* | Generate README.txt and index.html from markdown | Chris Johns | 2020-05-02 | 1 | -126/+0 |
| | | | | - Update to support ARCH-BSPS.md from an updated kernel tool | ||||
* | Fix the paths in the README | Chris Johns | 2020-04-29 | 1 | -30/+34 |
| | | | | | | | | | - Move URL path generation to the a separate script file - Move info generation to a separate script file - Add markdown to the README.txt.in but filter and do not generate HTML from MD. A lot more work is needed to have this right. Close #3813 | ||||
* | Fix README.txt.in after snapshot review. | Chris Johns | 2020-04-03 | 1 | -1/+2 |
* | Move all source into `sources` | Chris Johns | 2020-04-02 | 1 | -44/+57 |
| | | | | | | | - Update the README.txt to reference all the sources in the `sources` directory. Also fix the table formatting. - Add support for a release url to aid test and support deployment. - Make the docs and sources directory defaults | ||||
* | Update to support RTEMS 5 | Chris Johns | 2019-10-29 | 1 | -2/+2 |
* | Change the name of the examples-v2 package to rtems-examples-v2. | Chris Johns | 2017-04-04 | 1 | -8/+8 |
* | Add release notes and doxygen to the release. | Chris Johns | 2017-03-24 | 1 | -11/+13 |
| | | | | Rename the examples to have an rtems prefix. | ||||
* | Add examples-v2 and libbsd. | Chris Johns | 2016-11-11 | 1 | -0/+2 |
| | | | | | | These repos have submodules which need special handling to archive. Add release notes. | ||||
* | Fix the doco and packaging of docs. Sort out the README.txt templates. | Chris Johns | 2016-11-09 | 1 | -8/+37 |
* | Documentation is not built for some versions. | Chris Johns | 2016-09-04 | 1 | -31/+2 |
* | Initial addition of the RTEMS releasing scripts. | Chris Johns | 2016-09-04 | 1 | -0/+104 |
