* | buildset: Add minimal and everything config. | Christian Mauderer | 2018-05-03 | 2 | -0/+7 |
| | | | | | | | | | | | | This adds two new buildset configurations: One that leaves out as much features as possible and one that enables all features. For the default configuration WiFi support is now disabled. To disable IPv6 for the minimal configuration, all -DINET6 are eliminated in libbsd.py. They are now replaced by a #ifdef that checks for RTEMS_BSD_MODULE_NETINET6 instead. Close #3351. | ||||
* | Update due to Newlib 2017-06-07 changes | Sebastian Huber | 2017-06-08 | 23 | -23/+23 |
| | | | | | | | | | | | | | | | | | The following files are now provided by Newlib: * arpa/inet.h * net/if.h * netinet/in.h * netinet/tcp.h * sys/socket.h * sys/uio.h * sys/un.h The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be used directly. Update #2833. | ||||
* | Update to FreeBSD head 2017-04-04 | Sebastian Huber | 2017-04-04 | 13 | -35/+128 |
| | | | | Git mirror commit 642b174daddbd0efd9bb5f242c43f4ab4db6869f. | ||||
* | SYSCTL(8): Fix command line option processing | Sebastian Huber | 2017-02-14 | 1 | -0/+9 |
* | userspace tools: Regenerate headers. | Christian Mauderer | 2017-01-17 | 18 | -28/+28 |
* | ifconfig/wlan, expat, lib80211: Port to RTEMS. | Christian Mauderer | 2017-01-17 | 5 | -2/+48 |
* | ifconfig/wlan, expat, lib80211: Import from FreeBSD. | Christian Mauderer | 2017-01-17 | 2 | -272/+547 |
* | ROUTE(8): Disable routing socket timeout support | Sebastian Huber | 2017-01-11 | 2 | -1/+12 |
| | | | | | | | | | | | | | | FIXME: This reverts the following change in FreeBSD. commit 76a39ff8dc5e1f7bc8a065115ec3837761ed0600 Author: ae <ae@FreeBSD.org> Date: Wed Jul 27 08:26:34 2016 +0000 Due to dropped mbuf in netisr queue route(8) can fall into infinity loop of reading the rtsock's feed. When it used by some scripts, this leads to growing number of not finished route(8) instances and thus growing number of rtsock consumers. Add SIGALRM handler to prevent this. | ||||
* | pf: Some fixes after the update | Sebastian Huber | 2017-01-10 | 3 | -0/+5 |
* | Update to FreeBSD head 2017-01-09 | Sebastian Huber | 2017-01-10 | 6 | -832/+885 |
| | | | | Git mirror commit 1f8e4a995a6ede4bdb24e6d335ccda2bdb0175ab. | ||||
* | Update to FreeBSD head 2016-12-10 | Sebastian Huber | 2017-01-10 | 15 | -35/+168 |
| | | | | Git mirror commit 80c55f08a05ab3b26a73b226ccb56adc3122a55c. | ||||
* | Update to FreeBSD head 2016-08-23 | Sebastian Huber | 2017-01-10 | 89 | -2114/+32038 |
| | | | | Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd. | ||||
* | Add SIZE_T_MAX to <machine/rtems-bsd-user-space.h> | Sebastian Huber | 2016-10-24 | 1 | -3/+0 |
* | Remove AppleTalk support | Sebastian Huber | 2016-10-13 | 3 | -245/+0 |
| | | | | Prepare update to FreeBSD 11. | ||||
* | freebsd: Don't use new wrappers for old ports. | Christian Mauderer | 2016-08-02 | 7 | -0/+63 |
| | | | | | | Some of the commands have been adapted manually. So the wrapper currently don't necessarily work as expected. For example ifconfig calls malloc outside of the program call. | ||||
* | Directly use <sys/types.h> provided by Newlib | Sebastian Huber | 2016-05-30 | 8 | -8/+8 |
* | Directly use <sys/time.h> provided by Newlib | Sebastian Huber | 2016-05-30 | 7 | -7/+7 |
