tmtests.am: Remove.
* tm01/.cvsignore: Remove.
* tm01/Makefile.am: Remove.
* tm01/system.h: Remove.
* tm01/task1.c: Remove.
* tm01/tm01.doc: Remove.
* tm02/.cvsignore: Remove.
* tm02/Makefile.am: Remove.
* tm02/system.h: Remove.
* tm02/task1.c: Remove.
* tm02/tm02.doc: Remove.
* tm03/.cvsignore: Remove.
* tm03/Makefile.am: Remove.
* tm03/system.h: Remove.
* tm03/task1.c: Remove.
* tm03/tm03.doc: Remove.
* tm04/.cvsignore: Remove.
* tm04/Makefile.am: Remove.
* tm04/system.h: Remove.
* tm04/task1.c: Remove.
* tm04/tm04.doc: Remove.
* tm05/.cvsignore: Remove.
* tm05/Makefile.am: Remove.
* tm05/system.h: Remove.
* tm05/task1.c: Remove.
* tm05/tm05.doc: Remove.
* tm06/.cvsignore: Remove.
* tm06/Makefile.am: Remove.
* tm06/system.h: Remove.
* tm06/task1.c: Remove.
* tm06/tm06.doc: Remove.
* tm07/.cvsignore: Remove.
* tm07/Makefile.am: Remove.
* tm07/system.h: Remove.
* tm07/task1.c: Remove.
* tm07/tm07.doc: Remove.
* tm08/.cvsignore: Remove.
* tm08/Makefile.am: Remove.
* tm08/system.h: Remove.
* tm08/task1.c: Remove.
* tm08/tm08.doc: Remove.
* tm09/.cvsignore: Remove.
* tm09/Makefile.am: Remove.
* tm09/system.h: Remove.
* tm09/task1.c: Remove.
* tm09/tm09.doc: Remove.
* tm10/.cvsignore: Remove.
* tm10/Makefile.am: Remove.
* tm10/system.h: Remove.
* tm10/task1.c: Remove.
* tm10/tm10.doc: Remove.
* tm11/.cvsignore: Remove.
* tm11/Makefile.am: Remove.
* tm11/system.h: Remove.
* tm11/task1.c: Remove.
* tm11/tm11.doc: Remove.
* tm12/.cvsignore: Remove.
* tm12/Makefile.am: Remove.
* tm12/system.h: Remove.
* tm12/task1.c: Remove.
* tm12/tm12.doc: Remove.
* tm13/.cvsignore: Remove.
* tm13/Makefile.am: Remove.
* tm13/system.h: Remove.
* tm13/task1.c: Remove.
* tm13/tm13.doc: Remove.
* tm14/.cvsignore: Remove.
* tm14/Makefile.am: Remove.
* tm14/system.h: Remove.
* tm14/task1.c: Remove.
* tm14/tm14.doc: Remove.
* tm15/.cvsignore: Remove.
* tm15/Makefile.am: Remove.
* tm15/system.h: Remove.
* tm15/task1.c: Remove.
* tm15/tm15.doc: Remove.
* tm16/.cvsignore: Remove.
* tm16/Makefile.am: Remove.
* tm16/system.h: Remove.
* tm16/task1.c: Remove.
* tm16/tm16.doc: Remove.
* tm17/.cvsignore: Remove.
* tm17/Makefile.am: Remove.
* tm17/system.h: Remove.
* tm17/task1.c: Remove.
* tm17/tm17.doc: Remove.
* tm18/.cvsignore: Remove.
* tm18/Makefile.am: Remove.
* tm18/system.h: Remove.
* tm18/task1.c: Remove.
* tm18/tm18.doc: Remove.
* tm19/.cvsignore: Remove.
* tm19/Makefile.am: Remove.
* tm19/system.h: Remove.
* tm19/task1.c: Remove.
* tm19/tm19.doc: Remove.
* tm20/.cvsignore: Remove.
* tm20/Makefile.am: Remove.
* tm20/system.h: Remove.
* tm20/task1.c: Remove.
* tm20/tm20.doc: Remove.
