The realview_pbx_a9_qemu test configuration for Qemu produced no output
due to wrong serial/monitor settings. Remove the serial/monitor
settings from qemu_opts_base and move them to the new qemu_opts_serial.
Add support in tester to run covoar and generate an html report to display
the summary of the coverage reports generated from covoar.
Co-authored-by : Cillian O'Donnell <cpodonnell8@gmail.com>
Add ability to organize symbol sets of libraries in INI file
and then read them with covoar and load the symbols directly from the
libraries.
rtems-tools/../testing: Add configuration files for coverage analysis.
A number of covoar options are not required and are defaulted.
Co-author: Krzysztof Miesowicz <krzysztof.miesowicz@gmail.com>
Co-author: Vijay Kumar Banerjee <vijaykumar9597@gmail.com>
Co-author: Chris Johns <chrisj@rtems.org>
