* custom/h8sim.cfg, custom/h8sxsim.cfg:
Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* make/custom/h8sim.cfg: New (relocated from /make/custom).
* make/custom/h8sxsim.cfg: New (relocated from /make/custom).
* custom/c3xsim.cfg, custom/c4xsim.cfg:
* make/custom/c3xsim.cfg: New (relocated from /make/custom).
* make/custom/c4xsim.cfg: New (relocated from /make/custom).
* custom/pghplus.cfg:
* make/custom/pghplus.cfg: New (relocated from /make/custom).
* custom/ep1a.cfg, custom/gen5200.cfg, custom/gen83xx.cfg,
custom/haleakala.cfg, custom/mbx821_001.cfg,
custom/mbx821_002.cfg, custom/mbx821_002b.cfg,
custom/mbx860_001b.cfg, custom/mbx860_002.cfg,
custom/mbx860_005b.cfg, custom/mbx860_1b.cfg,
custom/mbx8xx.cfg, custom/mcp750.cfg, custom/mpc5566evb.cfg,
custom/mpc55xx.cfg, custom/mpc8260ads.cfg, custom/mtx603e.cfg,
custom/mvme2100.cfg, custom/mvme2307.cfg, custom/mvme3100.cfg,
custom/mvme5500.cfg, custom/psim.cfg, custom/qemuppc.cfg,
custom/score603e.cfg, custom/ss555.cfg, custom/tqm8xx.cfg,
custom/tqm8xx_stk8xx.cfg, custom/virtex.cfg:
* make/custom/tqm8xx.cfg: New (relocated from /make/custom).
* make/custom/tqm8xx_stk8xx.cfg: New (relocated from /make/custom).
* make/custom/ss555.cfg: New (relocated from /make/custom).
* make/custom/score603e.cfg: New (relocated from /make/custom).
* make/custom/qemuppc.cfg: New (relocated from /make/custom).
* make/custom/psim.cfg: New (relocated from /make/custom).
* make/custom/mvme5500.cfg: New (relocated from /make/custom).
* make/custom/mvme3100.cfg: New (relocated from /make/custom).
* make/custom/mpc8260ads.cfg: New (relocated from /make/custom).
* make/custom/mpc5566evb.cfg: New (relocated from /make/custom).
* make/custom/mpc55xx.cfg: New (relocated from /make/custom).
* make/custom/mcp750.cfg: New (relocated from /make/custom).
* make/custom/mtx603e.cfg: New (relocated from /make/custom).
* make/custom/mvme2100.cfg: New (relocated from /make/custom).
* make/custom/mvme2307.cfg: New (relocated from /make/custom).
* make/custom/mbx821_001.cfg: New (relocated from /make/custom).
* make/custom/mbx821_002b.cfg: New (relocated from /make/custom).
* make/custom/mbx821_002.cfg: New (relocated from /make/custom).
* make/custom/mbx860_001b.cfg: New (relocated from /make/custom).
* make/custom/mbx860_002.cfg: New (relocated from /make/custom).
* make/custom/mbx860_005b.cfg: New (relocated from /make/custom).
* make/custom/mbx860_1b.cfg: New (relocated from /make/custom).
* make/custom/mbx8xx.cfg: New (relocated from /make/custom).
* make/custom/haleakala.cfg: New (relocated from /make/custom).
* make/custom/gen83xx.cfg: New (relocated from /make/custom).
* make/custom/gen5200.cfg: New (relocated from /make/custom).
* make/custom/ep1a.cfg: New (relocated from /make/custom).
* make/custom/virtex.cfg: New (relocated from /make/custom).
* custom/nios2_iss.cfg:
* make/custom/nios2_iss.cfg: New (relocated from /make/custom).
* custom/leon3.cfg, custom/leon2.cfg, custom/sis.cfg,
custom/erc32.cfg:
* make/custom/leon3.cfg: New (relocated from /make/custom).
* make/custom/leon2.cfg: New (relocated from /make/custom).
* make/custom/erc32.cfg: New (relocated from /make/custom).
* make/custom/sis.cfg: New (relocated from /make/custom).
* custom/avrtest.cfg:
* make/custom/avrtest.cfg: New (relocated from /make/custom).
* custom/i386ex.cfg, custom/pc486.cfg, custom/ts_386ex.cfg,
custom/pc386.cfg, custom/pc586.cfg, custom/pc386dx.cfg,
custom/pc686.cfg:
* make/custom/ts_386ex.cfg: New (relocated from /make/custom).
* make/custom/pc386.cfg: New (relocated from /make/custom).
* make/custom/pc386dx.cfg: New (relocated from /make/custom).
* make/custom/pc486.cfg: New (relocated from /make/custom).
* make/custom/pc586.cfg: New (relocated from /make/custom).
* make/custom/pc686.cfg: New (relocated from /make/custom).
* make/custom/i386ex.cfg: New (relocated from /make/custom).
* custom/gensh1.cfg, custom/gensh2.cfg, custom/gensh4.cfg,
custom/simsh1.cfg, custom/simsh2.cfg, custom/simsh2e.cfg,
custom/simsh4.cfg:
* make/custom/simsh1.cfg: New (relocated from /make/custom).
* make/custom/simsh2.cfg: New (relocated from /make/custom).
* make/custom/simsh2e.cfg: New (relocated from /make/custom).
* make/custom/simsh4.cfg: New (relocated from /make/custom).
* make/custom/gensh4.cfg: New (relocated from /make/custom).
* make/custom/gensh2.cfg: New (relocated from /make/custom).
* make/custom/gensh1.cfg: New (relocated from /make/custom).
* aclocal/check-custom-bsp.m4: Let _RTEMS_CHECK_CUSTOM_BSP look for
*.cfg into c/src/lib/libbsp/<cpu>/<bsp_family>/make/custom.
* sp32/init.c: Lengthen the clock tick and move configuration to the
bottom of the file.
* psxtimer01/psxtimer.c: It is not necessarily an error for the time
remaining to not equal the period.
* tmck/task1.c: Ignore numbers that are too large but keep going -- do
not abort.
* unlimited/test1.c: Spacing.
* libcsupport/src/no_libc.c: Remove.
* libcsupport/Makefile.am: Remove no_libc.c.
* libcsupport/src/newlibc_reent.c: Eliminate RTEMS_UNIX.