* tm21/.cvsignore: Remove.
* tm21/Makefile.am: Remove.
* tm21/system.h: Remove.
* tm21/task1.c: Remove.
* tm21/tm21.doc: Remove.
* tm22/.cvsignore: Remove.
* tm22/Makefile.am: Remove.
* tm22/system.h: Remove.
* tm22/task1.c: Remove.
* tm22/tm22.doc: Remove.
* tm23/.cvsignore: Remove.
* tm23/Makefile.am: Remove.
* tm23/system.h: Remove.
* tm23/task1.c: Remove.
* tm23/tm23.doc: Remove.
* tm24/.cvsignore: Remove.
* tm24/Makefile.am: Remove.
* tm24/system.h: Remove.
* tm24/task1.c: Remove.
* tm24/tm24.doc: Remove.
* tm25/.cvsignore: Remove.
* tm25/Makefile.am: Remove.
* tm25/system.h: Remove.
* tm25/task1.c: Remove.
* tm25/tm25.doc: Remove.
* tm26/.cvsignore: Remove.
* tm26/Makefile.am: Remove.
* tm26/fptest.h: Remove.
* tm26/system.h: Remove.
* tm26/task1.c: Remove.
* tm26/tm26.doc: Remove.
* tm27/.cvsignore: Remove.
* tm27/Makefile.am: Remove.
* tm27/system.h: Remove.
* tm27/task1.c: Remove.
* tm27/tm27.doc: Remove.
* tm28/.cvsignore: Remove.
* tm28/Makefile.am: Remove.
* tm28/system.h: Remove.
* tm28/task1.c: Remove.
* tm28/tm28.doc: Remove.
* tm29/.cvsignore: Remove.
* tm29/Makefile.am: Remove.
* tm29/system.h: Remove.
* tm29/task1.c: Remove.
* tm29/tm29.doc: Remove.
* tmck/.cvsignore: Remove.
* tmck/Makefile.am: Remove.
* tmck/system.h: Remove.
* tmck/task1.c: Remove.
* tmck/tmck.doc: Remove.
* tmoverhd/.cvsignore: Remove.
* tmoverhd/Makefile.am: Remove.
* tmoverhd/dumrtems.h: Remove.
* tmoverhd/empty.c: Remove.
* tmoverhd/system.h: Remove.
* tmoverhd/testtask.c: Remove.
* tmoverhd/tmoverhd.doc: Remove.
* sp01/.cvsignore: Remove.
* sp01/Makefile.am: Remove.
* sp01/init.c: Remove.
* sp01/sp01.doc: Remove.
* sp01/sp01.scn: Remove.
* sp01/system.h: Remove.
* sp01/task1.c: Remove.
* sp02/.cvsignore: Remove.
* sp02/Makefile.am: Remove.
* sp02/init.c: Remove.
* sp02/preempt.c: Remove.
* sp02/sp02.doc: Remove.
* sp02/sp02.scn: Remove.
* sp02/system.h: Remove.
* sp02/task1.c: Remove.
* sp02/task2.c: Remove.
* sp02/task3.c: Remove.
* README: Remove.
* sptests.am: Remove.
* sp03/.cvsignore: Remove.
* sp03/Makefile.am: Remove.
* sp03/init.c: Remove.
* sp03/sp03.doc: Remove.
* sp03/sp03.scn: Remove.
* sp03/system.h: Remove.
* sp03/task1.c: Remove.
* sp03/task2.c: Remove.
* sp04/.cvsignore: Remove.
* sp04/Makefile.am: Remove.
* sp04/init.c: Remove.
* sp04/sp04.doc: Remove.
* sp04/sp04.scn: Remove.
* sp04/system.h: Remove.
* sp04/task1.c: Remove.
* sp04/task2.c: Remove.
* sp04/task3.c: Remove.
* sp04/tswitch.c: Remove.
* sp05/.cvsignore: Remove.
* sp05/Makefile.am: Remove.
* sp05/init.c: Remove.
* sp05/sp05.doc: Remove.
* sp05/sp05.scn: Remove.
* sp05/system.h: Remove.
