* | fbd: Import from FreeBSD | Vijay Kumar Banerjee | 2019-08-11 | 10 | -0/+3621 |
* | TDA19988: Port to RTEMS | Vijay Kumar Banerjee | 2019-08-11 | 10 | -0/+372 |
* | TDA19988: Import from FreeBSD | Vijay Kumar Banerjee | 2019-08-11 | 12 | -0/+3362 |
* | Pinmux: Port to RTEMS | Vijay Kumar Banerjee | 2019-08-11 | 7 | -0/+124 |
* | Pinmux : Import from FreeBSD | Vijay Kumar Banerjee | 2019-08-11 | 6 | -0/+1138 |
* | Add mmap | Vijay Kumar Banerjee | 2019-07-27 | 7 | -7/+71 |
* | EPOCH(9): Add epoch_drain_callbacks() | Sebastian Huber | 2019-07-09 | 3 | -2/+138 |
* | test/epoch01: Simplify | Sebastian Huber | 2019-07-09 | 1 | -48/+36 |
* | EPOCH(9): Avoid inline functions | Sebastian Huber | 2019-07-09 | 2 | -27/+35 |
| | | | | | FreeBSD changed the epoch_enter() and epoch_exit() inline functions into proper functions after a performance analysis to avoid code bloat. | ||||
* | SLEEPQUEUE(9): Fix timeout handling | Sebastian Huber | 2019-07-05 | 3 | -2/+8 |
* | i2c tool : port to RTEMS | Vijay Kumar Banerjee | 2019-06-29 | 5 | -0/+76 |
* | i2c tool : Import from FreeBSD | Vijay Kumar Banerjee | 2019-06-29 | 1 | -0/+733 |
* | Add rtems i2c adaptation layer | Vijay Kumar Banerjee | 2019-06-29 | 2 | -0/+232 |
* | iicbus: port to RTEMS | Vijay Kumar Banerjee | 2019-06-29 | 7 | -0/+324 |
* | iicbus: Import from FreeBSD | Vijay Kumar Banerjee | 2019-06-29 | 7 | -0/+1970 |
* | test/commands01: Fix sporadic test failures | Sebastian Huber | 2019-06-26 | 1 | -1/+29 |
* | test/program01: Fix sporadic test failures | Sebastian Huber | 2019-06-26 | 1 | -0/+8 |
* | if_atsam: Remove WDT_Disable() | Sebastian Huber | 2019-06-13 | 1 | -3/+0 |
| | | | | | The watchdog timer (WDT) can be configure only once. Do not touch it in the BSP since the application may want to use it. | ||||
* | config: Control the interface from the command line net config file. | Chris Johns | 2019-06-12 | 3 | -2/+4 |
* | Remove junk folders. | Chris Johns | 2019-06-12 | 2 | -0/+0 |
* | Add RTEMS-specific getcredhostuuid() | Sebastian Huber | 2019-06-05 | 2 | -11/+29 |
* | CONTRIBUTING: mention pyelftools dependency | Vijay Kumar Banerjee | 2019-05-24 | 1 | -0/+3 |
* | Add riscv support | Sebastian Huber | 2019-05-23 | 2 | -1/+84 |
* | Use _SMP_Unicast_action() | Sebastian Huber | 2019-05-21 | 2 | -8/+2 |
| | | | | It is a bit more efficient. | ||||
* | Update due to API changes | Sebastian Huber | 2019-05-15 | 1 | -5/+3 |
| | | | | Close #3749. | ||||
* | Separate libbsd and RTEMS clock ticks | Sebastian Huber | 2019-05-15 | 8 | -26/+15 |
* | Fix USB_DEBUG redefinition warnings | Sebastian Huber | 2019-05-13 | 1 | -0/+12 |
* | Include missing <stdlib.h> to fix warnings | Sebastian Huber | 2019-05-13 | 1 | -0/+1 |
* | Remove unused maxusers | Sebastian Huber | 2019-05-13 | 2 | -3/+0 |
* | Remove jail/prison functions from namespace | Sebastian Huber | 2019-05-13 | 1 | -21/+0 |
* | Remove dangerous weak definition of getentropy() | Sebastian Huber | 2019-05-13 | 1 | -12/+0 |
| | | | | All BSP supporting libbsd should provide this function. | ||||
* | Add hostname related sysctls conditionally | Sebastian Huber | 2019-05-13 | 1 | -0/+5 |
| | | | | This helps to the reduce code size for USB only use cases. | ||||
* | usb: Undefine USB_DEBUG | Sebastian Huber | 2019-05-13 | 1 | -1/+1 |
| | | | | | | In contrast to some other USB options which use 0/1 values, the USB_DEBUG uses defined/undefined to enable/disable the USB debug support. | ||||
* | Add wrapper for abort() | Sebastian Huber | 2019-05-13 | 1 | -2/+7 |
* | Add USB mass storage only build set | Sebastian Huber | 2019-05-13 | 2 | -0/+22 |
* | Use static inline functions for jail and prison | Sebastian Huber | 2019-05-13 | 2 | -230/+202 |
| | | | | This helps the compiler to optimize away dead code. | ||||
* | Fix zero-copy mbuf support | Sebastian Huber | 2019-05-13 | 3 | -7/+5 |
| | | | | In 2017 there was a change in the mbuf API. | ||||
* | IFCONFIG(8): Fix write to const string | Sebastian Huber | 2019-05-13 | 1 | -0/+6 |
* | Update due to API changes | Sebastian Huber | 2019-04-11 | 12 | -18/+18 |
* | Import FreeBSD license files. | Christian Mauderer | 2019-04-04 | 10 | -0/+449 |
* | builder.py: Add case for plain text files. | Christian Mauderer | 2019-04-04 | 1 | -0/+8 |
* | Add helper script to find licenses. | Christian Mauderer | 2019-04-04 | 1 | -0/+121 |
* | Fix the sed generator for processing INI configuration files. | Chris Johns | 2019-04-04 | 1 | -2/+2 |
* | Remove pcap_version.h | Vijay Kumar Banerjee | 2019-04-02 | 2 | -17/+0 |
* | nfsclient: Fix for 64-bit targets | Sebastian Huber | 2019-03-29 | 1 | -1/+8 |
| | | | | | | | The use of the serporid structure with several embedded unions to split up the specific NFS request/response structures is quite a hack. It breaks on 64-bit targets due to the presence of pointer members which affect the overall alignment. | ||||
* | openssl02: Fix includes | Sebastian Huber | 2019-03-29 | 1 | -7/+3 |
* | BPF(9): Disable legacy timestamp support | Sebastian Huber | 2019-03-29 | 1 | -0/+7 |
* | Revert "Add BURN_BRIDGES global kernel option" | Sebastian Huber | 2019-03-29 | 1 | -5/+0 |
| | | | | This reverts commit 0904e3371406d2775cba848da441e00fd1ef1ef6. | ||||
* | Add BURN_BRIDGES global kernel option | Sebastian Huber | 2019-03-28 | 1 | -0/+5 |
* | BPF(9): Fix timestamps | Sebastian Huber | 2019-03-28 | 1 | -0/+1 |
