* devnull/devnull.c: Eliminate warning.
* src/sysconf.c: Fix typo syntax error accidentally committed.
* setup.def, gccnewlib/gccnewlib.add, gccnewlib/target-gcc.add:
Revert changes because of gcc 2.5.x/3.0 transition and continue
to support gcc 2.95.x as primary version.
* configure.in: Add RTEMS specific version of EXEEXT test.
* mkgdbspec.in, mkgnatnewlibspec.in, gdb/gdb.spec.in,
gnatnewlib/gnatnewlib.spec.in: Change to Target_alias to avoid
conflicts with new autoconf/automake.
* setup, setup.def, mkgnatnewlibspec.in: Add gnat_newlib_patch_version
variable.
* gnatnewlib/Makefile.am: Add i386-rtemscoff target in attempt to
build it.
* mkgccnewlibspec.in,
Use Target_alias not target_alias to avoid conflicts with new autoconf.
* setup.def: Changed version numbers in attempt at building gcc 3.0.1.
Only sparc and arm built for C/C++ OK. :(
* gccnewlib/base-gcc.add: Modifications to reflect files not in gcc 3.x.
* gccnewlib/gccnewlib.add: gcc 3.x does not have "everything in the name"
* target-gcc.add: Modifications to reflect files not in gcc 3.1
* configure.in: autoupdate to autoconf-2.52, new CONFIG_SUBDIRS
handling.
* src/mprotect.c: New file. Stub required by some gcc's to pass tests.
In particular, about 350 ACATS tests fail if this is not present.
* src/getpagesize.c: Ditto.
* src/sysconf.c: Addition of Solaris value for _SC_STACK_PROT required
to pass about 350 ACATS test cases.
* src/Makefile.am: Added new files.
* missing: Updated to latest version.
* configure.in: autoupdate to autoconf-2.52.
* bootstrap: Add handling for configure.ac, make autoheader verbose,
fix auto*tool invocation order.
* aclocal/rtems-test-no-pause.m4: Introduce AC_HELP_STRING.
* aclocal/enable-bare.m4: Introduce AC_HELP_STRING.
* aclocal/enable-cxx.m4: Introduce AC_HELP_STRING.
* aclocal/enable-gcc28: Introduce AC_HELP_STRING.
* aclocal/enable-inlines.m4: Introduce AC_HELP_STRING.
* aclocal/enable-itron.m4: Introduce AC_HELP_STRING.
* aclocal/enable-libcdir.m4: Introduce AC_HELP_STRING.
* aclocal/enable-multiprocessing.m4: Introduce AC_HELP_STRING.
* aclocal/enable-networking.m4: Introduce AC_HELP_STRING.
* aclocal/enable-posix.m4: Introduce AC_HELP_STRING.
* aclocal/enable-rdbg.m4: Introduce AC_HELP_STRING.
* aclocal/enable-rtemsbsp.m4: Introduce AC_HELP_STRING.
* aclocal/enable-tests.m4: Introduce AC_HELP_STRING.
* aclocal/env-rtemsbsp.m4: Add AC_ARC_VAR(RTEMS_BSP), apply true in
RTEMS_CONFIG_PER_BSP conditional.
* aclocal/multilib.m4: Introduce AC_HELP_STRING.
* aclocal/rtems-debug.m4: Introduce AC_HELP_STRING.
* aclocal/rtems-top.m4: Add AC_PREFIX_DEFAULT(/opt/rtems).
* autotools/.cvsignore: New file.
* .cvsignore: Corrected for missing files.
* autotools/Makefile.am, autotools/autoconf-rtems.spec,
autotools/automake-rtems.spec: New.
* configure.in, Makefile.am: Add autotools/.
* .cvsignore: Missed in previous commit.
* Makefile.am, .cvsignore, configure.in, i386-cygwin-binutils.spec.in,
i386-cygwin-gcc.spec.in, i386-cygwin-libs.spec.in,
i386-cygwin-w32api.spec.in, i386-cygwin-mingw.spec.in, setup, setup.def:
New files that support building RPMs for Linux hosted cross compilers
targeting Cygwin.