* sp05/task1.c: Remove.
* sp05/task2.c: Remove.
* sp05/task3.c: Remove.
* sp06/.cvsignore: Remove.
* sp06/Makefile.am: Remove.
* sp06/init.c: Remove.
* sp06/sp06.doc: Remove.
* sp06/sp06.scn: Remove.
* sp06/system.h: Remove.
* sp06/task1.c: Remove.
* sp06/task2.c: Remove.
* sp06/task3.c: Remove.
* sp07/.cvsignore: Remove.
* sp07/Makefile.am: Remove.
* sp07/init.c: Remove.
* sp07/sp07.doc: Remove.
* sp07/sp07.scn: Remove.
* sp07/system.h: Remove.
* sp07/task1.c: Remove.
* sp07/task2.c: Remove.
* sp07/task3.c: Remove.
* sp07/task4.c: Remove.
* sp07/taskexit.c: Remove.
* sp07/tcreate.c: Remove.
* sp07/tdelete.c: Remove.
* sp07/trestart.c: Remove.
* sp07/tstart.c: Remove.
* sp08/.cvsignore: Remove.
* sp08/Makefile.am: Remove.
* sp08/init.c: Remove.
* sp08/sp08.doc: Remove.
* sp08/sp08.scn: Remove.
* sp08/system.h: Remove.
* sp08/task1.c: Remove.
* sp09/.cvsignore: Remove.
* sp09/Makefile.am: Remove.
* sp09/delay.c: Remove.
* sp09/init.c: Remove.
* sp09/isr.c: Remove.
* sp09/screen01.c: Remove.
* sp09/screen02.c: Remove.
* sp09/screen03.c: Remove.
* sp09/screen04.c: Remove.
* sp09/screen05.c: Remove.
* sp09/screen06.c: Remove.
* sp09/screen07.c: Remove.
* sp09/screen08.c: Remove.
* sp09/screen09.c: Remove.
* sp09/screen10.c: Remove.
* sp09/screen11.c: Remove.
* sp09/screen12.c: Remove.
* sp09/screen13.c: Remove.
* sp09/screen14.c: Remove.
* sp09/sp09.doc: Remove.
* sp09/sp09.scn: Remove.
* sp09/system.h: Remove.
* sp09/task1.c: Remove.
* sp09/task2.c: Remove.
* sp09/task3.c: Remove.
* sp09/task4.c: Remove.
* sp11/.cvsignore: Remove.
* sp11/Makefile.am: Remove.
* sp11/init.c: Remove.
* sp11/sp11.doc: Remove.
* sp11/sp11.scn: Remove.
* sp11/system.h: Remove.
* sp11/task1.c: Remove.
* sp11/task2.c: Remove.
* sp11/timer.c: Remove.
* sp12/.cvsignore: Remove.
* sp12/Makefile.am: Remove.
* sp12/init.c: Remove.
* sp12/pridrv.c: Remove.
* sp12/pritask.c: Remove.
* sp12/sp12.doc: Remove.
* sp12/sp12.scn: Remove.
* sp12/system.h: Remove.
* sp12/task1.c: Remove.
* sp12/task2.c: Remove.
* sp12/task3.c: Remove.
* sp12/task4.c: Remove.
* sp12/task5.c: Remove.
* sp13/.cvsignore: Remove.
* sp13/Makefile.am: Remove.
* sp13/fillbuff.c: Remove.
* sp13/init.c: Remove.
* sp13/putbuff.c: Remove.
* sp13/sp13.doc: Remove.
* sp13/sp13.scn: Remove.
* sp13/system.h: Remove.
* sp13/task1.c: Remove.
* sp13/task2.c: Remove.
* sp13/task3.c: Remove.
* sp14/.cvsignore: Remove.
* sp14/Makefile.am: Remove.
* sp14/asr.c: Remove.
* sp14/init.c: Remove.
* sp14/sp14.doc: Remove.
* sp14/sp14.scn: Remove.
* sp14/system.h: Remove.
* sp14/task1.c: Remove.
* sp14/task2.c: Remove.
* sp15/.cvsignore: Remove.