* | Add sbin/sysctl | Chris Johns | 2016-05-06 | 1 | -0/+784 |
* | dhclient: Avoid SIZE_T_MAX | Sebastian Huber | 2016-04-18 | 1 | -0/+3 |
| | | | | | Use SIZE_MAX instead of SIZE_T_MAX to avoid a dependency on BSD specifics. | ||||
* | Update to FreeBSD Stable/9 2015-04-08 | Sebastian Huber | 2015-05-20 | 3 | -5/+13 |
* | Add generated files | Sebastian Huber | 2015-04-08 | 1 | -0/+110 |
| | | | | | | This avoids dependencies on a particular generator tool version. On MinGW and Cygwin hosts these tools tend to be outdated or somehow incapable. | ||||
* | Update to FreeBSD 9.3 | Sebastian Huber | 2015-02-13 | 4 | -6/+28 |
* | PING(8): Default to three packets | Sebastian Huber | 2014-09-24 | 1 | -1/+1 |
| | | | | | In the standard RTEMS shell it is not possible to use CTRL-C, to stop the program. So use a default with finite run-time. | ||||
* | IFCONFIG(8): Default to AF_INET for RTEMS | Sebastian Huber | 2014-09-24 | 1 | -0/+4 |
| | | | | Avoid errors due to optional AF_LOCAL. | ||||
* | ROUTE(8): Fix memory leak | Sebastian Huber | 2013-12-20 | 1 | -1/+1 |
* | ROUTE(8): Initialize file descriptor | Sebastian Huber | 2013-12-20 | 1 | -0/+1 |
* | commands: Use REQUIRE_ORDER option processing | Sebastian Huber | 2013-11-13 | 4 | -3/+7 |
* | Update to FreeBSD 9.2 | Sebastian Huber | 2013-11-11 | 15 | -360/+655 |
* | Reduce divergence from FreeBSD sources | Sebastian Huber | 2013-11-11 | 1 | -2/+1 |
* | Move content to <machine/rtems-bsd-user-space.h> | Sebastian Huber | 2013-11-11 | 1 | -7/+0 |
* | Add and use <machine/rtems-bsd-user-space.h> | Sebastian Huber | 2013-11-11 | 36 | -0/+72 |
* | Update to FreeBSD 8.4 | Sebastian Huber | 2013-11-04 | 13 | -236/+558 |
* | PING6(8): Fix resource leaks | Sebastian Huber | 2013-10-31 | 1 | -2/+24 |
* | PING6(8): Add RTEMS support | Sebastian Huber | 2013-10-31 | 1 | -11/+47 |
* | PING6(8): Delete unused variable | Sebastian Huber | 2013-10-31 | 1 | -1/+0 |
* | PING6(8): Fix isxdigit() usage | Sebastian Huber | 2013-10-31 | 1 | -1/+1 |
* | PING6(8): Delete unused variable | Sebastian Huber | 2013-10-31 | 1 | -2/+1 |
* | PING6(8): Add const qualifier | Sebastian Huber | 2013-10-31 | 1 | -4/+4 |
* | PING6(8): Use local scope for functions | Sebastian Huber | 2013-10-31 | 1 | -33/+34 |
* | PING6(8): Use local scope for global variables | Sebastian Huber | 2013-10-31 | 1 | -37/+37 |
* | ROUTE(8): Add and use context | Sebastian Huber | 2013-10-31 | 1 | -3/+4 |
* | PING(8): Fix initialization and cleanup | Sebastian Huber | 2013-10-31 | 1 | -0/+16 |
* | PING(8): Delete unused variable | Sebastian Huber | 2013-10-31 | 1 | -1/+0 |
* | PING(8): Add const qualifier | Sebastian Huber | 2013-10-31 | 1 | -7/+4 |
* | PING(8): Use local scope for global variables | Sebastian Huber | 2013-10-31 | 1 | -42/+42 |
* | PING(8): Use BSD program lock | Sebastian Huber | 2013-10-31 | 1 | -4/+11 |
* | PING(8): Avoid large buffers on the stack | Sebastian Huber | 2013-10-31 | 1 | -0/+10 |
* | PING(8): Fix isxdigit() usage | Sebastian Huber | 2013-10-31 | 1 | -1/+1 |
* | PING(8): Do not use signals | Sebastian Huber | 2013-10-31 | 1 | -11/+12 |
* | IFCONFIG(8): Avoid write to const string | Sebastian Huber | 2013-10-31 | 1 | -4/+14 |
