* | misc/tftpproxy: Add a proxy TFTP server. | Chris Johns | 2019-08-19 | 4 | -0/+693 |
- Uses a config INI file to map clients to servers - Handle a number of requests to a single server's TFTP port (69) and multiplex to a non-su ports or different servers. - Supports running rtems-test to more than one hardware device using TFTP at once. |
