* | bin/openssl: Port to RTEMS. | Christian Mauderer | 2019-03-27 | 3 | -0/+43 |
* | Remove unused file | Sebastian Huber | 2019-03-01 | 1 | -224/+0 |
* | Build C++ kernel-space compatibility file | Sebastian Huber | 2019-02-18 | 1 | -2/+3 |
* | Fix atomic_load_32() | Sebastian Huber | 2019-02-18 | 1 | -1/+1 |
* | Remove <linux/rbtree.h> | Sebastian Huber | 2019-02-12 | 1 | -146/+0 |
| | | | | It is already provided by RTEMS. | ||||
* | Remove obsolete <rtems/pty.h> | Sebastian Huber | 2019-02-12 | 1 | -68/+0 |
* | mghttpd: Remove | Sebastian Huber | 2019-02-12 | 2 | -5907/+0 |
| | | | | The mghttpd is already provided by RTEMS. | ||||
* | ZONE(9): Fix UMA_PCPU_ALLOC_SIZE | Sebastian Huber | 2019-02-12 | 1 | -2/+2 |
| | | | | | Using CACHE_LINE_SIZE for UMA_PCPU_ALLOC_SIZE was a huge memory waste since the backend memory allocator is page based. | ||||
* | atomic.h: Add atomic_fetchadd_64() | Sebastian Huber | 2019-02-11 | 1 | -0/+26 |
* | atomic.h: Add atomic_load_32() | Sebastian Huber | 2019-02-11 | 1 | -0/+21 |
* | Fix INVARIANTS support | Sebastian Huber | 2019-01-22 | 2 | -2/+35 |
* | dpaa: Use if_transmit instead of legacy if_start | Sebastian Huber | 2019-01-15 | 1 | -82/+65 |
| | | | | This avoids a lock contention on the send queue. | ||||
* | dpaa: Fix FMan MAC SGT zone alignment | Sebastian Huber | 2019-01-15 | 1 | -1/+1 |
* | Update rtems-bsd-kernel-namespace.h | Sebastian Huber | 2018-12-20 | 1 | -1/+26 |
* | Update to FreeBSD head 2018-12-20 | Sebastian Huber | 2018-12-20 | 5 | -30/+177 |
| | | | | | | | | | | Git mirror commit 19a6ceb89dbacf74697d493e48c388767126d418. It includes an update of wpa_supplicant to version 2.7. It includes an update of the OpenSSL baseline to version 1.1.1a. Update #3472. | ||||
* | freebsd/if_cpsw: Port. | Christian Mauderer | 2018-12-20 | 2 | -0/+2 |
* | Fix locking issue in epoch_sysinit() | Sebastian Huber | 2018-12-20 | 1 | -0/+4 |
| | | | | | The _Watchdog_Per_CPU_insert_ticks() assumes that interrupts are disabled. | ||||
* | Update to FreeBSD head 2018-11-15 | Sebastian Huber | 2018-11-15 | 3 | -577/+592 |
| | | | | | | Git mirror commit a18b0830c4be01b39489a891b63d6023ada6358a. Update #3472. | ||||
* | Disable or make static kern_* functions | Sebastian Huber | 2018-11-15 | 1 | -9/+0 |
* | mutex: Avoid NULL pointer access in panic() | Sebastian Huber | 2018-11-15 | 1 | -1/+2 |
* | Fix locking issue in epoch_watchdog() | Sebastian Huber | 2018-11-15 | 1 | -0/+3 |
* | Include missing <sys/types.h> | Sebastian Huber | 2018-11-13 | 1 | -0/+1 |
| | | | | Update #3598. | ||||
* | Update to FreeBSD head 2018-10-23 | Sebastian Huber | 2018-10-25 | 3 | -0/+14 |
| | | | | | | | | | | | Git mirror commit 59f44d20be3f99d181ca742e636d45fc39ec982b. This commit updates OpenSSL to version 1.1.1. This required an update of racoon which uses some internal stuff from OpenSSL and seems to be mostly unmaintained, e.g. there is update in the FreeBSD ports to cope with OpenSSL 1.1.1. Update #3472. | ||||
* | Fix redefinition warnings | Sebastian Huber | 2018-10-23 | 1 | -4/+0 |
* | pppd: Fix use of uninitialized stack variables | Sebastian Huber | 2018-10-23 | 1 | -3/+3 |
* | Use global stdout for kernel output and syslog() | Sebastian Huber | 2018-10-10 | 1 | -7/+19 |
* | Fix syslog() priority handling | Sebastian Huber | 2018-10-10 | 1 | -10/+30 |
| | | | | Ths syslog priority is a mask not a level. | ||||
* | Fix typo (RTEMS_BSD_MODULE_NET80211) | Sebastian Huber | 2018-10-02 | 1 | -2/+2 |
* | telnetd: Update due to API changes | Sebastian Huber | 2018-10-02 | 1 | -7/+2 |
| | | | | Update #3526. | ||||
* | Add PHY-driver for KSZ8091RNB with 50MHz. | Christian Mauderer | 2018-09-27 | 1 | -0/+186 |
