* gdb/gdb.add, gdb/mkspec.in, gdb/target-gdb.add: Use RPM logic to
determine which targets have simulators, configure with appropriate
arguments, and package the correct files.
* i386-cygwin-gcc.spec.in: Use %_prefix instead of %prefix.
Add gnatlib.
Add %defattr(-,root,root).
Provide virtual packages i386-cygwin-[c++|g++|gnat].
* gcc3newlib/target-gcc.add: Remove %{_exeext} from gccbug.
* gcc3newlib/gccnewlib.add: Add %gcj to support to disabling building
gcj from rpmbuild command line.
Copy gsyslimits.h for CDN-X compilation.
* README.configure: Updated to reflect new BSPs and deprecated
targets.
* pppd/chat.c: Convert routines with common names to static. This
included get_char(), put_char(), and character() among others.
* m68360.h: Correct the order of fields in the ethernet structure
to account for the typo in MC68360UM (page 7-248).
PR 342/networking
* kern/uipc_mbuf.c: The RTEMS version of the m_copyback is changing
the m_len value of the mbuf. I looked into the source from another
BSD system and the mbuf length is not changed inside this function.
The m_copyback function is only being used in the net/rtsock.c file.
So I think this problem is only visable under certain routing table
conditions.
* include/sys/ioccom.h: Include <sys/types.h> not <machine/types.h> so
Linux port builds.
PR 341/networking
* lib/ftpfs.c: Account for NULL at end of strings when malloc()'ing
memory.
PR 340/filesystem
* src/fcntl.c: Add missing _fcntl_r assumed to exist by newlib.
* include/sys/ioccom.h: Fix so not using internal RTEMS types in libc
code.
* Apply the 2003-01-31 changes OAR's broken CVS had dropped.
* configure.ac: Unconditionally check for CXX.
Require autoconf-2.57, automake-1.7.2.
* rtems++: Eliminate CC_O_FILES.
PR 338/filesystem
* io.t: Fix Ada binding as side-effect of fixing reentrancy
problem with rtems_io_lookup_name() (API change).
PR 338/filesystem
* include/rtems/io.h, src/io.c: Side-effect of fixing reentrancy
PR 338/filesystem
* src/unixlibc.c: Side-effect of fixing reentrancy problem with
PR 338/filesystem
* rtems.adb, rtems.ads: Side-effect of fixing reentrancy problem with
PR 338/filesystem
* sapi/no-io.c: Side-effect of fixing reentrancy problem with
rtems_io_lookup_name() (API change). Unused function removed.
PR 338/filesystem
* sci/sci.c: Side-effect of fixing reentrancy problem with
PR 338/filesystem
* console.c: Side-effect of fixing reentrancy problem with
PR 338/filesystem
* io.t: Document the API change that fixed reentrancy problem with
rtems_io_lookup_name().
PR 338/filesystem
* src/imfs/ioman.c: Fix reentrancy problem with
PR 339/filesystem
* src/chroot.c: Fix violation of FS node object copy semantics.
* shmdr/Makefile.am: Add .h files to PREINSTALL_FILES not
TMPINSTALL_FILES.
* README.cdn-X: New.
* binutils/binutils.add: Add --build=%_build --host=%_host.
* cpukit/.cvsignore: Add *.spec.in.
* gcc3newlib/gccnewlib.add: Add --build=%_build --host=%_host.
* gdb/gdb.add: Add --build=%_build --host=%_host.
* rtemsdoc/.cvsignore: Add *.spec.in.
* gcc3newlib/gccnewlib.add: Remove Buildroot.
* common/.cvsignore: New.
* common/common.add.in: Add Vendor, Distribution, BuildRoot.
* binutils/Makefile.am: Fix path to clean.add.
* binutils/binutils.add: Remove BuildRoot.
* cpukit/Makefile.am: Use $(top_builddir)/common/common.add,
$(top_builddir)/common/clean.add, header.add.
Generate rtems-cpukit.spec.in.
* cpukit/header.add: New.
* cpukit/rtems-cpukit.spec.in: Remove.
* cpukit/rtems-cpukit.add: New.
* gccnewlib/gccnewlib.add: Remove Buildroot.
* gdb/gdb.add: Remove Buildroot.
* rtemsdoc/rtemsdoc.add: Remove BuildRoot.
* rtemsdoc/Makefile.am: Use $(top_builddir)/common/common.add,
Generate rtemsdoc.spec.in.
* rtemsdoc/mkspec.in: Remove exe_ext.
* rtemsdoc/rtemsdoc.spec.in: Remove.
* gccnewlib/Makefile.am: Use $(top_builddir)/common/common.add,
* gccnewlib/base-gcc.m4: Replace @exe_ext@ with %{_exeext}.
* gccnewlib/base-gcj.add: Replace @exe_ext@ with %{_exeext}.
