* | Add remainder of schedulers and cluster scheduler support. | Jennifer Averett | 2014-06-17 | 1 | -0/+5 |
* | schedsim_smppriority_affinity: Resolve problem in expected files. | Jennifer Averett | 2014-06-04 | 2 | -9/+162 |
* | schedsim_smppriority_affinity: New scenarios. | Jennifer Averett | 2014-06-03 | 7 | -0/+429 |
* | schedsim_smppriority_affinity: Change expected scenaoro filenames to not ↵ | Jennifer Averett | 2014-05-27 | 15 | -21/+15 |
| | | | | include path. | ||||
* | schedsim_smpsimple: Remove error case from scenario file. | Jennifer Averett | 2014-05-27 | 1 | -5/+0 |
| | | | | Any error now causes tests to stop. | ||||
* | make check now works and reports pass/fail | Joel Sherrill | 2014-05-26 | 1 | -3/+4 |
* | Add initial support for make check | Joel Sherrill | 2014-05-26 | 1 | -0/+17 |
| | | | | | | | | | | | | | | | + Enhance run_scenario to run from build tree. Required specification of both executable and scenario directory + check-local stanzas have first cut at which scenarios to run for each scheduler. TODO: + Verify behavior of each scheduler versus expected output. + Ensure list of scenarios executed is complete and appropriate. For example, SMP schedulers should avoid disable preemption scenarios. | ||||
* | _Thread_Dispatch wrapper is now shared between uniprocessor and SMP ↵ | Joel Sherrill | 2014-05-26 | 1 | -1/+0 |
| | | | | configurations | ||||
* | Unify printing of heir and executing | Joel Sherrill | 2014-05-26 | 16 | -235/+234 |
* | dispatch is now a shared SMP command | Joel Sherrill | 2014-05-26 | 1 | -1/+0 |
* | current_cpu is now a shared SMP command | Joel Sherrill | 2014-05-26 | 1 | -1/+0 |
* | shared/smp_stub.c: Only one shared version now | Joel Sherrill | 2014-05-26 | 1 | -1/+0 |
* | Use shared main() and file processor | Joel Sherrill | 2014-05-23 | 1 | -1/+0 |
* | schedsim_smppriority_affinity: Add expected file for ↵ | Jennifer Averett | 2014-05-23 | 1 | -1/+1 |
| | | | | cpus4_affinity_block_case1 scenario. | ||||
* | schedsim_smppriority_affinity: Add a worst case migration scenario. | Jennifer Averett | 2014-05-23 | 2 | -0/+182 |
* | schedsim_smppriority_affinity: Fix typo in name. | Jennifer Averett | 2014-05-23 | 1 | -0/+0 |
* | schedsim_smppriority_affinity: Change scenario thread name to 4 characters. | Jennifer Averett | 2014-05-23 | 2 | -7/+6 |
* | schedsim_smppriority_affinity: Cleanup scenarios. | Jennifer Averett | 2014-05-23 | 32 | -314/+807 |
| | | | | | Add check of expected threads to cpu commands. Add more documentation and set fix the expected files. | ||||
* | cpus4_affinity_case1.scen: Add error checking | Joel Sherrill | 2014-05-22 | 1 | -13/+23 |
* | Enhance cpus command to do validation of executing threads. | Joel Sherrill | 2014-05-22 | 1 | -1/+0 |
| | | | | | | | | | | This patch enhances the cpus command such that it can take a list of expected threads to be executing and validate that they are executing on the expected cores. The cpus command was moved to the shared directory. The documentation was updated. | ||||
* | cpus4_affinity_case1.scen: Specify affinity in hexadecimal | Joel Sherrill | 2014-05-22 | 1 | -4/+4 |
* | cpus4_exercise_affinity_api.scen: Reword comment | Joel Sherrill | 2014-05-22 | 1 | -0/+3 |
* | shedsim_smppriority_affinity: Add scenarios. | Jennifer Averett | 2014-05-20 | 7 | -1/+317 |
* | schedsim_smppriority_affinity: Add overlapping affinity scenario. | Jennifer Averett | 2014-05-19 | 2 | -0/+145 |
* | Add scenarios for setting affinity before start of task. | Jennifer Averett | 2014-05-16 | 11 | -0/+338 |
* | cpus4_exercise_affinity_api.scen: Scenario to exercise affinity | Joel Sherrill | 2014-05-14 | 1 | -0/+29 |
* | schedsim_smppriority_affinity: New simulator instance | Joel Sherrill | 2014-05-14 | 2 | -0/+68 |
