* | Add mmap | Vijay Kumar Banerjee | 2019-07-27 | 1 | -0/+38 |
* | Add rtems i2c adaptation layer | Vijay Kumar Banerjee | 2019-06-29 | 1 | -0/+231 |
* | if_atsam: Remove WDT_Disable() | Sebastian Huber | 2019-06-13 | 1 | -3/+0 |
| | | | | | The watchdog timer (WDT) can be configure only once. Do not touch it in the BSP since the application may want to use it. | ||||
* | dpaa: Use if_transmit instead of legacy if_start | Sebastian Huber | 2019-01-15 | 1 | -82/+65 |
| | | | | This avoids a lock contention on the send queue. | ||||
* | dpaa: Fix FMan MAC SGT zone alignment | Sebastian Huber | 2019-01-15 | 1 | -1/+1 |
* | Add PHY-driver for KSZ8091RNB with 50MHz. | Christian Mauderer | 2018-09-27 | 1 | -0/+186 |
| | | | | | This adds a driver for the KSZ8091RNB PHY. This PHY needs some special treatment if it is clocked with a 50MHz clock. | ||||
* | if_ffec_mpc8xx: Fix incoming data invalidation | Sebastian Huber | 2018-09-21 | 1 | -8/+4 |
| | | | | | | | With a write-back cache dirty cache lines may be evicted which could overwrite new data. Close #3523. | ||||
* | if_ffec_mpc8xx: Use M_NOWAIT for incoming frames | Sebastian Huber | 2018-09-21 | 1 | -22/+32 |
| | | | | Update #3523. | ||||
* | if_ffec_mpc8xx: New MDIO driver support | Sebastian Huber | 2018-09-21 | 1 | -172/+128 |
* | if_ffec_mpc8xx: Port driver to libbsd | Sebastian Huber | 2018-09-21 | 1 | -223/+182 |
* | if_ffec_mpc8xx: Import legacy driver from RTEMS | Sebastian Huber | 2018-09-21 | 1 | -0/+1248 |
| | | | | | | | Imported from RTEMS commit 1fe1b820de02c274c2b2b3431340152734ee9fb6 (2018-09-12). Update #3523. | ||||
* | Update to FreeBSD head 2018-09-17 | Sebastian Huber | 2018-09-21 | 5 | -0/+2213 |
| | | | | | | Git mirror commit 6c2192b1ef8c50788c751f878552526800b1e319. Update #3472. | ||||
* | Update to FreeBSD head 2018-06-01 | Sebastian Huber | 2018-09-21 | 1 | -2/+16 |
| | | | | | | Git mirror commit fb63610a69b0eb7f69a201ba05c4c1a7a2739cf9. Update #3472. | ||||
* | Update to FreeBSD head 2018-02-01 | Sebastian Huber | 2018-09-21 | 5 | -0/+2503 |
| | | | | | | Git mirror commit d079ae0442af8fa3cfd6d7ede190d04e64a2c0d4. Update #3472. | ||||
* | dw_mmc: Avoid conflicting device ivars | Sebastian Huber | 2018-09-11 | 1 | -2/+1 |
| | | | | | Do not overwrite the device ivars used by the simplebus. Use unspecified unit number for child device. | ||||
* | DEVFS(5): Properly initialize fp->f_cdevpriv | Sebastian Huber | 2018-03-27 | 1 | -0/+1 |
* | if_atsam: Add checksum offload. | Christian Mauderer | 2018-03-21 | 1 | -8/+44 |
* | dw_mmc: Properly init/reset DMA | Sebastian Huber | 2018-02-06 | 1 | -12/+27 |
* | dw_mmc: Add MMCBR_IVAR_TIMING | Sebastian Huber | 2018-02-06 | 1 | -0/+6 |
* | Add device tree support for Altera/Intel Cyclone V | Sebastian Huber | 2018-02-06 | 2 | -157/+16 |
| | | | | Close #3290. | ||||
* | sdk_dpaa: Port to RTEMS | Sebastian Huber | 2018-01-23 | 1 | -0/+208 |
| | | | | Update #3277. | ||||
* | linux/of_irq.h: Generalize of_irq_to_resource() | Sebastian Huber | 2018-01-23 | 1 | -10/+51 |
| | | | | | | Determine interrupt cells via device tree. Update #3277. | ||||
* | linux/of_address.h: of_address_to_resource() | Sebastian Huber | 2018-01-23 | 1 | -15/+7 |
| | | | | | | Translate address in of_address_to_resource(). Update #3277. | ||||
* | linux/of_address.h: Add of_translate_address() | Sebastian Huber | 2018-01-23 | 1 | -1/+75 |
