* | user: Automatic version number fixes | Chris Johns | 2023-12-20 | 2 | -16/+16 |
| | | | | Updates #4695 | ||||
* | Update company name | Sebastian Huber | 2023-05-20 | 1 | -1/+1 |
| | | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | ||||
* | Document CONFIGURE_RECORD_INTERRUPTS_ENABLED | Sebastian Huber | 2022-12-02 | 1 | -60/+5 |
| | | | | Close #4769. | ||||
* | Update build system related sections for RTEMS 6 | Sebastian Huber | 2022-11-08 | 1 | -2/+2 |
| | | | | Update sections which contained the word "bsp_specs". | ||||
* | user: Mention use of LLVM | Sebastian Huber | 2021-01-04 | 1 | -0/+4 |
* | user: Document event recording | Sebastian Huber | 2020-04-11 | 1 | -10/+212 |
| | | | | Close #3904. | ||||
* | User: Change output block to type none. | Chris Johns | 2019-03-01 | 3 | -10/+10 |
* | user: Remove nit-picky warnings. | Chris Johns | 2019-02-28 | 4 | -13/+13 |
* | user: Add basic event recording documentation | Sebastian Huber | 2019-02-01 | 5 | -4/+64 |
| | | | | Update #3665. | ||||
* | user: Spell out third-party | Sebastian Huber | 2019-01-24 | 1 | -1/+1 |
* | Simplify SPDX-License-Identifier comment | Sebastian Huber | 2019-01-11 | 5 | -5/+5 |
* | Remove superfluous "All rights reserved." | Sebastian Huber | 2019-01-11 | 5 | -5/+0 |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 5 | -5/+5 |
* | Eliminate UTF-8 characters except superscripted 2 in i2c | Joel Sherrill | 2018-12-20 | 2 | -4/+4 |
* | User: Simplify the top level headings. | Chris Johns | 2018-11-03 | 1 | -2/+2 |
* | Adding Trace Documentation | Vidushi Vashishth | 2018-06-18 | 5 | -0/+994 |
- Updates #3454 - This commit adds Tracing Framework Chapter in the RTEMS User Manual - It comprises of subchapters on RTEMS Trace Linker, Capture Engine, Trace generation techniques explaining trace generation using Trace Buffering and Printk generators and sample demonstrations. |
