* | Fix python3 print problem. | Chris Johns | 2018-12-26 | 1 | -1/+4 | |
* | Add some Livermore pthread examples (GCI 2013/2018) | Marçal Comajoan Cara | 2018-12-09 | 8 | -0/+141 | |
| | | | | | | | | | | The initial conversion was done by Christopher Kerl as part of GCI 2013. Finally merged as part of GCI 2018. This is part of the Livermore pthread examples from https://computing.llnl.gov/tutorials/pthreads/ Closes #2087. | |||||
* | Remove outdated instructions and change sis to erc32 | Marçal Comajoan Cara | 2018-12-09 | 2 | -14/+2 | |
| | | | | This work was part of GCI 2018. | |||||
* | README.Makefile: New file | Joel Sherrill | 2018-10-26 | 1 | -0/+36 | |
* | Update rtems_waf | Sebastian Huber | 2018-10-25 | 1 | -0/+0 | |
| | | | | Update #3551. | |||||
* | rtems_waf: Update to get #3424 | Joel Sherrill | 2018-10-14 | 1 | -0/+0 | |
* | file_io/crc/Makefile: Update to match wscript | Joel Sherrill | 2018-10-14 | 1 | -8/+8 | |
* | README.waf: Update to reflect RTEMS 5 and sis->erc32 transition | Joel Sherrill | 2018-10-14 | 1 | -8/+12 | |
* | Add various programs to report default attributes for various POSIX objects | Joel Sherrill | 2018-09-26 | 30 | -35/+1051 | |
| | | | | Closes #3531. | |||||
* | c11_thread01/test.c: Fix minor issues | Joel Sherrill | 2018-09-24 | 1 | -3/+5 | |
* | README.waf: Update waf URL and sis->erc32 | Joel Sherrill | 2018-09-24 | 1 | -4/+4 | |
* | rtems_waf: Update to pick up rtems5 not having bin/ | Joel Sherrill | 2018-09-24 | 1 | -0/+0 | |
* | rtems_waf: Move to the public repositories. | Christian Mauderer | 2018-06-18 | 1 | -1/+1 | |
| | | | | | | | | | For an update from an earlier version it is necessary to do a git submodule sync rtems_waf git submodule update rtems_waf after this commit is applied to update the submodules URL. | |||||
* | wscript: fix default version from 4.12 to 5 | Gedare Bloom | 2018-01-18 | 1 | -1/+1 | |
* | Add examples for using the entire C11 <threads.h> API. | Joel Sherrill | 2017-10-12 | 1 | -0/+7 | |
| | | | | | | | | | c11_thread01 - multiple threads, arguments, yield, sleep c11_mutex01 - mutual exclusion, blocking, timeout c11_cndvar01 - use condition variable to signal data arrival c11_key01 - per thread storage Closes #3188. | |||||
* | Add C11 Threading Examples | Joel Sherrill | 2017-10-12 | 18 | -0/+814 | |
* | psx_sched_report: Add RTEMS configuration to address build issue. | Joel Sherrill | 2017-10-12 | 2 | -1/+40 | |
| | | | | Closes #3158. | |||||
* | Make crc and fdopen build | Joel Sherrill | 2017-10-12 | 2 | -3/+2 | |
| | | | | Updates #3158. | |||||
* | Fix warnings | Sebastian Huber | 2017-10-12 | 4 | -7/+7 | |
| | | | | Update #3158. | |||||
* | Fix configuration warnings | Sebastian Huber | 2017-10-12 | 7 | -13/+0 | |
* | Update due to trace linker changes | Sebastian Huber | 2017-10-12 | 3 | -3/+3 | |
| | | | | Close #3160. | |||||
* | ticker/low_ticker2/init.c: Add include <rtems/bspIo.h> | Joel Sherrill | 2017-10-05 | 1 | -2/+3 | |
* | ticker/low_ticker1/init.c: Add include <rtems/bspIo.h> | Joel Sherrill | 2017-10-05 | 1 | -0/+1 | |
* | ticker/low_ticker/init.c: Add include <rtems/bspIo.h> | Joel Sherrill | 2017-10-05 | 1 | -0/+1 | |
* | led/complex1/MessageQueueT.h: Add include <cstring> | Joel Sherrill | 2017-10-05 | 1 | -0/+1 | |
* | Update rtems_waf to use the rootfs support. Fix trace linker INI files. | Chris Johns | 2017-10-02 | 8 | -52/+29 | |
| | | | | | | | | | Use the rtems_waf rootfs support to create a root file system. Remove the double cflags on some projects that broke linking. Remove the dump-on-error, there is no option in rtems-tld. Closes 3158. Closes 3159. | |||||
* | Add waf to the project so we control the version required. | Chris Johns | 2017-10-02 | 2 | -0/+171 | |
| | | | | Updates 3158. | |||||
* | posix_api/psx_sched_report/test.c: Uses default configuration now. | Joel Sherrill | 2016-08-07 | 1 | -29/+6 | |
* | led/msg_server/init.c: Account for message buffers in configuration. | Joel Sherrill | 2016-08-07 | 1 | -0/+2 | |
* | fat_ramdisk: define POSIX keys number | Peng Fan | 2016-04-13 | 1 | -0/+3 | |
| | | | | | | | define POSIX KEYS and PAIRS to 16, otherwise met: " pthread_setspecific(shell_current_env_key) " | |||||