* sp15/Makefile.am: Remove.
* sp15/init.c: Remove.
* sp15/sp15.doc: Remove.
* sp15/sp15.scn: Remove.
* sp15/system.h: Remove.
* sp15/task1.c: Remove.
* sp16/.cvsignore: Remove.
* sp16/Makefile.am: Remove.
* sp16/init.c: Remove.
* sp16/sp16.doc: Remove.
* sp16/sp16.scn: Remove.
* sp16/system.h: Remove.
* sp16/task1.c: Remove.
* sp16/task2.c: Remove.
* sp16/task3.c: Remove.
* sp16/task4.c: Remove.
* sp16/task5.c: Remove.
* sp17/.cvsignore: Remove.
* sp17/Makefile.am: Remove.
* sp17/asr.c: Remove.
* sp17/init.c: Remove.
* sp17/sp17.doc: Remove.
* sp17/sp17.scn: Remove.
* sp17/system.h: Remove.
* sp17/task1.c: Remove.
* sp17/task2.c: Remove.
* sp19/.cvsignore: Remove.
* sp19/Makefile.am: Remove.
* sp19/first.c: Remove.
* sp19/fptask.c: Remove.
* sp19/fptest.h: Remove.
* sp19/init.c: Remove.
* sp19/inttest.h: Remove.
* sp19/sp19.doc: Remove.
* sp19/sp19.scn: Remove.
* sp19/system.h: Remove.
* sp19/task1.c: Remove.
* sp20/.cvsignore: Remove.
* sp20/Makefile.am: Remove.
* sp20/getall.c: Remove.
* sp20/init.c: Remove.
* sp20/sp20.doc: Remove.
* sp20/sp20.scn: Remove.
* sp20/system.h: Remove.
* sp20/task1.c: Remove.
* sp21/.cvsignore: Remove.
* sp21/Makefile.am: Remove.
* sp21/init.c: Remove.
* sp21/sp21.doc: Remove.
* sp21/sp21.scn: Remove.
* sp21/system.h: Remove.
* sp21/task1.c: Remove.
* sp22/.cvsignore: Remove.
* sp22/Makefile.am: Remove.
* sp22/delay.c: Remove.
* sp22/init.c: Remove.
* sp22/prtime.c: Remove.
* sp22/sp22.doc: Remove.
* sp22/sp22.scn: Remove.
* sp22/system.h: Remove.
* sp22/task1.c: Remove.
* sp23/.cvsignore: Remove.
* sp23/Makefile.am: Remove.
* sp23/init.c: Remove.
* sp23/sp23.doc: Remove.
* sp23/sp23.scn: Remove.
* sp23/system.h: Remove.
* sp23/task1.c: Remove.
* sp24/.cvsignore: Remove.
* sp24/Makefile.am: Remove.
* sp24/init.c: Remove.
* sp24/resume.c: Remove.
* sp24/sp24.doc: Remove.
* sp24/sp24.scn: Remove.
* sp24/system.h: Remove.
* sp24/task1.c: Remove.
* sp25/.cvsignore: Remove.
* sp25/Makefile.am: Remove.
* sp25/init.c: Remove.
* sp25/sp25.doc: Remove.
* sp25/sp25.scn: Remove.
* sp25/system.h: Remove.
* sp25/task1.c: Remove.
* sp26/.cvsignore: Remove.
* sp26/Makefile.am: Remove.
* sp26/init.c: Remove.
* sp26/sp26.doc: Remove.
* sp26/sp26.scn: Remove.
* sp26/system.h: Remove.
* sp26/task1.c: Remove.
* sp27/.cvsignore: Remove.
* sp27/Makefile.am: Remove.
* sp27/init.c: Remove.
* sp27/sp27.doc: Remove.
* sp27/sp27.scn: Remove.
* sp28/.cvsignore: Remove.
* sp28/Makefile.am: Remove.
* sp28/init.c: Remove.
* sp28/sp28.doc: Remove.
* sp28/sp28.scn: Remove.
* sp29/.cvsignore: Remove.
* sp29/Makefile.am: Remove.
