* | NVD(4): Add RTEMS-specific NVMe disk driver | Sebastian Huber | 2019-11-13 | 2 | -0/+347 |
| | | | | Update #3821. | ||||
* | NVME(4): Add NVME_GET_NAMESPACE IO control | Sebastian Huber | 2019-11-13 | 2 | -0/+8 |
* | NVME(4): Install header files | Sebastian Huber | 2019-11-13 | 1 | -0/+1 |
* | NVME(4): Enable per-CPU IO queues | Sebastian Huber | 2019-11-13 | 1 | -0/+7 |
* | NVME(4): Add support for SGL | Sebastian Huber | 2019-11-13 | 4 | -0/+118 |
* | NVME(4): Add SGL descriptor | Sebastian Huber | 2019-11-13 | 1 | -0/+24 |
* | NVME(4): Optimize data transfer | Sebastian Huber | 2019-11-13 | 2 | -0/+56 |
* | NVME(4): Big endian support | Sebastian Huber | 2019-11-13 | 1 | -5/+5 |
* | NVME(4): Port to RTEMS | Sebastian Huber | 2019-11-13 | 8 | -0/+31 |
* | NVME(4): Add build module | Sebastian Huber | 2019-11-13 | 1 | -0/+30 |
* | NVME(4): Import from FreeBSD | Sebastian Huber | 2019-11-13 | 10 | -0/+5570 |
* | Add support for EARLY_COUNTER | Sebastian Huber | 2019-09-25 | 3 | -0/+17 |
* | Fix warnings | Sebastian Huber | 2019-09-25 | 6 | -11/+15 |
* | Remove obsolete header files | Sebastian Huber | 2019-09-25 | 3 | -207/+0 |
* | Compatibility for next Newlib update | Sebastian Huber | 2019-09-25 | 1 | -0/+5 |
* | Fix pgsigio() warnings | Sebastian Huber | 2019-09-25 | 4 | -52/+14 |
* | Add compatiblity for older Newlib variants | Sebastian Huber | 2019-09-25 | 1 | -0/+36 |
* | Update to FreeBSD stable/12 2019-09-23 | Sebastian Huber | 2019-09-23 | 304 | -2228/+5685 |
| | | | | Git mirror commit 7e8d1444023128d34fb9aa4e4515928a4f794d1b. | ||||
* | Add pselect() | Sebastian Huber | 2019-09-23 | 3 | -1/+174 |
* | test/syscalls01: Fix sporadic test failures | Sebastian Huber | 2019-09-23 | 1 | -0/+32 |
* | PCI(4): Import missing file | Sebastian Huber | 2019-09-23 | 2 | -1/+86 |
* | PCI(4): Disable unsupported features | Sebastian Huber | 2019-09-23 | 1 | -0/+10 |
* | PCI(4): Add big endian support | Sebastian Huber | 2019-09-23 | 1 | -0/+8 |
* | PCI(4): Install header files | Sebastian Huber | 2019-09-23 | 1 | -0/+1 |
* | Add <sys/disk.h> to build module | Sebastian Huber | 2019-09-23 | 1 | -0/+1 |
* | CONFIG_INTRHOOK(9): Call handlers after boot | Sebastian Huber | 2019-09-23 | 2 | -5/+45 |
| | | | | | This enables adding drivers on demand which use this service after initialization. | ||||
* | nexus: Avoid NULL pointer access | Sebastian Huber | 2019-09-23 | 1 | -1/+4 |
* | C++ compatibility for <dev/pci/pcivar.h> | Sebastian Huber | 2019-09-23 | 1 | -1/+1 |
* | C++ compatiblity for kernel space header | Sebastian Huber | 2019-09-23 | 1 | -0/+8 |
* | C++ compatibility for kernel space <sys/sysctl.h> | Sebastian Huber | 2019-09-23 | 1 | -0/+2 |
* | Add wrapper for strndup() | Sebastian Huber | 2019-09-11 | 4 | -15/+55 |
* | media01: Reduce record item count | Sebastian Huber | 2019-08-27 | 1 | -1/+1 |
* | libsodium: Disable unused function | Sebastian Huber | 2019-08-27 | 1 | -0/+2 |
* | tty.c: Disable unused functions | Sebastian Huber | 2019-08-27 | 1 | -4/+2 |
* | pf_ioctl.c: Disable superfluous unload support | Sebastian Huber | 2019-08-27 | 1 | -0/+4 |
* | kern_intr.c: Disable unused functions | Sebastian Huber | 2019-08-27 | 1 | -3/+1 |
* | Remove superfluous support for preloaded modules | Sebastian Huber | 2019-08-27 | 3 | -314/+2 |
* | atomic.h: Add atomic_load_long() | Sebastian Huber | 2019-08-27 | 1 | -0/+21 |
* | Update to FreeBSD stable/12 2019-08-26 | Sebastian Huber | 2019-08-26 | 51 | -208/+1039 |
| | | | | Git mirror commit 621e7bafbf6857451f23ba11b0495c7ac69aff89. | ||||
* | SLEEPQUEUE(9): Optimize sleepq_set_timeout_sbt() | Sebastian Huber | 2019-08-26 | 1 | -2/+3 |
| | | | | Avoid an extra ISR disable/enable in SMP configurations. | ||||
* | media01: Enable event recording | Sebastian Huber | 2019-08-26 | 1 | -0/+8 |
* | rtems/rtems-kernel-nexus.c: LibBSD init now uses all pass levels. | Nils Hölscher | 2019-08-12 | 1 | -1/+2 |
| | | | | | I observed all Modules loading in the last fdt pass. The reason was, nexus bus loading with BUS_PASS_DEFAULT. | ||||
* | Update to FreeBSD stable/12 2019-07-09 | Sebastian Huber | 2019-07-09 | 34 | -690/+711 |
| | | | | Git mirror commit 3427c3416aa3c0f25124070959cca78024b94d85. | ||||
* | EPOCH(9): Add epoch_drain_callbacks() | Sebastian Huber | 2019-07-09 | 3 | -2/+138 |
* | test/epoch01: Simplify | Sebastian Huber | 2019-07-09 | 1 | -48/+36 |
* | EPOCH(9): Avoid inline functions | Sebastian Huber | 2019-07-09 | 2 | -27/+35 |
| | | | | | FreeBSD changed the epoch_enter() and epoch_exit() inline functions into proper functions after a performance analysis to avoid code bloat. | ||||
* | SLEEPQUEUE(9): Fix timeout handling | Sebastian Huber | 2019-07-05 | 3 | -2/+8 |
* | Import missing header file | Sebastian Huber | 2019-06-28 | 2 | -0/+49 |
* | Update to FreeBSD stable/12 2019-06-26 | Sebastian Huber | 2019-06-26 | 20 | -126/+285 |
| | | | | Git mirror commit aa83598855d14cdbf7aef6b05d0617e90f87ca2f. | ||||
* | test/commands01: Fix sporadic test failures | Sebastian Huber | 2019-06-26 | 1 | -1/+29 |