* | Added code to turn on and off LED for STM32F4 Discovery Board4.11.34.11.24.11.14.11.04.11 | SteveB | 2015-05-28 | 1 | -0/+23 | |
* | Pre-release top level clean up | Joel Sherrill | 2015-05-28 | 2 | -25/+0 | |
* | Update top files for upcoming release | Joel Sherrill | 2015-05-17 | 3 | -3/+14 | |
* | hello: remove spurious code. Close #2264 | Gedare Bloom | 2015-03-03 | 1 | -17/+1 | |
* | Add more trace builds for other examples. | Chris Johns | 2014-09-22 | 5 | -1/+75 | |
* | Add a deep trace of the both hello world. | Chris Johns | 2014-09-21 | 3 | -1/+55 | |
* | Add RTEMS trace support. | Chris Johns | 2014-09-21 | 4 | -1/+70 | |
* | Clean up warnings. | Chris Johns | 2014-09-05 | 4 | -7/+9 | |
* | hello: Fix the waf script. | Chris Johns | 2014-09-05 | 1 | -1/+0 | |
* | example-v2 patch for RPi B+ (led) | Pierre Ficheux | 2014-08-29 | 1 | -4/+12 | |
| | | | | | | | | | | | | | | | | | | Hi, Here is the patch for "example-v2" project to support Raspberry Pi B+ as led number is now 47 instead of 16 on RPi B. regards -- Pierre FICHEUX -/- CTO OW/OWI, France -\- pierre.ficheux@openwide.fr http://ingenierie.openwide.fr http://www.linuxembedded.fr I would love to change the world, but they won't give me the source code From e4d8edfb8650207641bc8e2716cf15ce958ede0f Mon Sep 17 00:00:00 2001 From: Pierre FICHEUX <pierre.ficheux@openwide.fr> Date: Fri, 29 Aug 2014 15:11:41 +0200 Subject: [PATCH] Added led blink support for RPi B+ | |||||
* | Miscellaneous clean up and warning removal | Joel Sherrill | 2014-08-29 | 11 | -103/+80 | |
* | User friendly error message if the rtems_waf module is not included. | Chris Johns | 2013-12-13 | 1 | -3/+8 | |
* | Replace rtems_waf with a submodule | Chirayu Desai | 2013-12-12 | 6 | -807/+11 | |
| | | | | | Replace the rtems_waf subdirectory with a git-submodule that points to the git repository located at http://git.rtems.org/chrisj/rtems_waf.git | |||||
* | waf: append .exe to target names | Gedare Bloom | 2013-12-12 | 23 | -23/+23 | |
* | led: complex1: Add support for building with waf | Chirayu Desai | 2013-12-12 | 2 | -0/+17 | |
* | misc: Add a commented out call to build adamain with waf | Chirayu Desai | 2013-12-12 | 1 | -0/+2 | |
| | | | | | * Currently disabled as it doesn't build, even with make. Refer commit 0da2dccb01e2aa13eeab492e2f5ca012ca3a2fab | |||||
* | misc: adamain: Add support for building waf | Chirayu Desai | 2013-12-12 | 1 | -0/+14 | |
| | | | | | But do not build it by default yet. Also see commit 9dd07ee6bb99bf57e7a9b5fb819dad88f2657ac4 | |||||
* | cxx: Add support for building with waf | Chirayu Desai | 2013-12-12 | 4 | -0/+44 | |
* | posix_api: Pass needed argument to posix check | Chirayu Desai | 2013-12-12 | 1 | -1/+1 | |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | Fixes commit 579cc3c468c0dc923e37474e38c778bc2d085382 Traceback (most recent call last): File "/home/cdesai/bin/.waf-1.7.13-8c328f55ac27cdb03b8c949f189bbac3/waflib/Scripting.py", line 97, in waf_entry_point run_commands() File "/home/cdesai/bin/.waf-1.7.13-8c328f55ac27cdb03b8c949f189bbac3/waflib/Scripting.py", line 153, in run_commands ctx=run_command(cmd_name) File "/home/cdesai/bin/.waf-1.7.13-8c328f55ac27cdb03b8c949f189bbac3/waflib/Scripting.py", line 146, in run_command ctx.execute() File "/home/cdesai/bin/.waf-1.7.13-8c328f55ac27cdb03b8c949f189bbac3/waflib/Scripting.py", line 351, in execute return execute_method(self) File "/home/cdesai/bin/.waf-1.7.13-8c328f55ac27cdb03b8c949f189bbac3/waflib/Build.py", line 106, in execute self.execute_build() File "/home/cdesai/bin/.waf-1.7.13-8c328f55ac27cdb03b8c949f189bbac3/waflib/Build.py", line 109, in execute_build self.recurse([self.run_dir]) File "/home/cdesai/bin/.waf-1.7.13-8c328f55ac27cdb03b8c949f189bbac3/waflib/Context.py", line 128, in recurse user_function(self) File "/home/cdesai/rtems/examples-v2/wscript", line 45, in build bld.recurse('posix_api') File "/home/cdesai/bin/.waf-1.7.13-8c328f55ac27cdb03b8c949f189bbac3/waflib/Context.py", line 128, in recurse user_function(self) File "/home/cdesai/rtems/examples-v2/posix_api/wscript", line 9, in build if rtems.check_posix(): TypeError: check_posix() takes exactly 1 argument (0 given) | |||||
* | posix_api: Turn posix check into function call. | Gedare Bloom | 2013-12-12 | 1 | -1/+1 | |