* | linux/of.h: Add of_find_node_by_path() | Sebastian Huber | 2018-01-23 | 1 | -0/+16 |
* | linux/of.h: Add of_read_number() | Sebastian Huber | 2018-01-23 | 1 | -0/+16 |
* | linux/of.h: Add of_n_size_cells() | Sebastian Huber | 2018-01-23 | 1 | -0/+7 |
* | linux/of.h: Add of_n_addr_cells() | Sebastian Huber | 2018-01-23 | 1 | -0/+7 |
* | ehci_mpc83xx.c: Fix for qoriq hypervisor guest | Sebastian Huber | 2018-01-19 | 1 | -1/+2 |
* | dpaa: Use only one FMan MAC SGT zone | Sebastian Huber | 2017-10-23 | 2 | -17/+19 |
* | dpaa: Add "libbsd,dedicated-portal" to QMan portals | Sebastian Huber | 2017-10-23 | 1 | -0/+9 |
| | | | | | | | | | | | | | | | | | By default, the network interfaces use a pool channel, see dpaa_get_channel() in dpaa_eth_priv_probe(). To enable a dedicated QMan software portal, use libbsd,dedicated-portal = "enabled";. This option is useful for special purpose 10Gbit/s Ethernet processing. / { soc: soc@ffe000000 { fman0: fman@400000 { enet7: ethernet@f2000 { libbsd,dedicated-portal = "enabled"; }; }; }; }; | ||||
* | dpaa: Add <soc/fsl/dpaa.h> | Sebastian Huber | 2017-10-23 | 1 | -0/+11 |
* | dpaa: Get c45 ids | Sebastian Huber | 2017-10-23 | 1 | -0/+108 |
* | dpaa: No error if MII attach failed | Sebastian Huber | 2017-10-23 | 1 | -4/+2 |
* | dpaa: Support c45 phys | Sebastian Huber | 2017-10-23 | 1 | -48/+98 |
* | dpaa: Use receive checksum offload | Sebastian Huber | 2017-10-23 | 1 | -1/+1 |
* | Linux update to 4.11-rc5 | Sebastian Huber | 2017-10-23 | 5 | -343/+247 |
| | | | | Linux baseline a71c9a1c779f2499fb2afc0553e543f18aff6edf (4.11-rc5). | ||||
* | Import DPAA driver snapshot | Sebastian Huber | 2017-10-23 | 6 | -0/+2621 |
| | | | | | | | | | | Imported from Freescale Linux repository git://git.freescale.com/ppc/upstream/linux.git commit 2774c204cd8bfc56a200ff4dcdfc9cdf5b6fc161. Linux compatibility layer is partly from FreeBSD. | ||||
* | if_atsam: Allow fixed MII settings. | Christian Mauderer | 2017-09-22 | 2 | -65/+173 |
* | if_atsam: Move statistics to sysctl. | Christian Mauderer | 2017-09-22 | 1 | -96/+319 |
* | if-atsam: Port to rtems-libbsd. | Christian Mauderer | 2017-09-22 | 1 | -328/+297 |
* | rtemsbsd/if-atsam: Copy from RTEMS. | Christian Mauderer | 2017-09-22 | 1 | -0/+1259 |
| | | | | Copied from RTEMS commit 146adb1edf from 17.07.2017. | ||||
* | ohci: Fix for BSP_USB_OTG_TRANSCEIVER_I2C_ADDR | Sebastian Huber | 2017-07-18 | 1 | -0/+2 |
* | Use <sys/lock.h> provided by Newlib | Sebastian Huber | 2017-06-08 | 5 | -5/+5 |
* | Update due to Newlib 2017-06-07 changes | Sebastian Huber | 2017-06-08 | 11 | -13/+14 |
| | | | | | | | | | | | | | | | | | The following files are now provided by Newlib: * arpa/inet.h * net/if.h * netinet/in.h * netinet/tcp.h * sys/socket.h * sys/uio.h * sys/un.h The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be used directly. Update #2833. | ||||
* | Add LPC32XX touch screen driver | Kevin Kirspel | 2017-05-19 | 1 | -0/+421 |
* | devfs: Fix some issues | Kevin Kirspel | 2017-05-12 | 1 | -16/+138 |
| | | | | | Fix issue with cdev private data usage with RTEMS iop structure. Add support for cdev alias device names. Add support for cdev fstat. | ||||
* | Adding RTEMS support for FREEBSD TTY | Kevin Kirspel | 2017-05-11 | 1 | -6/+80 |
* | ppp: Update due to API changes | Sebastian Huber | 2017-04-03 | 1 | -5/+8 |
* | Fix dw_mmc dependencies | Sebastian Huber | 2017-03-01 | 1 | -0/+2 |