| | | | | | This adds a driver for the KSZ8091RNB PHY. This PHY needs some special treatment if it is clocked with a 50MHz clock. | ||||
* | fsl_sdhci.c: Port to RTEMS | Sebastian Huber | 2018-09-25 | 1 | -0/+3 |
| | | | | Update #3525. | ||||
* | imx/imx_gpio.c: Port to RTEMS | Sebastian Huber | 2018-09-25 | 1 | -0/+2 |
* | Update gpio interface | Sebastian Huber | 2018-09-25 | 2 | -10/+80 |
* | CONFIG_INTRHOOK(9): Port to RTEMS | Sebastian Huber | 2018-09-25 | 1 | -58/+0 |
| | | | | | | | | | Some device drivers (e.g. MMC) need a complex intialization with working callouts. Remove the dummy CONFIG_INTRHOOK() implementation and replace it with the real one from FreeBSD. Make sure TIMEOUT(9) services work at this point. Update #3525. | ||||
* | if_ffec_mpc8xx: Fix incoming data invalidation | Sebastian Huber | 2018-09-21 | 1 | -8/+4 |
| | | | | | | | With a write-back cache dirty cache lines may be evicted which could overwrite new data. Close #3523. | ||||
* | if_ffec_mpc8xx: Use M_NOWAIT for incoming frames | Sebastian Huber | 2018-09-21 | 1 | -22/+32 |
| | | | | Update #3523. | ||||
* | if_ffec_mpc8xx: New MDIO driver support | Sebastian Huber | 2018-09-21 | 2 | -172/+129 |
* | if_ffec_mpc8xx: Port driver to libbsd | Sebastian Huber | 2018-09-21 | 2 | -223/+186 |
* | if_ffec_mpc8xx: Import legacy driver from RTEMS | Sebastian Huber | 2018-09-21 | 1 | -0/+1248 |
| | | | | | | | Imported from RTEMS commit 1fe1b820de02c274c2b2b3431340152734ee9fb6 (2018-09-12). Update #3523. | ||||
* | Update to FreeBSD head 2018-09-17 | Sebastian Huber | 2018-09-21 | 18 | -129/+3069 |
| | | | | | | Git mirror commit 6c2192b1ef8c50788c751f878552526800b1e319. Update #3472. | ||||
* | Update to FreeBSD head 2018-06-01 | Sebastian Huber | 2018-09-21 | 7 | -38/+606 |
| | | | | | | Git mirror commit fb63610a69b0eb7f69a201ba05c4c1a7a2739cf9. Update #3472. | ||||
* | Update to FreeBSD head 2018-04-01 | Sebastian Huber | 2018-09-21 | 6 | -34/+189 |
| | | | | | | Git mirror commit 8dfb1ccc26d1cea7e2529303003ff61f9f1784c4. Update #3472. | ||||
* | Update to FreeBSD head 2018-02-01 | Sebastian Huber | 2018-09-21 | 15 | -60/+2755 |
| | | | | | | Git mirror commit d079ae0442af8fa3cfd6d7ede190d04e64a2c0d4. Update #3472. | ||||
* | Update to FreeBSD head 2017-12-01 | Sebastian Huber | 2018-09-21 | 9 | -23/+83 |
| | | | | | | Git mirror commit e724f51f811a4b2bd29447f8b85ab5c2f9b88266. Update #3472. | ||||
* | Update to FreeBSD head 2017-10-01 | Sebastian Huber | 2018-09-21 | 4 | -21/+53 |
| | | | | | | Git mirror commit b2f0376b45428f13151d229c5ae9d4d8f74acbd1. Update #3472. | ||||
* | Update to FreeBSD head 2017-08-01 | Sebastian Huber | 2018-09-21 | 8 | -9/+107 |
| | | | | | | Git mirror commit f5002f5e5f78cae9f0269d812dc0aedb0339312c. Update #3472. | ||||
* | Update to FreeBSD head 2017-06-01 | Sebastian Huber | 2018-09-21 | 3 | -24/+16 |
| | | | | | | Git mirror commit dfb26efac4ce9101dda240e94d9ab53f80a9e131. Update #3472. | ||||
* | mDNSResponder: Update to v765.1.2 | Sebastian Huber | 2018-09-20 | 1 | -0/+314 |
| | | | | | | | | | | | | | The sources can be obtained via: https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-765.1.2.tar.gz Move mDNS_StartResolveService() and mDNS_StopResolveService() to an RTEMS-specific file (rtemsbsd/mdns/mDNSResolveService.c) using the v576.30.4 implementation. Apple removed these functions without explanation. Update #3522. | ||||
* | mDNSResponder: Increase stack size | Sebastian Huber | 2018-09-20 | 1 | -1/+1 |
| | | | | | | | The current stack size was insuffient on a test run of the foobarclient test program. Update #3522. | ||||
* | mDNSResponder: Use FPU enabled task | Sebastian Huber | 2018-09-20 | 1 | -1/+1 |
