* | gdb-python: Update so 'rtems task' lists the classic tasks. | Chris Johns | 2014-08-26 | 1 | -1/+30 |
| | | | | | | | | | | | | | | This is a first pass at cleaning up the support. To use: $ waf configure --prefix=$HOME/development/rtems/4.11 $ waf build install Start GDB and break at Init: (gdb) py import rtems (gdb) rtems task will list the classic API tasks. | ||||
* | Fix Task and state printer bugs. | Dhananjay Balan | 2014-08-25 | 1 | -0/+1 |
| | | | | | - Removed ITRON api objects in thread control - fixes #1 | ||||
* | Refactoring | Dhananjay Balan | 2014-08-25 | 1 | -6/+6 |
| | | | | - drop _printer suffix from printer classes. | ||||
* | Add printers to stage. | Dhananjay Balan | 2014-08-25 | 1 | -0/+140 |
