- Update rtems-bsp support to correctly handle hosts for BSP.
- Clean up the options for a BSP.
- Check all RTEMS 5 packages and add 5/rtems-packages for all that build.
- Update download locations and checksum of all packages.
- The work requires the kernel and Libbsd hacve the same prefix.
graphics/nxlib is removed from build set because for actual Microwindows
the NXlib is included in Microwindows sources (src/nxlib).
The original NXlib libX11.a is replaced by two varinats
libPX11 links X11 server replacement directly to the application.
libNX11 is more X11 concept compatible, application and server
runs in the separate processes.
The support is added at the top level and so not lost when we
move to a new version of RTEMS.
The change also moves all 3rd party packages to use a common
rtems-package.bset build set file.
All packages except Microwindows itself build cleanly.