* network/network.c: Fix to account for return value when
installing interrupts handler.
* startup/linkcmds: Modified to work better with gcc 2.8.1 and
gnat 3.13p.
* src/coremutex.c, src/coremutexseize.c, src/coremutexsurrender.c,
inline/rtems/score/coremutex.inl: The per thread field resource_count
should only be manipulated when a mutex is priority ceiling or
priority inherit. This was reported by Chris Johns <ccj@acm.org>
who also noticed that the use of switches for all disciplines
generated less efficient code than using explicit tests for the one
or two cases we were really interested in. Further review of his
modifications made it apparent that the "isa" methods to test mutex
discipline were not being used so this modification was swept into
the code as well.
* inline/rtems/rtems/attr.inl: Correct typo and use correct
attribute RTEMS_SYSTEM_TASK. Reported by Chris Johns <ccj@acm.org>.
* src/coremutexseize.c: Add missing code for proper handling
of nesting acquisitions. This only impacts building with
inlines disabled on the source with the "fast mutex" optimizations.
This was post the 4.5 branch and did not impact released versions.
* .cvsignore: Add buildalltar.
* buildalltar.in: New file.
* configure.in, Makefile.am: Modified to reflect addition of file.
* macros/rtems/posix/mqueue.inl: Add cast so negation works.
* include/Makefile.am: Include coverhd.h so tmtests will compile.
* include/rtems/libio_.h: Added ifdef to ensure that LOGIN_NAME_MAX
is defined on GNU/Linux (RedHat 6.2 distribution).
* libc/unixlibc.c: Added stubs for rtems_io_register_name() and
rtems_io_lookup_name() so UNIX port would compile the IO manager
sptest that registers /dev/null.
* pppd/STATUS: Updated by Joel based upon email from Mike.
* pppd/cbcp.c, pppd/cbcp.h: Readded files. These support callback
functionality that has not even been compiled under RTEMS yet.
* score/cpu_asm.c (sh_set_irq_priority): Changed interrupt vector
number range check and handling of interrupt priority regs to
conform SH2 specs.
* sci/sci_termios.c: New file.
* include/sci_termios.h: New file.
* include/Makefile.am (EXTRA_DIST): Added sci_termios.h.
(include_sh_HEADERS): Added sci_termios.h.
* score/ispsh7045.c (isp): Calling an ISR with immediate argument
casued negative sign extension for vector numbers of 128 and
above. This was fixed.
* sci/sci.c: Cleaned initialization of SCI registers; added
necessary setup for new TERMIOS console cooperation
* libc/lseek.c: Modified after discussion with Eugeny S. Mints
<jack@oktet.ru> to correct the behavior. There were two mistakes.
First, iop->offset was incorrectly set for SEEK_END. Second,
iop->offset should be left unmodified if there are errors.
This modification attempts to fix both situations.
conform SH2 specs.
* include/bsp.h: Disabled redefinition of
CONSOLE_DRIVER_TABLE_ENTRY. Some "FIXME:" comments added.
* console/config.c: New file. Definitions of externs referenced
from libbsp/shared/console.c.
* console/Makefile.am: Changed VPATH to point to
libbsp/shared. Added config.c to C_FILES and EXTRA_DIST.
* mw-fb\Makefile.am: Corrected problem.
* cpu.c (_CPU_ISR_install_vector): Corrected interrupt range
checking which was SH1 specific. It didn't work for SH2 (has more
interrupt sources).
conform SH2 specs.
* pppd/example/Makefile: Removed.
* pppd/example/Makefile-user: Added was Makefile. Renamed to
avoid bootstrap -c clobbering it.
* libc/termios.c: Fix a bug in the termios implementation in
the following scenario:
The General Terminal Interface document that me states that
if VMIN = 0 and VTIME = 0, then read() should return the minimum
of two values:
a) number of bytes available
b) number of bytes requested (I assume from the read call)
The current implementation of the fillBufferQueue() in termios.c is
always return 1 character with these setting values. I know the
termios buffer has more than one character available and my read()
call is requesting 1024 bytes.
* comm/tty_drv.c, comm/uart.c: Correct some minor cut and paste bugs.
