* | user: Spell out third-party | Sebastian Huber | 2019-01-24 | 1 | -1/+1 |
* | Simplify SPDX-License-Identifier comment | Sebastian Huber | 2019-01-11 | 1 | -1/+1 |
* | Remove superfluous "All rights reserved." | Sebastian Huber | 2019-01-11 | 1 | -1/+0 |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 1 | -1/+1 |
* | Clean up sphinx warnings. | Chris Johns | 2017-11-13 | 1 | -1/+0 |
| | | | | | | | | | | - Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229. | ||||
* | Use '.. toctree::' and not '.. include::' in the User Manual. | Chris Johns | 2017-11-13 | 1 | -6/+8 |
| | | | | | | | | - Change all suitable '.. include::' to TOC tree. - Remove unused and not needed sections. - Fix the conf.py to not exclude some files. Close #3232. | ||||
* | User Manual: Added rtems-tester in the docs | Tanu Hari Dixit | 2017-06-14 | 1 | -0/+1 |
| | | | | | | | Added as part of Tools. Made changes according to Chris' review Also removed the ini format part inline with the new release that is expected. | ||||
* | User: Remove conflict marker. | Chris Johns | 2017-06-01 | 1 | -1/+0 |
* | User: Improvements to some of the tools commands. | Chris Johns | 2017-05-31 | 1 | -11/+10 |
* | user: Add tool commands to the user manual. | Chris Johns | 2017-03-15 | 1 | -6/+18 |
* | user: Fix header levels. | Chris Johns | 2016-11-09 | 1 | -2/+1 |
* | Reorganisse the User Manual to make it easier to navigate. | Chris Johns | 2016-07-04 | 1 | -8/+8 |
* | Set SPDX License Identifier in each source file. | Chris Johns | 2016-05-20 | 1 | -0/+2 |
* | Initial reST documentation using Sphinx. | Amar Takhar | 2016-05-02 | 1 | -0/+10 |
