* | Fix dw_mmc dependencies | Sebastian Huber | 2017-03-01 | 1 | -0/+2 |
* | Port LPC32XX Ethernet and USB OHCI to RTEMS | Kevin Kirspel | 2017-02-14 | 3 | -91/+502 |
* | devfs: Fix typo | Sebastian Huber | 2017-01-10 | 1 | -1/+1 |
* | Update to FreeBSD head 2016-08-23 | Sebastian Huber | 2017-01-10 | 7 | -41/+35 |
| | | | | Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd. | ||||
* | PIPE(2): Port to RTEMS | Kevin Kirspel | 2016-12-23 | 1 | -0/+29 |
* | devfs: Fix includes | Sebastian Huber | 2016-10-26 | 1 | -5/+8 |
* | ohci: Fixes due to USB stack update | Sebastian Huber | 2016-10-07 | 1 | -21/+7 |
* | if_ffec_mcf548x.c: Fix include order | Sebastian Huber | 2016-09-23 | 1 | -2/+2 |
* | devfs: Create path. | Christian Mauderer | 2016-08-16 | 1 | -2/+33 |
* | if_ffec_mcf548x: Init when interface is set to UP. | Christian Mauderer | 2016-08-05 | 1 | -0/+8 |
| | | | | Call the driver initialization function if the interface is set to UP. | ||||
* | rtemsbsd/devfs: Add. | Christian Mauderer | 2016-08-01 | 1 | -0/+293 |
* | Directly use <sys/types.h> provided by Newlib | Sebastian Huber | 2016-05-30 | 2 | -2/+2 |
* | dwc_otg: Port to RTEMS | Sebastian Huber | 2015-11-12 | 1 | -0/+156 |
* | Update due to header guard changes | Sebastian Huber | 2015-07-23 | 1 | -2/+2 |
* | usb: Import USB support from libusb | Sebastian Huber | 2015-05-15 | 7 | -837/+1256 |
* | dw_mmc: Implement host acquire/release | Sebastian Huber | 2015-03-26 | 1 | -11/+10 |
| | | | | This should avoid the "mmc: host bridge didn't serialize us." panic. | ||||
* | mmc: Import MMC/SDCard support from libusb | Sebastian Huber | 2015-03-26 | 2 | -0/+1326 |
* | if_tsec: Add Nexus support | Sebastian Huber | 2015-02-13 | 1 | -0/+310 |
* | ffec: Accept all mulitcast frames | Sebastian Huber | 2014-10-31 | 1 | -2/+2 |
* | ppp: Port to new stack | Sebastian Huber | 2014-10-08 | 3 | -157/+180 |
* | ppp: Import from RTEMS sources | Sebastian Huber | 2014-10-08 | 6 | -0/+3345 |
* | Fix legacy MCF548X FEC interface driver | Sebastian Huber | 2014-01-30 | 1 | -5/+0 |
* | Update legacy MCF548X FEC interface driver | Sebastian Huber | 2013-12-16 | 1 | -259/+145 |
* | Add legacy MCF548X FEC interface driver | Sebastian Huber | 2013-12-16 | 1 | -0/+1697 |
* | ehci_mpc83xx.c: Update due to API changes | Sebastian Huber | 2013-12-04 | 1 | -37/+25 |
* | if_smc: Add Nexus device support | Sebastian Huber | 2013-11-13 | 1 | -0/+91 |
* | Rename rtems-bsd-config.h | Sebastian Huber | 2013-11-11 | 3 | -3/+3 |
| | | | | Rename rtems-bsd-config.h in rtems-bsd-kernel-space.h. | ||||
* | Update files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 3 | -99/+99 |
| | | | | | | | | | | | | | | | | | | | Add compatibility with Newlib header files. Some FreeBSD header files are mapped by the translation script: o rtems/bsd/sys/_types.h o rtems/bsd/sys/errno.h o rtems/bsd/sys/lock.h o rtems/bsd/sys/param.h o rtems/bsd/sys/resource.h o rtems/bsd/sys/time.h o rtems/bsd/sys/timespec.h o rtems/bsd/sys/types.h o rtems/bsd/sys/unistd.h It is now possible to include <sys/socket.h> directly for example. Generate one Makefile which builds everything including tests. | ||||
* | Move files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 3 | -0/+1121 |
