* | tester: Make the SIS time limit user configurable | Chris Johns | 2022-07-06 | 1 | -3/+2 |
| | | | | | | Let the user set the test time limit in a config file to provide site specific overrides. Optimisation can effect the time a test may take to run. | ||||
* | tester: Remove target from BSP coverage configs | Alex White | 2021-03-30 | 1 | -1/+0 |
* | testing/bsps: Add covoar commands in bsp ini file | Vijay Kumar Banerjee | 2019-02-19 | 1 | -6/+7 |
* | Coverage : Add coverage support for RISCV | Vijay Kumar Banerjee | 2019-02-12 | 1 | -0/+40 |
