* | user: Document BSP new build system | Sebastian Huber | 2020-09-13 | 1 | -1/+0 |
| | | | | Update #3818. | ||||
* | start/index: relocate gsoc section | Gedare Bloom | 2020-04-02 | 1 | -1/+1 |
* | start/gsoc: GSoC Getting started instructions. | G S Niteesh Babu | 2020-04-02 | 1 | -0/+1 |
| | | | | | Added instructions to setup development environment for students interested in GSoC. | ||||
* | user: Update Quick Start Guide | Chris Johns | 2020-03-13 | 1 | -1/+2 |
| | | | | | | | | | - Add support for release source archives - Add building the BSP using the RSB - Add building packages using the RSB - Add an application Closes #2998 | ||||
* | user: Remove nit-picky warnings. | Chris Johns | 2019-02-28 | 1 | -2/+0 |
* | user: Remove obsolete content in quick start | Sebastian Huber | 2019-02-18 | 1 | -87/+0 |
* | user: Add "Build Your Application" | Sebastian Huber | 2019-02-18 | 1 | -0/+1 |
* | user: Add "Test a Board Support Package (BSP)" | Sebastian Huber | 2019-02-18 | 1 | -0/+1 |
* | user: Add "Build a Board Support Package (BSP)" | Sebastian Huber | 2019-02-18 | 1 | -0/+1 |
* | user: Add "Bootstrap the RTEMS Sources" | Sebastian Huber | 2019-02-18 | 1 | -0/+1 |
* | user: Add "Install the Tool Suite" section | Sebastian Huber | 2019-02-18 | 1 | -0/+1 |
* | user: Add "Obtain the Sources" section | Sebastian Huber | 2019-02-18 | 1 | -0/+1 |
* | user: Rework Prefixes section | Sebastian Huber | 2019-02-18 | 1 | -1/+1 |
| | | | | | | Rename it to "Choose an Installation Prefix". Update #3675. | ||||
* | user: Spell out third-party | Sebastian Huber | 2019-01-24 | 1 | -1/+1 |
* | user: Add "Host Computer Setup" to "Quick Start" | Sebastian Huber | 2019-01-14 | 1 | -0/+1 |
* | user: Move "Prefixes" to "Quick Start" | Sebastian Huber | 2019-01-14 | 1 | -0/+9 |
| | | | | | Move "Project Sandboxing" to a separate section of the "Installation" chapter since this is an advance topic which may confuse new users. | ||||
* | Simplify SPDX-License-Identifier comment | Sebastian Huber | 2019-01-11 | 1 | -1/+1 |
* | Remove superfluous "All rights reserved." | Sebastian Huber | 2019-01-11 | 1 | -1/+0 |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 1 | -1/+1 |
* | user: Rework overview | Sebastian Huber | 2019-01-09 | 1 | -0/+2 |
| | | | | | | Move "Overview", "Real-time Applicaiton Systems" and "Real-time Executive" chapters as sections into new "Introduction" chapter. Add "Feature" section. | ||||
* | Merge duplicative RSB Quick Start into Users Guide | Joel Sherrill | 2018-10-13 | 1 | -15/+35 |
* | user: Do not mention "bootstrap -p" | Sebastian Huber | 2018-03-28 | 1 | -2/+1 |
| | | | | | | It is now obsolete and was never necessary for an RTEMS users. Update #3254. | ||||
* | Clean up sphinx warnings. | Chris Johns | 2017-11-13 | 1 | -2/+4 |
| | | | | | | | | | | - Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229. | ||||
* | Change RTEMS version to 5 | Sebastian Huber | 2017-11-09 | 1 | -4/+4 |
| | | | | Update #3220. | ||||
* | user: Fix header levels. | Chris Johns | 2016-11-09 | 1 | -1/+1 |
* | Reorganisse the User Manual to make it easier to navigate. | Chris Johns | 2016-07-04 | 1 | -14/+70 |
* | Set SPDX License Identifier in each source file. | Chris Johns | 2016-05-20 | 1 | -0/+2 |
* | Review changes from Chris Mayfield. | Chris Johns | 2016-05-02 | 1 | -2/+2 |
* | Corrections from Worth Burruss. Many thanks. | Chris Johns | 2016-05-02 | 1 | -4/+3 |
* | Add a basics section to Getting Started. Rearrange the content. | Chris Johns | 2016-05-02 | 1 | -0/+4 |
* | Split installation into separate files. | Chris Johns | 2016-05-02 | 1 | -1/+0 |
* | User manual, devel install and windows install. | Chris Johns | 2016-05-02 | 1 | -3/+8 |
* | Initial reST documentation using Sphinx. | Amar Takhar | 2016-05-02 | 1 | -0/+10 |
