Closes #4037
- Add '%source download <source>' to only download the source
and do not unpack and prep. This can used when a package
internally needs another source package.
- Install the staging root only if it is present. A package
may internally build another package that is not staged as it
is not suitable for installing.
Updates #3250
Updatew #3797
Ignore RSB generated files to keep the git dirty status clean.
Closes #2647.
Closes #2748.
Set up the rules to manage the separate host and build setting to
allow a Canadian cross to complete.
Update the scripts to move the build directory and host/build
flags into the defaults so they are common for all build
configurations.
To support building snapshots and pre-release source the defaults
has been refactored. The defaults have been moved to a stand alone
file and a macros.py module added. This modile abstracts the
old default dictionary turning it into a class. The macros
class can load macros from a file therefore the defaults have
been moved to a stand alone file.
The use of defaults has been removed from the project. The only
case where it is used in the options where the defaults are read
from a file. Macros are used everywhere now.
The defaults.py has been moved to the option.py and the separate
options and defaults values has been moved to a new pattern. When
constructing an object that needs macros and options if the macros
passed in is None the defaults from the options are used. This makes
it clear when the defaults are being used or when a modified set of
macros is being used.
The macros class support maps. The default is 'global' and where all
the defaults reside and where configuratiion file changes end up.
Maps allow macros to be read from a file and override the values
being maintained in the 'global' map. Reading a macro first checks
the map and if not present checks the 'global' map.
The addition of maps to the macros provides the base to support
snapshots and pre-release testing with standard configurations.
This functionality needs to be added. It works by letting to
specify a snapshot with:
source0: none, override, 'my-dist.tar.bz2'
and it will be used rather the value from the standard configuration.
With a build set you need to also specify the package these macros
are for. The maps provide this.
Refactor the options handling in defaults.py to allow the --jobs
option have varing specific parameters. The option supports 'none',
'max' and 'half' or a fraction to divide the number of CPUs or
an integer value which is the number of jobs. The --no-smp has
been removed.
The host specific modules have been changed to set the number of
CPUs in the defaults table.
Fixed the --keep-going to clean up is --always-clean is provided
even if the build has an error.
