* | Fix the sed generator for processing INI configuration files. | Chris Johns | 2019-06-26 | 1 | -2/+2 | |
* | if_atsam: Remove WDT_Disable() | Sebastian Huber | 2019-06-13 | 1 | -3/+0 | |
| | | | | | The watchdog timer (WDT) can be configure only once. Do not touch it in the BSP since the application may want to use it. | |||||
* | config: Control the interface from the command line net config file. | Chris Johns | 2019-06-13 | 3 | -2/+4 | |
* | Remove junk folders. | Chris Johns | 2019-06-13 | 2 | -0/+0 | |
* | Update to FreeBSD stable/12 2019-06-05 | Sebastian Huber | 2019-06-05 | 368 | -7508/+34630 | |
| | | | | Git mirror commit 78576620f2689e23144a1cf1bf55106cc6abe2b7. | |||||
* | Add RTEMS-specific getcredhostuuid() | Sebastian Huber | 2019-06-05 | 2 | -11/+29 | |
* | Add riscv support | Sebastian Huber | 2019-05-23 | 2 | -1/+84 | |
* | Use _SMP_Unicast_action() | Sebastian Huber | 2019-05-21 | 2 | -8/+2 | |
| | | | | It is a bit more efficient. | |||||
* | Update due to API changes | Sebastian Huber | 2019-05-15 | 1 | -5/+3 | |
| | | | | Close #3749. | |||||
* | Separate libbsd and RTEMS clock ticks | Sebastian Huber | 2019-05-15 | 8 | -26/+15 | |
* | Fix USB_DEBUG redefinition warnings | Sebastian Huber | 2019-05-15 | 1 | -0/+12 | |
* | Include missing <stdlib.h> to fix warnings | Sebastian Huber | 2019-05-15 | 1 | -0/+1 | |
* | Remove unused maxusers | Sebastian Huber | 2019-05-15 | 2 | -3/+0 | |
* | Remove jail/prison functions from namespace | Sebastian Huber | 2019-05-15 | 1 | -21/+0 | |
* | Remove dangerous weak definition of getentropy() | Sebastian Huber | 2019-05-15 | 1 | -12/+0 | |
| | | | | All BSP supporting libbsd should provide this function. | |||||
* | Add hostname related sysctls conditionally | Sebastian Huber | 2019-05-13 | 1 | -0/+5 | |
| | | | | This helps to the reduce code size for USB only use cases. | |||||
* | usb: Undefine USB_DEBUG | Sebastian Huber | 2019-05-13 | 1 | -1/+1 | |
| | | | | | | In contrast to some other USB options which use 0/1 values, the USB_DEBUG uses defined/undefined to enable/disable the USB debug support. | |||||
* | Add wrapper for abort() | Sebastian Huber | 2019-05-13 | 1 | -2/+7 | |
* | Add USB mass storage only build set | Sebastian Huber | 2019-05-13 | 2 | -0/+22 | |
* | Use static inline functions for jail and prison | Sebastian Huber | 2019-05-13 | 2 | -230/+202 | |
| | | | | This helps the compiler to optimize away dead code. | |||||
* | Fix zero-copy mbuf support | Sebastian Huber | 2019-05-13 | 3 | -7/+5 | |
| | | | | In 2017 there was a change in the mbuf API. | |||||
* | IFCONFIG(8): Fix write to const string | Sebastian Huber | 2019-05-13 | 1 | -0/+6 | |
* | Update due to API changes | Sebastian Huber | 2019-04-11 | 12 | -18/+18 | |
* | nfsclient: Fix for 64-bit targets | Sebastian Huber | 2019-03-29 | 1 | -1/+8 | |
