The realview_pbx_a9_qemu test configuration for Qemu produced no output
due to wrong serial/monitor settings. Remove the serial/monitor
settings from qemu_opts_base and move them to the new qemu_opts_serial.
The INI section in a BSP configuration is the name of the INI file so
each BSP configuration section needs a BSP.
Updates #3204.
- Add support for user condfigurations files with the --user-config.
- Add support for a $HOME/.rtemstesterrc for a user configuration.
Closes #3204.
