* | Fix version dependence in package lists | Chris Johns | 2023-02-14 | 1 | -1/+2 |
* | release: Update to support the 5.2 release | Chris Johns | 2022-11-17 | 1 | -68/+49 |
| | | | | | | - Add a new release notes generator - Update and support the fixed RSB get sources | ||||
* | Fix release branch git clones | Chris Johns | 2020-08-15 | 1 | -10/+10 |
| | | | | Closes #4051 | ||||
* | Fix the paths in the README | Chris Johns | 2020-04-29 | 1 | -2/+1 |
| | | | | | | | | | - Move URL path generation to the a separate script file - Move info generation to a separate script file - Add markdown to the README.txt.in but filter and do not generate HTML from MD. A lot more work is needed to have this right. Close #3813 | ||||
* | Move all source into `sources` | Chris Johns | 2020-04-02 | 1 | -13/+20 |
| | | | | | | | - Update the README.txt to reference all the sources in the `sources` directory. Also fix the table formatting. - Add support for a release url to aid test and support deployment. - Make the docs and sources directory defaults | ||||
* | Add a release_url to the arguments for the various steps. | Chris Johns | 2020-02-28 | 1 | -2/+3 |
| | | | | | | - The release_url can be used for testing or to allow deployment by setting the top level URL the source is fetched from. - Move libbsd up in the order so the RSB can get a hash for it. | ||||
* | Stop of error (set -e) | Chris Johns | 2019-10-30 | 1 | -0/+2 |
* | Update to support RTEMS 5 | Chris Johns | 2019-10-29 | 1 | -17/+27 |
* | Minor formatting change. | Chris Johns | 2017-07-04 | 1 | -1/+2 |
* | Fix the compression bugs. Clean if present. | Chris Johns | 2017-04-12 | 1 | -2/+6 |
* | Use the top level rtems-tools and kernel packages. These are stamped. | Chris Johns | 2017-04-12 | 1 | -2/+36 |
| | | | | | | | | The rtems-release-source packages are not version stamped so are not suitable. Clean any empty git repos if found. Creating rtems-tools and kernel packages creates git source which is not allowed for a release. | ||||
* | Use defaults for compress. | Chris Johns | 2017-04-12 | 1 | -4/+4 |
| | | | | The threading option is added to the XZ command. | ||||
* | Keep the tools and kernel source in the `sources` directory. | Chris Johns | 2017-04-10 | 1 | -7/+0 |
| | | | | Updates #2952. | ||||
* | Add a release-path to the RSB VERSION file. Add better defaults support. | Chris Johns | 2017-04-06 | 1 | -7/+2 |
* | Fix the doco and packaging of docs. Sort out the README.txt templates. | Chris Johns | 2016-11-09 | 1 | -96/+97 |
* | Format to show directory levels. | Chris Johns | 2016-11-03 | 1 | -100/+99 |
* | Fix bare source packaging. | Chris Johns | 2016-10-31 | 1 | -3/+4 |
* | Make the source packages included version specific. | Chris Johns | 2016-09-04 | 1 | -42/+45 |
* | Initial addition of the RTEMS releasing scripts. | Chris Johns | 2016-09-04 | 1 | -0/+205 |
