* | Fix bad formatting that somehow went into the doco. | Chris Johns | 2016-05-02 | 1 | -47/+47 |
* | Corrections from a review. | Chris Johns | 2016-05-02 | 3 | -87/+97 |
* | Corrections and improvements from Worth Burruss (thanks so much). | Chris Johns | 2016-05-02 | 2 | -7/+38 |
* | Corrections. | Chris Johns | 2016-05-02 | 3 | -39/+65 |
* | Add a basics section to Getting Started. Rearrange the content. | Chris Johns | 2016-05-02 | 8 | -380/+563 |
* | Start adding Getting Started guide's Released Version. | Chris Johns | 2016-05-02 | 1 | -2/+267 |
* | Updates from user reviews. | Chris Johns | 2016-05-02 | 2 | -23/+28 |
* | Split installation into separate files. | Chris Johns | 2016-05-02 | 6 | -632/+646 |
* | User manual, devel install and windows install. | Chris Johns | 2016-05-02 | 17 | -56/+1612 |
* | Add 'waf linkcheck' to check external references. | Amar Takhar | 2016-05-02 | 1 | -1/+1 |
* | Add PDF generation support use with --pdf | Amar Takhar | 2016-05-02 | 2 | -6/+5 |
* | Add support for spellchecking with a custom dictionary. | Amar Takhar | 2016-05-02 | 1 | -1/+1 |
| | | | | | | | | | | | | | | To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar. | ||||
* | Rework how conf.py is handled. | Amar Takhar | 2016-05-02 | 2 | -9/+9 |
| | | | | Needed to switch due to increasing complexity. | ||||
* | Initial reST documentation using Sphinx. | Amar Takhar | 2016-05-02 | 25 | -0/+432 |
