* | qemu-xilinx: Update to 2023.2 | Kinsey Moore | 2024-04-04 | 2 | -1/+38 |
| | | | | | | | The 2020.2 version of Xilinx's qemu branch does not build on AArch64 due to a merge conflict that was integrated into the repository and never corrected. This brings qemu-xilinx up to 2023.2 to resolve that issue and allow it to build on AArch64 systems. | ||||
* | glib: Update to 2.56.4 | Kinsey Moore | 2024-04-04 | 4 | -3/+33 |
| | | | | This updates glib to 2.56.4 for AArch64 build support. | ||||
* | devel/qemu-xilinx: Fix build on GCC 13.2.0 | Kinsey Moore | 2024-02-19 | 1 | -0/+7 |
| | | | | | GCC 13.2.0 adds new warnings/errors when mixing ints and enums. This changes the pminsn helper type to correctly use enums. | ||||
* | Update libtool to 2.4.7 for AArch64 support | Kinsey Moore | 2024-02-12 | 3 | -2/+19 |
* | bare/config/qemu-5.2.0: Add gdbus-codegen patch | Kinsey Moore | 2024-01-31 | 1 | -0/+7 |
* | bare/or1ksim: Fix invalid hash and fix the version | Chris Johns | 2023-12-13 | 1 | -3/+3 |
* | hash: Fix missing hashes after errors if missing | Chris Johns | 2023-12-07 | 5 | -0/+31 |
* | 6: Fix gcc-13 support for MacOS | Chris Johns | 2023-11-28 | 2 | -1/+28 |
| | | | | Update #4921 | ||||
* | qemu: Adjust cgem interrupt patch | Kinsey Moore | 2023-10-07 | 2 | -0/+14 |
| | | | | | | | | | This patch is being moved to the 5.2.0-1 QEMU configuration because the Xilinx QEMU build uses the 5-1 configuration and this patch does not apply to Xilinx's modified tree. This also adds a new patch that applies correctly to Xilinx's modified QEMU tree. Updates #4919 | ||||
* | 6: Use libexpat 2.5.0 | Sebastian Huber | 2023-07-24 | 1 | -0/+20 |
| | | | | | | This version contains security fixes. Prepare for RTEMS 6.1 release. Update #4921. | ||||
* | devel/qemu-xilinx: Fix source URL | Alex White | 2023-05-15 | 1 | -1/+1 |
| | | | | | The source URL for Xilinx QEMU appears to have been incorrect from the start. Since we are cloning a git repository, we should use 'git://'. | ||||
* | devel/mpfr: Add MPFR as a package | Chris Johns | 2023-04-05 | 1 | -0/+18 |
| | | | | | | | - This is a place holder incase we stop building MPFR in GCC. Updates #4892 | ||||
* | Revert github tarball hash changes | Kinsey Moore | 2023-02-01 | 5 | -6/+6 |
| | | | | | GitHub has reverted the change that caused all these tarball hashes to change and so we follow suit. | ||||
* | devel/gnu-default-tools: Use correct include path | Kinsey Moore | 2023-01-30 | 1 | -1/+1 |
| | | | | | Include paths must use the full file name with extension. This was causing errors because it couldn't resolve the include. | ||||
* | Update hashes for github-sourced tarballs | Kinsey Moore | 2023-01-30 | 5 | -6/+6 |
| | | | | | | | Github has changed the way it generates on-the-fly tarball requests which has changed the hashes of the resulting tarballs. This adjusts the affected tarball hashes as a stop-gap until a more permanent solution can be devised. | ||||
* | dtc: Add patch to build for ticket 4783 | Kinsey Moore | 2023-01-30 | 1 | -0/+3 |
| | | | | | This patch resolves a build error with dtc on cygwin until upstream adopts a fix. | ||||
* | sis: update to version 2.30 | Sebastian Huber | 2022-11-04 | 1 | -2/+3 |
* | testproc/gsed: Do not use %include with internal builds | Chris Johns | 2022-09-16 | 1 | -0/+1 |
* | devel/gcc: Check and build GNU sed if not available on build host | Chris Johns | 2022-09-14 | 1 | -0/+6 |
| | | | | Closes #2300 | ||||
* | config: Various updates to fix downloading of sources | Chris Johns | 2022-08-17 | 4 | -3/+9 |
* | bare/gnu-tools: Update bare gnu-tools to gcc 12, binutils 2.38 and gdb 11.2 | Chris Johns | 2022-06-17 | 4 | -0/+81 |
| | | | | | | | | - This tracks the common RTEMS tools version. It does not track special builds that are specific to a tool set. - Use with "--target=microblaze-elf gnu-tools" where the target is the tools to build | ||||
