* | Add remainder of schedulers and cluster scheduler support. | Jennifer Averett | 2014-06-17 | 1 | -0/+5 |
* | make check now works and reports pass/fail | Joel Sherrill | 2014-05-26 | 1 | -3/+4 |
* | Add initial support for make check | Joel Sherrill | 2014-05-26 | 1 | -0/+12 |
| | | | | | | | | | | | | | | | + Enhance run_scenario to run from build tree. Required specification of both executable and scenario directory + check-local stanzas have first cut at which scenarios to run for each scheduler. TODO: + Verify behavior of each scheduler versus expected output. + Ensure list of scenarios executed is complete and appropriate. For example, SMP schedulers should avoid disable preemption scenarios. | ||||
* | _Thread_Dispatch wrapper is now shared between uniprocessor and SMP ↵ | Joel Sherrill | 2014-05-26 | 1 | -1/+0 |
| | | | | configurations | ||||
* | Unify printing of heir and executing | Joel Sherrill | 2014-05-26 | 1 | -1/+0 |
* | dispatch is now a shared SMP command | Joel Sherrill | 2014-05-26 | 1 | -1/+0 |
* | current_cpu is now a shared SMP command | Joel Sherrill | 2014-05-26 | 1 | -1/+0 |
* | shared/smp_stub.c: Only one shared version now | Joel Sherrill | 2014-05-26 | 1 | -1/+0 |
* | Use shared main() and file processor | Joel Sherrill | 2014-05-23 | 1 | -1/+0 |
* | Enhance cpus command to do validation of executing threads. | Joel Sherrill | 2014-05-22 | 1 | -1/+0 |
| | | | | | | | | | | This patch enhances the cpus command such that it can take a list of expected threads to be executing and validate that they are executing on the expected cores. The cpus command was moved to the shared directory. The documentation was updated. | ||||
* | schedsim_smppriority: New simulator instance | Joel Sherrill | 2014-05-14 | 2 | -0/+68 |