| | | | | | | | The use of the serporid structure with several embedded unions to split up the specific NFS request/response structures is quite a hack. It breaks on 64-bit targets due to the presence of pointer members which affect the overall alignment. | |||||
* | openssl02: Fix includes | Sebastian Huber | 2019-03-29 | 1 | -7/+3 | |
* | BPF(9): Disable legacy timestamp support | Sebastian Huber | 2019-03-29 | 1 | -0/+7 | |
* | Revert "Add BURN_BRIDGES global kernel option" | Sebastian Huber | 2019-03-29 | 1 | -5/+0 | |
| | | | | This reverts commit b5cc3f67ed15f23a868c7f846dca48ff9f3f803a. | |||||
* | Add BURN_BRIDGES global kernel option | Sebastian Huber | 2019-03-28 | 1 | -0/+5 | |
* | BPF(9): Fix timestamps | Sebastian Huber | 2019-03-28 | 1 | -0/+1 | |
* | Update to FreeBSD stable/12 2019-03-27 | Sebastian Huber | 2019-03-28 | 33 | -69/+781 | |
| | | | | Git mirror commit 43a38f188ca2e936ec78104c30ea3e24d9c1606b. | |||||
* | openssl/apps: Add missing newline | Sebastian Huber | 2019-03-28 | 52 | -0/+52 | |
| | | | | This is necessary to get a reversible import from FreeBSD. | |||||
* | CONTRIBUTING: Fix sed command example | Sebastian Huber | 2019-03-28 | 1 | -1/+1 | |
* | build: Add RTEMS test library | Sebastian Huber | 2019-03-28 | 1 | -2/+2 | |
| | | | | Update #3199. | |||||
* | bin/openssl: Port to RTEMS. | Christian Mauderer | 2019-03-28 | 114 | -0/+1424 | |
* | bin/openssl: Import from FreeBSD. | Christian Mauderer | 2019-03-28 | 58 | -0/+43004 | |
* | Update to FreeBSD stable/12 2019-03-11 | Sebastian Huber | 2019-03-11 | 167 | -3747/+5490 | |
| | | | | Git mirror commit 735fe7a0a5f9c265040e2e6654a01b081d6354f1. | |||||
* | tcpdump: Move static variables to special section | Sebastian Huber | 2019-03-11 | 6 | -0/+39 | |
| | | | | This fixes some issues if tcpdump is invoked a second time. | |||||
* | tcpdump: Remove superfluous static variable | Sebastian Huber | 2019-03-11 | 1 | -3/+1 | |
* | tcpdump: Use stack variables | Sebastian Huber | 2019-03-11 | 1 | -2/+2 | |
* | tcpdump: Constify | Sebastian Huber | 2019-03-11 | 4 | -13/+13 | |
* | rcconf02: Reduce maximum connection counts | Sebastian Huber | 2019-03-11 | 1 | -2/+2 | |
| | | | | This avoids a file descriptor exhaustion. | |||||
* | Remove unused file | Sebastian Huber | 2019-03-11 | 1 | -224/+0 | |
* | build: Make it possible to disable the tests | Sebastian Huber | 2019-02-18 | 1 | -1/+3 | |
* | Build C++ kernel-space compatibility file | Sebastian Huber | 2019-02-18 | 2 | -2/+4 | |
* | C++ compatibility for some kernel-space headers | Sebastian Huber | 2019-02-18 | 3 | -13/+13 | |
* | Fix atomic_load_32() | Sebastian Huber | 2019-02-18 | 1 | -1/+1 | |
* | builder.py: Accept C++ source files | Sebastian Huber | 2019-02-18 | 1 | -2/+2 | |
* | Remove <linux/rbtree.h> | Sebastian Huber | 2019-02-12 | 1 | -146/+0 | |
| | | | | It is already provided by RTEMS. | |||||
* | Remove obsolete <rtems/pty.h> | Sebastian Huber | 2019-02-12 | 1 | -68/+0 | |
* | mghttpd: Remove | Sebastian Huber | 2019-02-12 | 4 | -5927/+0 | |
| | | | | The mghttpd is already provided by RTEMS. |