* | 6/7: Use gmp-6.2.1 for GDB | Sebastian Huber | 2022-04-25 | 1 | -0/+17 |
* | devel: add configuration for expat 2.4.8 | Karel Gardas | 2022-04-22 | 1 | -0/+19 |
* | devel/glib-2.48: Update hash and patch | Ryan Long | 2022-03-25 | 1 | -2/+2 |
| | | | | | | | Changes patch to be pulled from an RTEMS ticket and updated the hash of the patch. Updates #4634 | ||||
* | devel/spike-1.1.0: bump hash | Ryan Long | 2022-02-25 | 1 | -2/+2 |
| | | | | Bump the hash of spike to match the 1.1.0 release. | ||||
* | bare/.../dtc.bset: Update to 1.6.1 like other cases | Joel Sherrill | 2021-11-18 | 1 | -1/+1 |
* | RSB: update dtc 1.6.0 -> dtc 1.6.1 | Karel Gardas | 2021-11-18 | 2 | -1/+19 |
| | | | | | | | | Fixes #4221 Note: the patch updates only dtc 1.6.0 occurrences. It leaves all other dtc (1.4.x) usages as they are just to not break anything which depends on older dtc versions. | ||||
* | rsb: Add Xilinx QEMU | Alex White | 2021-08-20 | 2 | -0/+47 |
* | sis: update to version 2.29 | Sebastian Huber | 2021-08-04 | 1 | -2/+2 |
* | sis: update to version 2.28 | Sebastian Huber | 2021-07-30 | 1 | -2/+2 |
* | sis: update to version 2.27 | Jiri Gaisler | 2021-07-15 | 1 | -2/+2 |
* | Add aarch64 target to qemu-couverture | Alex White | 2021-07-02 | 1 | -1/+1 |
* | Add GMP as a prerequisite for GDB | Sebastian Huber | 2020-12-21 | 1 | -0/+18 |
* | devel/sis: Update to 2.26 | Jiri Gaisler | 2020-12-18 | 1 | -2/+2 |
* | devel/sis: Update to 2.25 | Sebastian Huber | 2020-12-02 | 1 | -5/+4 |
| | | | | Update #4195. | ||||
* | devel/qemu: Add the hash for the QEMU 5.2.0-rc1 | Chris Johns | 2020-11-16 | 1 | -3/+3 |
* | devel/qemu: Update QEMU to 5.2.0-rc1 | Chris Johns | 2020-11-13 | 3 | -35/+10 |
| | | | | | - This version of qemu uses meson and ninja to build. You will need to install ninja to build. No checks are made until meson run | ||||
* | devel/sis: Update to 2.22 | Chris Johns | 2020-09-10 | 1 | -2/+3 |
* | sb/track: Add a command to track build sets. | Chris Johns | 2020-08-10 | 1 | -0/+3 |
| | | | | | | | | - Process a build set for a range of hosts and output a dependency tree, the used build set and configuration files. - Output the configuration files that are no referenced Closes #4036 | ||||
* | glib: Gnome has change the git version to gitlab in requested patches. | Chris Johns | 2020-06-25 | 1 | -1/+1 |
* | devel/qemu4: Use release source tarball | Chris Johns | 2020-06-10 | 1 | -25/+9 |
| | | | | | | | Git cannot be used for a release as our release process does not package the source in a manner qemu expects. Closes #3976 | ||||
* | re/pixman: Revert the accidental commit. | Chris Johns | 2020-05-08 | 2 | -2/+2 |
| | | | | - Move qemu to 0.40.0 so pixman builds on FreeBSD 12 | ||||
* | bare/qemu: Fixes building on FreeBSD | Chris Johns | 2020-05-08 | 2 | -2/+2 |
| | | | | | | | | | | | | | | | - Move the qemu config to a common file shared by qemu and qemu4. - Disable nettle on qemu4, FreeBSd complained. - Add some extra git cleaning steps to the git path. These however do not full clean the qemu submodules and it is not worth the effort to try and fix. - The devel/qemu will not build on machines with python set to python3. This will not be fixed, use qemu4. Closes #3966 | ||||
* | qemu4.bset: Update to pixman 0.40.0. | Joel Sherrill | 2020-05-08 | 2 | -1/+20 |
* | devel/glib: Fix the checksum for the patch | Chris Johns | 2020-04-27 | 1 | -1/+2 |
* | source-builder: Add capstone | Vijay Kumar Banerjee | 2020-04-10 | 2 | -0/+34 |
* | bare/config: Add devel/dtc-1.6.0 | Vijay Kumar Banerjee | 2020-04-10 | 1 | -0/+18 |
* | bare/glib-2.48.2: Add patches to suppress null string warning | Vijay Kumar Banerjee | 2020-04-10 | 1 | -0/+7 |
* | qemu-couverture: update to qemu-stable-4.0.0 | Vijay Kumar Banerjee | 2020-04-10 | 2 | -13/+8 |
* | rsb: Use dtc.bset for Spike | Hesham Almatary | 2020-04-09 | 1 | -1/+1 |