* include/rtems/termiostypes.h, include/sys/ioccom.h:
Update of PPPD to 2.3.11 from 2.3.5 touched these files.
* Update of PPPD to 2.3.11 from 2.3.5 and addition of an example
application. Mike's notes on the modifications:
- renamed error() function because of namespace problems
- removed calls to the exit() funciton
- removed extra files from the pppd source directory
- defined pppd task constant values in rtemspppd.h
- modifyied example code to get actual tick per second value
- placed the pppd 2.3.11 man page file (pppd.8) into the pppd
directory
* pppd/cbcp.c, pppd/cbcp.h, pppd/main.c, pppd/ppp_tty.c,
pppd/pppmain.c, pppd/rtems-ppp.c, pppd/rtems-ppp.c: Deleted.
* pppd/pppd.8, pppd/rtemsmain.c, pppd/rtemspppd.c, pppd/rtemspppd.h,
pppd/sys-rtems.c, pppd/utils.c, pppd/example/Makefile,
pppd/example/README, pppd/example/init.c, pppd/example/netconfig.h,
pppd/example/ppp.conf, pppd/example/pppdapp.c, pppd/example/system.h:
New files.
* modem/ppp_tty.c, net/if_ppp.h, pppd/Makefile.am, pppd/README,
pppd/STATUS, pppd/auth.c, pppd/ccp.c, pppd/ccp.h, pppd/chap.c,
pppd/chap.h, pppd/chap_ms.c, pppd/chap_ms.h, pppd/chat.c,
pppd/demand.c, pppd/fsm.c, pppd/fsm.h, pppd/ipcp.c, pppd/ipcp.h,
pppd/ipxcp.c, pppd/ipxcp.h, pppd/lcp.c, pppd/lcp.h, pppd/magic.c,
pppd/magic.h, pppd/options.c, pppd/patchlevel.h,
pppd/pathnames.h, pppd/pppd.h, pppd/upap.c, pppd/upap.h: Modified.
of two values:
* clock/clock.c: Ensure that clock ticks are long enough to
make forward progress. This was modified to improve results
on the RTEMS tests and the ACATS.
gnat 3.13p.
* src/msgqsubmit.c: Add a comment indicating that we do not have
to account for possibly blocking during the core send operation
because Classic API message queue send is always non-blocking.
* src/mqueuesendsupp.c: Account for possibly blocking during the
core send operation.
* setup.def, gnatnewlib/gnatnewlib.spec.in: Modified to properly
build gnat 3.13p-2 RPMs. These were used to run the ACATS with
the following results on the powepc-rtems/psim:
acats4gnat results cz 3 / 4
acats4gnat results a 75 / 75
acats4gnat results c2 35 / 35
acats4gnat results c3 347 / 349
acats4gnat results c4 333 / 338
acats4gnat results c5 95 / 95
acats4gnat results c6 81 / 81
acats4gnat results c7 47 / 50
acats4gnat results c8 140 / 140
acats4gnat results c9 246 / 255
acats4gnat results ca 73 / 74
acats4gnat results cb 43 / 43
acats4gnat results cc 117 / 117
acats4gnat results cd 172 / 172
acats4gnat results ce 262 / 268
acats4gnat results cxa 85 / 85
acats4gnat results cxb 29 / 30
acats4gnat results cxc 9 / 16
acats4gnat results cxd 27 / 39
acats4gnat results cxe 1 / 1
acats4gnat results cxf 20 / 20
acats4gnat results cxg 28 / 29
acats4gnat results cxh 4 / 4
acats4gnat results d 4 / 4
acats4gnat results e 11 / 11
acats4gnat results l 26 / 26
This compares favorably with the results on Linux. Laurent
Guerby's <guerby@acm.org> acats4gnat-0.2 scripts were used
with minor modifications to support cross testing.
* include/tmacros.h: Attempt to print errno as further information.
* sp20/system.h: Account for extra task stacks properly.
* sp13/sp13.scn: Id in screen had wrong class field value.
* sp13/system.h: Account for message buffer memory.
* sp13/task2.c: Remove unnecessary check for failure.
* tools/runtest.in: Recognize debug variant of monitor test.