* sp29/init.c: Remove.
* sp29/sp29.doc: Remove.
* sp29/sp29.scn: Remove.
* sp30/.cvsignore: Remove.
* sp30/Makefile.am: Remove.
* sp30/init.c: Remove.
* sp30/resume.c: Remove.
* sp30/sp30.doc: Remove.
* sp30/sp30.scn: Remove.
* sp30/system.h: Remove.
* sp30/task1.c: Remove.
* sp31/.cvsignore: Remove.
* sp31/Makefile.am: Remove.
* sp31/delay.c: Remove.
* sp31/init.c: Remove.
* sp31/prtime.c: Remove.
* sp31/sp31.doc: Remove.
* sp31/sp31.scn: Remove.
* sp31/system.h: Remove.
* sp31/task1.c: Remove.
* sp32/.cvsignore: Remove.
* sp32/Makefile.am: Remove.
* sp32/init.c: Remove.
* sp32/sp32.scn: Remove.
* spfatal/.cvsignore: Remove.
* spfatal/Makefile.am: Remove.
* spfatal/README: Remove.
* spfatal/fatal.c: Remove.
* spfatal/init.c: Remove.
* spfatal/puterr.c: Remove.
* spfatal/spfatal.doc: Remove.
* spfatal/spfatal.scn: Remove.
* spfatal/system.h: Remove.
* spfatal/task1.c: Remove.
* spsize/.cvsignore: Remove.
* spsize/Makefile.am: Remove.
* spsize/getint.c: Remove.
* spsize/init.c: Remove.
* spsize/size.c: Remove.
* spsize/size.scn: Remove.
* spsize/system.h: Remove.
* base_mp/node1/.cvsignore: Remove.
* base_mp/node1/Makefile.am: Remove.
* base_mp/node1/base_mp.doc: Remove.
* base_mp/node1/base_mp.scn: Remove.
* base_mp/.cvsignore: Remove.
* base_mp/Makefile.am: Remove.
* base_mp/apptask.c: Remove.
* base_mp/init.c: Remove.
* base_mp/system.h: Remove.
* base_mp/node2/.cvsignore: Remove.
* base_mp/node2/Makefile.am: Remove.
* base_mp/node2/base_mp.doc: Remove.
* base_mp/node2/base_mp.scn: Remove.
* README: Remove.
* sample.am: Remove.
* base_sp/.cvsignore: Remove.
* base_sp/Makefile.am: Remove.
* base_sp/apptask.c: Remove.
* base_sp/base_sp.doc: Remove.
* base_sp/base_sp.scn: Remove.
* base_sp/init.c: Remove.
* base_sp/system.h: Remove.
* cdtest/.cvsignore: Remove.
* cdtest/Makefile.am: Remove.
* cdtest/cdtest.scn: Remove.
* cdtest/init.c: Remove.
* cdtest/main.cc: Remove.
* cdtest/system.h: Remove.
* fileio/.cvsignore: Remove.
* fileio/Makefile.am: Remove.
* fileio/fileio.doc: Remove.
* fileio/init.c: Remove.
* fileio/system.h: Remove.
* hello/.cvsignore: Remove.
* hello/Makefile.am: Remove.
* hello/hello.doc: Remove.
* hello/hello.scn: Remove.
* hello/init.c: Remove.
* hello/system.h: Remove.
* loopback/.cvsignore: Remove.
* loopback/Makefile.am: Remove.
* loopback/README: Remove.
* loopback/init.c: Remove.
* loopback/loopback.scn: Remove.
* minimum/.cvsignore: Remove.
* minimum/Makefile.am: Remove.
* minimum/init.c: Remove.
* minimum/minimum.doc: Remove.
* minimum/minimum.scn: Remove.
* paranoia/.cvsignore: Remove.
* paranoia/Makefile.am: Remove.
* paranoia/init.c: Remove.
* paranoia/paranoia.c: Remove.
* paranoia/paranoia.doc: Remove.
* paranoia/system.h: Remove.
* pppd/.cvsignore: Remove.
* pppd/Makefile-user: Remove.
