- Fix listener done state
- Finish open with the state as finished
Closes #4959
Check for "BEGIN OF TEST" and "END OF TEST" to not use other information blocks
such as "END OF GCOV" to determine the test status.
- Remove the hard tester error and count the header errors.
Tests resulting in the fatal-error state are counted as failures, but
are not currently reported in the text summary. This has already been
fixed for JSON output.
This fixes an issue with json report output that causes a crash due to
the incorrect object member being accessed for test-too-long. This also
changes treatment of fatal errors to match how they are displayed in the
tester log output and changes "fatal error" to "fatal-error" to better
match the naming of all the other failure types.
- A test that loops generating output did not timeout. Monitor the
the session time and set a maximum test period.
jobs
Update #3217.
Change the subject to place the arch/bsp first and then a short
score card for the tests so the archive can be listed by subject and
you can see regressions.
- Add support for user condfigurations files with the --user-config.
- Add support for a $HOME/.rtemstesterrc for a user configuration.
Closes #3204.
The exe filter lets a BSP change the executable file to something
that can be downloaded to the target. For example U-Boot requires the image
format. The tester can now be configured to on-demand generate a specific
image for the target as the tester runs.
TFTP runs a local TFTP server on port 69 or another specified port and
serves each test for any requested file.
Telnet is now a console option.
Count the errors for the states listed and add running totals.
Kill the test process if the test state is user-input or benchmark.
The conversion to Python3 added an eval() call which is wrong.
Fix the spelling in execute.
Fix labels in the tester gdb locking.
Check the debug-trace arguments.
Close #2642.