* gccnewlib/gccnewlib.add: Replace @exe_ext@ with %{_exeext}.
Remove header, broken cdn-X configuration, %clean.
* gccnewlib/target-g77.add: Replace @exe_ext@ with %{_exeext}.
* gccnewlib/target-gcc.add: Replace @exe_ext@ with %{_exeext}.
* gccnewlib/target-gcj.add: Replace @exe_ext@ with %{_exeext}.
* gccnewlib/target-objc.add: Replace @exe_ext@ with %{_exeext}.
* gdb/gdb.add: Remove header, broken cdn-X configuration,
%clean, Replace @exe_ext@ with %{_exeext}.
* gdb/mkspec.in: Remove exe_ext.
* gdb/target-gdb.add: Replace @exe_ext@ with %{_exeext}.
* gdb/Makefile.am: Use $(top_builddir)/common/common.add,
* gcc3newlib/base-gcj.add: Replace @exe_ext@ with %{_exeext}.
* cpukit/mkspec.in: Remove exe_ext.
* binutils/Makefile.am: Use $(top_builddir)/common/common.add,
* gcc3newlib/gccnewlib.add: Remove header, broken cdn-X configuration,
* gcc3newlib/mkspec.in: Remove exe_ext.
* gcc3newlib/target-c++.add: Replace @exe_ext@ with %{_exeext}.
* gcc3newlib/target-g77.add: Replace @exe_ext@ with %{_exeext}.
* gcc3newlib/target-gcc.add: Replace @exe_ext@ with %{_exeext}.
* gcc3newlib/target-gcj.add: Replace @exe_ext@ with %{_exeext}.
* gcc3newlib/target-gnat.add: Replace @exe_ext@ with %{_exeext}.
* gcc3newlib/target-objc.add: Replace @exe_ext@ with %{_exeext}.
+ gcc3newlib/Makefile.am: Use $(top_builddir)/common/common.add,
* Makefile.am: Remove reference to mkbinutilsspec.
* configure.ac: Remove EXEEXT check.
Add common/clean.add, common/common.add.
* binutils/binutils.add: Remove header, broken cdn-X configuration,
%clean.
* binutils/mkspec.in: Remove exe_ext, build_alias, host_alias.
* binutils/target-binutils.add: Replace @exe_ext@ with %{_exeext}.
* gcc3newlib/header.add: New.
* gccnewlib/header.add: New.
* binutils/header.add: New.
* gdb/header.add: New.
* rtemsdoc/header.add: New.
* rtemsdoc/rtemsdoc.add: New.
* common/clean.add.in: New.
* common/common.add.in: New.
* binutils/Makefile.am: Reflect changes above.
* binutils/mkspec.in: New.
* binutils/.cvsignore: Add mkspec.
* mkbinutilspec.in: Remove.
* gdb/Makefile.am: Depend on mkspec.
* binutils/binutils.add: Add @exe_ext@ to c++filt.
Add %_defaultbuildroot.
* gdb/.cvsignore: Add mkspec.
* ChangeLog: Fix yesterday's entry.
* gdb/target-gdb.add: %defattr(-,root,root).
Use %{_prefix} instead of /opt/rtems.
Misc. minor changes.
* gdb/gdb.add: Use %{_prefix} instead of /opt/rtems.
Remove stray unpackaged files.
Use %{_defaultbuildroot} instead of hard-coded values.
configure --disable-nls.
Add BuildPreReq: ncurses-devel.
* gdb/base-gdb.add: %defattr(-,root,root).
* gdb/mkspec.in: New.
* gdb/Makefile.am: Reflect addition of gdb/mkspec.in.
* gcc3newlib/mkspec.in: Fix usage.
* gcc3newlib/gccnewlib.add: Use %{_defaultbuildroot} instead of
hard-coded values. Update copyright notice.
* mkgdbspec.in: Removed.
* Makefile.am: Remove mkgdbspec.
* configure.ac: Remove mkgdbspec.
Add gdb/mkspec.
* VERSION: Updated to rtems-ss-20030128.
* aclocal/version.m4: Updated to rtems-ss-20030128.
* tversions.texi: Updated tool version numbers.
* makefiles.t, support.t: Updated to reflect use of automake in
addition to autoconf.
* startup/Makefile.am, startup/linkcmds, startup/linkcmds-le,
startup/linkcmds-le.coff: Fix to work around truncated section names.
* startup/linkcmds: Fix to work around truncated section names.
* startup/linkcmds, startup/linkcmds.rom, startup/linkcmds.rom2ram: Fix
* startup/linkcmds, startup/linkcmds.ram, startup/linkcmds.rom: Fix to
* include/DP8570A.h, include/bsp.h, start/start.c,
startup/efi68k_tcp.c: Rename tcp_init() to bsp_tcp_init()
to avoid conflict with TCP/IP stack internal routine.