* pppd/Makefile.am: Remove.
* pppd/README: Remove.
* pppd/init.c: Remove.
* pppd/netconfig.h: Remove.
* pppd/ppp.conf: Remove.
* pppd/pppd.options: Remove.
* pppd/pppdapp.c: Remove.
* pppd/system.h: Remove.
* ticker/.cvsignore: Remove.
* ticker/Makefile.am: Remove.
* ticker/init.c: Remove.
* ticker/system.h: Remove.
* ticker/tasks.c: Remove.
* ticker/ticker.doc: Remove.
* ticker/ticker.scn: Remove.
* unlimited/.cvsignore: Remove.
* unlimited/Makefile.am: Remove.
* unlimited/init.c: Remove.
* unlimited/system.h: Remove.
* unlimited/test1.c: Remove.
* unlimited/test2.c: Remove.
* unlimited/test3.c: Remove.
* unlimited/unlimited.doc: Remove.
* unlimited/unlimited.scn: Remove.
* cpuuse/.cvsignore: Remove.
* cpuuse/Makefile.am: Remove.
* cpuuse/cpuuse.scn: Remove.
* cpuuse/init.c: Remove.
* cpuuse/system.h: Remove.
* cpuuse/task1.c: Remove.
* cpuuse/task2.c: Remove.
* cpuuse/task3.c: Remove.
* cpuuse/tswitch.c: Remove.
* README: Remove.
* libtests.am: Remove.
* malloctest/.cvsignore: Remove.
* malloctest/Makefile.am: Remove.
* malloctest/init.c: Remove.
* malloctest/malloctest.scn: Remove.
* malloctest/system.h: Remove.
* malloctest/task1.c: Remove.
* monitor/.cvsignore: Remove.
* monitor/Makefile.am: Remove.
* monitor/init.c: Remove.
* monitor/system.h: Remove.
* putenvtest/.cvsignore: Remove.
* putenvtest/Makefile.am: Remove.
* putenvtest/init.c: Remove.
* rtems++/.cvsignore: Remove.
* rtems++/Init.cc: Remove.
* rtems++/Makefile.am: Remove.
* rtems++/System.h: Remove.
* rtems++/Task1.cc: Remove.
* rtems++/Task2.cc: Remove.
* rtems++/Task3.cc: Remove.
* rtems++/rtems++.doc: Remove.
* rtems++/rtems++.scn: Remove.
* rtmonuse/.cvsignore: Remove.
* rtmonuse/Makefile.am: Remove.
* rtmonuse/getall.c: Remove.
* rtmonuse/init.c: Remove.
* rtmonuse/rtmonuse.scn: Remove.
* rtmonuse/system.h: Remove.
* rtmonuse/task1.c: Remove.
* stackchk/.cvsignore: Remove.
* stackchk/Makefile.am: Remove.
* stackchk/blow.c: Remove.
* stackchk/init.c: Remove.
* stackchk/stackchk.scn: Remove.
* stackchk/system.h: Remove.
* stackchk/task1.c: Remove.
* termios/.cvsignore: Remove.
* termios/Makefile.am: Remove.
* termios/README: Remove.
* termios/init.c: Remove.
* itronhello/.cvsignore: Remove.
* itronhello/Makefile.am: Remove.
* itronhello/init.c: Remove.
* itronhello/itronhello.doc: Remove.
* itronhello/itronhello.scn: Remove.
* itronhello/system.h: Remove.
* README: Remove.
* itrontests.am: Remove.
* itronmbf01/.cvsignore: Remove.
* itronmbf01/Makefile.am: Remove.
* itronmbf01/init.c: Remove.
* itronmbf01/itronmbf01.doc: Remove.
* itronmbf01/itronmbf01.scn: Remove.
* itronmbf01/system.h: Remove.
* itronmbox01/.cvsignore: Remove.
* itronmbox01/Makefile.am: Remove.
* itronmbox01/init.c: Remove.
* itronmbox01/itronmbox01.doc: Remove.
* itronmbox01/itronmbox01.scn: Remove.
* itronmbox01/system.h: Remove.
