* | user: Add RTEMS executable and test documentation. | Chris Johns | 2018-11-03 | 17 | -47/+1371 |
* | User: Simplify the top level headings. | Chris Johns | 2018-11-03 | 4 | -10/+26 |
* | Update the copyright year. | Chris Johns | 2018-10-19 | 1 | -1/+1 |
* | Move duplicate host configuration information from RSB to Users Guide | Joel Sherrill | 2018-10-13 | 4 | -236/+383 |
* | Merge duplicative RSB Quick Start into Users Guide | Joel Sherrill | 2018-10-13 | 4 | -18/+240 |
* | user: Document QorIQ BSP variants | Sebastian Huber | 2018-10-01 | 1 | -0/+3 |
* | user: Add i.MX 7D MMC/SDCard driver | Sebastian Huber | 2018-09-25 | 1 | -0/+8 |
| | | | | Close #3525. | ||||
* | user: Add qoriq BSP section | Sebastian Huber | 2018-08-29 | 1 | -1/+78 |
| | | | | Update #2854. | ||||
* | build: Fix indexing so it works on HTML and PDF. | Chris Johns | 2018-08-21 | 2 | -5/+1 |
| | | | | | | | | | | | | - Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503 | ||||
* | user: Update x86-64 chapter with end-of-GSoC status | Amaan Cheval | 2018-08-20 | 1 | -1/+51 |
* | user: Add RISC-V BSP section | Sebastian Huber | 2018-08-02 | 1 | -1/+109 |
| | | | | Update #3433. | ||||
* | user: Add x86_64 BSP chapter | Amaan Cheval | 2018-07-18 | 1 | -1/+142 |
* | user: Add BSP chapter for each architecture | Sebastian Huber | 2018-06-26 | 19 | -0/+144 |
| | | | | Update #3464. | ||||
* | user: Add ARM BSPs chapter | Sebastian Huber | 2018-06-26 | 3 | -0/+153 |
| | | | | | | Add NXP i.MX section as a BSP example. Update #2854. | ||||
* | Adding Trace Documentation | Vidushi Vashishth | 2018-06-18 | 6 | -0/+996 |
| | | | | | | | | - Updates #3454 - This commit adds Tracing Framework Chapter in the RTEMS User Manual - It comprises of subchapters on RTEMS Trace Linker, Capture Engine, Trace generation techniques explaining trace generation using Trace Buffering and Printk generators and sample demonstrations. | ||||
* | user: Do not mention "bootstrap -p" | Sebastian Huber | 2018-03-28 | 1 | -2/+1 |
| | | | | | | It is now obsolete and was never necessary for an RTEMS users. Update #3254. | ||||
* | Clean up sphinx warnings. | Chris Johns | 2017-11-13 | 6 | -83/+43 |
| | | | | | | | | | | - Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229. | ||||
* | Use '.. toctree::' and not '.. include::' in the User Manual. | Chris Johns | 2017-11-13 | 17 | -228/+30 |
| | | | | | | | | - Change all suitable '.. include::' to TOC tree. - Remove unused and not needed sections. - Fix the conf.py to not exclude some files. Close #3232. | ||||
* | Add indexes to all documents. | Chris Johns | 2017-11-12 | 2 | -2/+5 |
* | Change RTEMS version to 5 | Sebastian Huber | 2017-11-09 | 9 | -228/+244 |
| | | | | Update #3220. | ||||
* | Update copyright notices. | Chris Johns | 2017-08-11 | 3 | -11/+32 |
* | User Manual: Added rtems-tester in the docs | Tanu Hari Dixit | 2017-06-14 | 2 | -0/+447 |
| | | | | | | | Added as part of Tools. Made changes according to Chris' review Also removed the ini format part inline with the new release that is expected. | ||||
* | User: Remove conflict marker. | Chris Johns | 2017-06-01 | 1 | -1/+0 |
* | User: Remove the stash conflict markers. | Chris Johns | 2017-05-31 | 1 | -4/+0 |
* | User: Improvements to some of the tools commands. | Chris Johns | 2017-05-31 | 3 | -50/+51 |
* | User Manual: Update the rtems-bsp-builder command. | Chris Johns | 2017-05-24 | 1 | -420/+282 |
* | waf: Cleaner formatting to see the importing. | Chris Johns | 2017-03-27 | 1 | -6/+7 |
* | user: Fix typo. | Chris Johns | 2017-03-21 | 1 | -1/+1 |
* | user: Minor fixes to rtems-bsp-builder. | Chris Johns | 2017-03-21 | 1 | -3/+3 |
* | user: Add an example of the rtems-bsp-builder running. | Chris Johns | 2017-03-21 | 1 | -2/+389 |
* | Use a single top level version number. | Chris Johns | 2017-03-20 | 1 | -4/+5 |
* | user: Add tool commands to the user manual. | Chris Johns | 2017-03-15 | 7 | -23/+612 |
* | Update document titles for consistency | Joel Sherrill | 2017-01-11 | 1 | -3/+3 |
* | Remove references to SPARC/SIS BSP. Also clean up old ERC32 references. | Joel Sherrill | 2017-01-11 | 1 | -1/+1 |
| | | | | updates #2810. | ||||
* | Update version/revision to 4.11.99 | Sebastian Huber | 2016-12-21 | 1 | -2/+2 |
* | user: Fix header levels. | Chris Johns | 2016-11-09 | 28 | -65/+88 |
* | Fix spelling. | Chris Johns | 2016-11-02 | 1 | -1/+1 |
* | waf: Add an install command. | Chris Johns | 2016-10-31 | 1 | -2/+6 |
* | waf: Formatting. | Chris Johns | 2016-10-30 | 1 | -2/+2 |
* | user: Add comments about warnings we cannot remove. | Chris Johns | 2016-10-29 | 2 | -0/+5 |
* | user: Add comment to move to packages. | Chris Johns | 2016-10-29 | 1 | -0/+3 |
* | ecosys/index.rst: Fix complixity spelling | Joel Sherrill | 2016-10-27 | 1 | -1/+1 |
* | Fix the table and section numbering in the User,Hardware,Tiers section. | Chris Johns | 2016-07-06 | 1 | -16/+16 |
* | Add a Hardware section. | Chris Johns | 2016-07-06 | 9 | -19/+224 |
* | Update the glossary. | Chris Johns | 2016-07-06 | 1 | -0/+25 |
* | Add the RTEMS Kernel section back in. | Chris Johns | 2016-07-04 | 3 | -0/+435 |
* | Reorganisse the User Manual to make it easier to navigate. | Chris Johns | 2016-07-04 | 19 | -843/+734 |
* | Set SPDX License Identifier in each source file. | Chris Johns | 2016-05-20 | 28 | -0/+56 |
* | Move images to a common directory. | Amar Takhar | 2016-05-18 | 2 | -1/+1 |
* | Review changes from Chris Mayfield. | Chris Johns | 2016-05-02 | 3 | -61/+67 |
