- Fix data decoding
- Fix get MAC call
- If you host does not provide a python command consult the User
manual for ways you can run the python commands.
- Full package paths are being used to avoid namespace pollution and
crosstalk.
- Uses a config INI file to map clients to servers
- Handle a number of requests to a single server's TFTP port (69)
and multiplex to a non-su ports or different servers.
- Supports running rtems-test to more than one hardware device using
TFTP at once.