* itronsem01/.cvsignore: Remove.
* itronsem01/Makefile.am: Remove.
* itronsem01/init.c: Remove.
* itronsem01/itronsem01.doc: Remove.
* itronsem01/itronsem01.scn: Remove.
* itronsem01/system.h: Remove.
* itrontask01/.cvsignore: Remove.
* itrontask01/Makefile.am: Remove.
* itrontask01/init.c: Remove.
* itrontask01/itrontask01.doc: Remove.
* itrontask01/itrontask01.scn: Remove.
* itrontask01/system.h: Remove.
* itrontask01/task1.c: Remove.
* itrontask02/.cvsignore: Remove.
* itrontask02/Makefile.am: Remove.
* itrontask02/dormant.c: Remove.
* itrontask02/init.c: Remove.
* itrontask02/itrontask02.doc: Remove.
* itrontask02/itrontask02.scn: Remove.
* itrontask02/system.h: Remove.
* itrontask03/.cvsignore: Remove.
* itrontask03/Makefile.am: Remove.
* itrontask03/init.c: Remove.
* itrontask03/itrontask03.doc: Remove.
* itrontask03/itrontask03.scn: Remove.
* itrontask03/preempt.c: Remove.
* itrontask03/system.h: Remove.
* itrontask03/task1.c: Remove.
* itrontask03/task2.c: Remove.
* itrontask03/task3.c: Remove.
* itrontask04/.cvsignore: Remove.
* itrontask04/Makefile.am: Remove.
* itrontask04/init.c: Remove.
* itrontask04/itrontask04.doc: Remove.
* itrontask04/itrontask04.scn: Remove.
* itrontask04/system.h: Remove.
* itrontask04/task1.c: Remove.
* itrontask04/task2.c: Remove.
* itrontask04/task3.c: Remove.
* itrontime01/.cvsignore: Remove.
* itrontime01/Makefile.am: Remove.
* itrontime01/init.c: Remove.
* itrontime01/itrontime01.doc: Remove.
* itrontime01/itrontime01.scn: Remove.
* itrontime01/system.h: Remove.
* README: Remove.
* include/buffer_test_io.h: Remove.
* include/tmacros.h: Remove.
* README: Remove.
* README: Remove.
* README: Remove.
* README: Remove.
* README: Remove.
* README: Remove.
* configure.ac: Reflect having moved tests to ../../testsuites.
* configure.ac: Reflect having moved to testsuites/.
* gcc3newlib/gccnewlib.add: Make not building gnat and gcj the
default for gcc-3.3.
* config-ml.in: Don't built multilib variant normal (-mn) for
h8300-*-rtems*.
* acinclude.m4: Merge-in former ../aclocal/config-subdirs.m4.
* configure.ac: remove RTEMS_CANONICAL_HOST.
* mongoosev/Makefile.am: Rework preinstall rules.
* mongoosev/duart/Makefile.am: Rework preinstall rules.
* tx39/include/Makefile.am: Remove.
* tx39/Makefile.am: Merge-in tx39/include/Makefile.am.
* configure.ac: Remove tx39/include/Makefile.
* Makefile.am: Fix stupid typo in previous patch.
* Makefile.am: Fix preinstallation of include/coverhd.h.
* aclocal/rtems-top.m4: Add support for --with-project-root.
Remove RTEMS Version message.
* binutils/Makefile.am: Add tic4x.
* binutils/mkspec.in: Remove duplicate rpmgroup.
* aclocal/canonical-host.m4: Remove.
* Makefile.am: Don't explictly invoke $MAKE preinstall.
* configure.ac: Add AM_CONDITIONAL(LIBCHIP).
* fileio/Makefile.am: Only build if LIBCHIP is available.
* src/regiongetsegment.c: Remove unneccessary typecast in assignment
to thread->Wait.return_argment.
* gcc3newlib/Makefile.am: Add tic4x.
* gcc3newlib/gccnewlib.add: Don't install install-tools for
gcc >= 3.3.
PR 515/filesystem
* src/dosfs/fat_fat_operations.c: Remove commented out code.
