* | PING(8): Default to three packets | Sebastian Huber | 2014-09-24 | 1 | -1/+1 |
| | | | | | In the standard RTEMS shell it is not possible to use CTRL-C, to stop the program. So use a default with finite run-time. | ||||
* | IFCONFIG(8): Default to AF_INET for RTEMS | Sebastian Huber | 2014-09-24 | 1 | -0/+4 |
| | | | | Avoid errors due to optional AF_LOCAL. | ||||
* | ROUTE(8): Fix memory leak | Sebastian Huber | 2013-12-20 | 1 | -1/+1 |
* | ROUTE(8): Initialize file descriptor | Sebastian Huber | 2013-12-20 | 1 | -0/+1 |
* | commands: Use REQUIRE_ORDER option processing | Sebastian Huber | 2013-11-13 | 4 | -3/+7 |
* | Update to FreeBSD 9.2 | Sebastian Huber | 2013-11-11 | 15 | -360/+655 |
* | Reduce divergence from FreeBSD sources | Sebastian Huber | 2013-11-11 | 1 | -2/+1 |
* | Move content to <machine/rtems-bsd-user-space.h> | Sebastian Huber | 2013-11-11 | 1 | -7/+0 |
* | Add and use <machine/rtems-bsd-user-space.h> | Sebastian Huber | 2013-11-11 | 36 | -0/+72 |
* | Update to FreeBSD 8.4 | Sebastian Huber | 2013-11-04 | 13 | -236/+558 |
* | PING6(8): Fix resource leaks | Sebastian Huber | 2013-10-31 | 1 | -2/+24 |
* | PING6(8): Add RTEMS support | Sebastian Huber | 2013-10-31 | 1 | -11/+47 |
* | PING6(8): Delete unused variable | Sebastian Huber | 2013-10-31 | 1 | -1/+0 |
* | PING6(8): Fix isxdigit() usage | Sebastian Huber | 2013-10-31 | 1 | -1/+1 |
* | PING6(8): Delete unused variable | Sebastian Huber | 2013-10-31 | 1 | -2/+1 |
* | PING6(8): Add const qualifier | Sebastian Huber | 2013-10-31 | 1 | -4/+4 |
* | PING6(8): Use local scope for functions | Sebastian Huber | 2013-10-31 | 1 | -33/+34 |
* | PING6(8): Use local scope for global variables | Sebastian Huber | 2013-10-31 | 1 | -37/+37 |
* | ROUTE(8): Add and use context | Sebastian Huber | 2013-10-31 | 1 | -3/+4 |
* | PING(8): Fix initialization and cleanup | Sebastian Huber | 2013-10-31 | 1 | -0/+16 |
* | PING(8): Delete unused variable | Sebastian Huber | 2013-10-31 | 1 | -1/+0 |
* | PING(8): Add const qualifier | Sebastian Huber | 2013-10-31 | 1 | -7/+4 |
* | PING(8): Use local scope for global variables | Sebastian Huber | 2013-10-31 | 1 | -42/+42 |
* | PING(8): Use BSD program lock | Sebastian Huber | 2013-10-31 | 1 | -4/+11 |
* | PING(8): Avoid large buffers on the stack | Sebastian Huber | 2013-10-31 | 1 | -0/+10 |
* | PING(8): Fix isxdigit() usage | Sebastian Huber | 2013-10-31 | 1 | -1/+1 |
* | PING(8): Do not use signals | Sebastian Huber | 2013-10-31 | 1 | -11/+12 |
* | IFCONFIG(8): Avoid write to const string | Sebastian Huber | 2013-10-31 | 1 | -4/+14 |
* | IFCONFIG(8): Wrap exit() | Sebastian Huber | 2013-10-31 | 2 | -0/+6 |
* | IFCONFIG(8): Fix some resource leaks | Sebastian Huber | 2013-10-31 | 5 | -4/+54 |
* | IFCONFIG(8): Initialize global variables in ctors | Sebastian Huber | 2013-10-31 | 18 | -10/+180 |
* | IFCONFIG(8): Fix isdigit() and isprint() usage | Sebastian Huber | 2013-10-31 | 3 | -4/+4 |
* | IFCONFIG(8): Add const qualifier | Sebastian Huber | 2013-10-31 | 5 | -61/+61 |
* | IFCONFIG(8): Avoid JAIL(3) | Sebastian Huber | 2013-10-31 | 1 | -7/+4 |
* | IFCONFIG(8): Workaround for struct option confict | Sebastian Huber | 2013-10-31 | 5 | -43/+2 |
* | ROUTE(8): Adjust port to RTEMS | Sebastian Huber | 2013-10-31 | 1 | -5/+48 |
* | ROUTE(8): Free dynamic memory | Sebastian Huber | 2013-10-31 | 1 | -2/+4 |
* | ROUTE(8): Add and use context | Sebastian Huber | 2013-10-31 | 1 | -270/+298 |
| | | | | | There is no point in aiming for long term FreeBSD compatibility here. The issues must be fixed upstream and then move back to the RTEMS port. | ||||
* | Move shell items to separate file | Sebastian Huber | 2013-10-31 | 3 | -42/+6 |
* | Move program control to thread structure | Sebastian Huber | 2013-10-31 | 3 | -75/+50 |
* | Simplify getopt() to getopt_r() translation | Sebastian Huber | 2013-10-31 | 4 | -62/+50 |
* | Update files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 28 | -188/+34 |
| | | | | | | | | | | | | | | | | | | | Add compatibility with Newlib header files. Some FreeBSD header files are mapped by the translation script: o rtems/bsd/sys/_types.h o rtems/bsd/sys/errno.h o rtems/bsd/sys/lock.h o rtems/bsd/sys/param.h o rtems/bsd/sys/resource.h o rtems/bsd/sys/time.h o rtems/bsd/sys/timespec.h o rtems/bsd/sys/types.h o rtems/bsd/sys/unistd.h It is now possible to include <sys/socket.h> directly for example. Generate one Makefile which builds everything including tests. | ||||
* | Move files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 45 | -0/+26729 |
