* | 2003-09-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-09-24 | 3 | -32/+41 |
| | | | | | * Makefile.am: Merge-in include/Makefile.am. * include/Makefile.am: Remove. | ||||
* | *** empty log message *** | Ralf Corsepius | 2003-09-22 | 1 | -1/+1 |
* | 2003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-09-22 | 5 | -18/+22 |
| | | | | | | | | | | | * monitor/monitor.h: Add rtems_monitor_commands[] (Illegally applied by shell/). Remove ifdef(__mips64) (Make broken code visible again). * monitor/mon-command.c: Add several ifndef RTEMS_UNIX to avoid warnings. * monitor/mon-monitor.c: Remove RTEMS_CPU_HAS_16_BIT_ADDRESSES (Make broken code visible again). * shell/cmds.c: Remove local decls of rtems_monitor_commands[]. | ||||
* | 2003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-09-22 | 2 | -11/+10 |
| | | | | | * images/ChangeLog: Removed. * ChangeLog: Merge images/ChangeLog. | ||||
* | 2003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-09-22 | 2 | -16/+18 |
| | | | | | * common/ChangeLog: Removed. * ChangeLog: Merge common/ChangeLog. | ||||
* | 2003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-09-22 | 2 | -0/+6 |
| | | | | * common/.cvsignore: Add rtems.texi, rtems.sed. | ||||
* | 2003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-09-22 | 4 | -4/+10 |
| | | | | * Makefile.am: Merger from rtems-4-6-branch. | ||||
* | 2003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-09-22 | 2 | -2/+5 |
| | | | | * configure.ac: Merger from rtems-4-6-branch. | ||||
* | 2003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-09-22 | 6 | -6/+15 |
* | 2003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-09-22 | 10 | -10/+25 |
* | 2003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-09-22 | 40 | -41/+108 |
* | 2003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-09-22 | 6 | -18/+77 |
| | | | | | | | | | * Makefile.am: Merger from rtems-4-6-branch. * configure.ac: Merger from rtems-4-6-branch. Purge hppa1.1. * index.html.in: Purge hppa1.1. * project.am: Merger from rtems-4-6-branch. * rtems_support.html.in: Purge hppa1.1. | ||||
* | 2003-09-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-09-20 | 3 | -2/+6 |
| | | | | | * supplement.am: Add -I $(top_builddir) TEXI2WWW_ARGS. * Makefile.am: Purge hppa1.1. | ||||
* | 2003-09-19 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-19 | 11 | -39/+42 |
| | | | | | | | * HELP.html, index.html.in, rtems_footer.html.in, rtems_header.html.in, rtems_support.html.in, ada_user/ada_user.texi: Merge from branch. * acinclude.m4, images/rtems_logo.jpg: New files. * SUPPORT, tools/texi2www/archive/texi2www-960103.tgz: Removed. | ||||
* | 2003-09-19 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-19 | 6 | -23/+60 |
| | | | | * FAQ.texi, basic.t, build45.t, entry, tools.t: Merge from branch. | ||||
* | 2003-09-19 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-19 | 6 | -20/+21 |
| | | | | | * analog.t, bsp_howto.texi, discrete.t, nvmem.t, target.t: Merge from branch. | ||||
* | 2003-09-19 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-19 | 4 | -14/+26 |
| | | | | | * cpright.texi, setup.texi: Merge from branch. * rtems.texi.in: New file. | ||||
* | 2003-09-19 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-19 | 2 | -0/+5 |
| | | | | * develenv.texi, direct.t, sample.t, utils.t: Merge from branch. | ||||
| | | | | * filesystem.texi: Merge from branch. | ||||
* | 2003-09-19 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-19 | 6 | -13/+18 |
| | | | | | * gnu_footer.html, gnu_header.html, index.html, refcard.html, rtems_tools_index.html: Merge from branch. | ||||
* | 2003-09-19 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-19 | 2 | -0/+6 |
| | | | | * itron.texi: Merge from branch. | ||||
| | | | | * networking.texi: Merge from branch. | ||||
| | | | | * porting.texi: Merge from branch. | ||||
| | | | | * new_chapters.texi: Merge from branch. | ||||
* | 2003-09-19 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-19 | 4 | -10/+15 |
| | | | | * ch07.t, posix1003_1.texi, preface.texi: Merge from branch. | ||||
| | | | | * posix_users.texi: Merge from branch. | ||||
* | 2003-09-19 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-19 | 5 | -99/+19 |
| | | | | | * install.texi, intro.texi, relnotes.texi, status.texi: Merge from branch. | ||||
| | | | | * rgdb_specs.texi: Merge from branch. | ||||
| | | | | * rtems_gdb.texi: Merge from branch. | ||||
* | 2003-09-19 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-19 | 10 | -138/+230 |
| | | | | | | * .cvsignore, binaries.t, buildc.t, buildrt.t, intro.t, nextstep.t, nt.t, started.texi: Merge from branch. * tversions.texi.in: New file. | ||||
* | 2003-09-19 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-19 | 4 | -18/+13 |
| | | | | * intro.t, started_ada.texi, tversions.texi: Merge from branch. | ||||
| | | | | * arm.texi: Merge from branch. | ||||
| | | | | * c4x.texi: Merge from branch. | ||||
| | | | | * hppa1_1.texi: Merge from branch. | ||||
| | | | | * i386.texi: Merge from branch. | ||||
| | | | | * i960.texi: Merge from branch. | ||||
| | | | | * m68k.texi: Merge from branch. | ||||
| | | | | * mips.texi: Merge from branch. | ||||
| | | | | * mips64orion.texi: Merge from branch. | ||||
| | | | | * powerpc.texi: Merge from branch. | ||||
| | | | | * sh.texi: Merge from branch. | ||||
| | | | | * sparc.texi: Merge from branch. | ||||
| | | | | * template.texi: Merge from branch. | ||||
* | 2003-09-19 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-19 | 3 | -11/+12 |
| | | | | * c_user.texi, fatal.t, preface.texi, rtmon.t: Merge from branch. | ||||
* | 2003-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-09-19 | 4 | -8/+13 |
| | | | | | | | * monitor/monitor.h: Remove STREQ, STNEQ (pollute namespace), RTEMS_MONITOR_PROMPT (pollutes namespace, useless). * monitor/mon-command.c: Add RTEMS_MONITOR_PROMPT. * monitor/mon-monitor.c: Apply private version of STREQ. | ||||
* | 2003-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-09-19 | 5 | -8/+21 |
| | | | | | | | | * monitor/symbols.h: Convert to private header. * monitor/monitor.h: Don't include symbols.h. Add forward decls. for symbols from symbols.h. * monitor/Makefile.am: Don't install symbols.h. * monitor/mon-symbols.c: Include "symbols.h". | ||||
* | 2003-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-09-19 | 14 | -56/+28 |
| | | | | * bsp_specs: Remove *lib:. | ||||
* | 2003-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-09-19 | 2 | -8/+4 |
* | 2003-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-09-19 | 8 | -32/+16 |
* | 2003-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-09-19 | 28 | -112/+56 |
