* lm3s6965.in.: New file.
* Makefile: Reflect change above.
* .cvsignore, Makefile, bf537Stamp.in, ezkit533.in: Move current
scripts to skyeye named ones so the default is to use the new
simulator in gdb.
* bf537Stamp-skyeye.in, ezkit533-skyeye.in: New files.
* .cvsignore: Add qemu-lm32_evr.
* .cvsignore, Makefile, gdb-sim-run.in: Add QEMU Gumstix Connex
support.
* qemu-gumstix.in: New file.
* .cvsignore, Makefile: Rename most qemu scripts to match the BSP name.
qemu-leon2 not renamed since we prefer tsim for it.
* pc386.in, qemuppc.in, uC5282.in: New files.
* qemu-ppc.in, qemu-rtems.in, qemu-uc5282.in: Removed.
* .cvsignore, Makefile, qemu-uc5282.in: Add script to run qemu-ppc
simulator.
* qemu-ppc.in: New file.
* .cvsignore, Makefile: Add lm32_evr simulator script support.
* lm32_evr.in: New file.
* .cvsignore, Makefile: Add initial version of Qemu uc5282 and LEON2
scripts.
* qemu-leon2.in, qemu-uc5282.in: New files.
* .cvsignore: Add tsim gdb scripts.
* gdb-sim-run.in: termios.exe is interactive. termios01 is not.
* .cvsignore, Makefile, edb7312.in, gdb-sim-run.in, skyeye-support: Add
support for invoking a simulator external to gdb in gdb server mode.
Have the gdb commands generated to include attaching to that server
instance.
* .cvsignore, Makefile, gdb-sim-run.in: Add support for avrtest BSP
using simulavrxx.
* avrtest.in: New file.
* .cvsignore, ChangeLog: Add gumstix.
* .cvsignore, Makefile: Add first cut at script to run leon2 BSP on
Skyeye.
* leon2-skyeye.in: New file.
* .cvsignore, Makefile, gdb-sim-run.in, gdb-sim.in, skyeye-support: Add
qemu-rtems script.
* qemu-rtems.in: New file.
* .cvsignore, Makefile, erc32.in, gdb-sim-run.in, mkrun: Add TSIM
support for ERC32, LEON2, and LEON3 BSPs. Include using all three for
coverage.
* leon2.in, leon3.in, tsim-support: New files.
* .cvsignore, Makefile, README, gdb-sim-run.in: Add first cut at ERC32.
Need to test on machine with TSIM license.
* erc32.in: New file.
* .cvsignore, Makefile: Add rest of Skyeye configurations whether
they work completely at this point or not.
* ant5206.in, bf537Stamp.in, csb337.in, csb350.in, csb360.in,
ezkit533.in, rtl22xx.in, smdk2410.in: New files.
* .cvsignore, Makefile, gdb-sim-run.in, gdb-sim.in, h8sim.in,
jmr3904.in, m32csim.in, m32rsim.in, mkrun, psim.in, simsh.in, sis.in:
Add ARM/edb7312 support. This is the first Skyeye BSP and adding this
required tinkering with all BSP scripts. All appear to still work OK.
* edb7312.in, skyeye-support: New files.
* .cvsignore, Makefile, gdb-sim-run.in, gdb-sim.in: Add psim support.
* psim.in: New file.
* .cvsignore, Makefile, jmr3904.in, mkrun: Now generate gdb script for
h8sim, jmr3904 m32csim, m32rsim, simsh and sis.
* gdb-sim.in: New file.
* .cvsignore, Makefile: Switch to using script to do sed and add
versioning on installation.
* mkrun: New file.
* .cvsignore, Makefile, gdb-sim-run.in: Add m32csim, m32rsim, and
simsh.
* m32csim.in, m32rsim.in, simsh.in: New files.
* .cvsignore, Makefile, gdb-sim-run.in: Add h8300/h8sim.
* h8sim.in: New file.
* .cvsignore, sis.in: New files.
